Question about Canon FAX L-120 Plain Paper Laser
My printer error is "No Toner Cartridge Put in Cartridge".already replaced it multiple times says the same thing,i 've checked the sensors,serviced the fuser unit and gear assembly,the arm is intact and the formatter works in my other printer.please help
Remove the toner cartridge and all the paper. make sure the top flap is closed then disconnect the power for about one minute. plug back in and allow to reboot, then put back the toner cartridge and paper, it should now be fine!
Posted on Nov 24, 2010
HOW CAN I SOLVE "THE TONER IS NOT SET INSERT THE TONER" ERROR ON MF3220 CANON, I've checked the sensor and cartridge gears.
TAke out the cartridge and unplug it and plug it back in and put the cartridge back in and see if thats the problem for you.
Dec 29, 2012 | Office Equipment & Supplies
I have a lexmark T520, just replace the old cartridge because it was leaving ink marks down sides of paper, smudges. Replaced with the new cartridge and it makes a loud popping noise. Now it's giving an...
Hello thanks for using Fixya
A 929 Service Toner Sensor error indicates a problem with the toner sensor, the front harness cable, or the developer drive. It could also mean that the toner cartridge is defective.
The most likely cause of this error is the toner cartridge itself. This is especially true if it is a new cartridge and the error started after you installed it.
To solve it try this:
Take the cartridge out of the printer and locate the encoder wheel on the right-hand side of the cartridge. The encoder wheel can be found on the right side of the cartridge (usually over a bar code sticker). It is a thin, black, plastic wheel with small rectangular notches cut into it. This wheel will sometimes get stuck, but you can free it by turning it by hand.
Try moving the wheel forwards and backwards a little. If it does not turn correctly, you will receive a 929 Toner Sensor error on the printer when you try to use the cartridge it is attached to
Note: The encoder wheel moves only a little bit each way. It should not make a complete revolution. If it does, the wheel is probably broken.
Try to move it a little bit each way a couple of times to see if you can free it up. Caution! DO NOT force the wheel as you could break it.
If the wheel on the toner cartridge is stuck, try another new toner cartridge. ( If you do not have another new toner cartridge available, an old toner cartridge or another cartridge from a working printer of the same model will also suffice for this test.)
Power the printer off and install the second toner cartridge. Then power the printer back on. If another toner cartridge clears up the 929 error, the printer is fine and the problem is with the toner cartridge.
If the error does not clear, there may be a problem with the printer.
If you narrow down the problem to the toner cartridge, call the point of purchase and explain the situation to them. They may have a replacement policy.
If you receive this error with a second toner cartridge, you may want to check if the Front Harness Cable is plugged into the Toner Sensor then Do the following:
Turn off the printer and remove the toner cartridge.
Look inside the printer at the place where the cartridge goes (on the right). You should see the Toner Sensor. On the back of the sensor assembly, you should be able to see a white cable connector.
Push this white cable connector into the toner sensor assembly by pushing the connector towards the front of the printer.
If you continue to receive the 929 error the final option is your printer will probably need service.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Feb 11, 2011 | Lexmark T520 Laser Printer
Hp8500n display reads replace toner cartridge when toner already installed
The toner cartridge is most likely not sitting in there correctly. Take it out and put it back in again. Make sure it snaps into place.
Check to see if the cartridge sensor is blocked, it is usually a flag that gets push in to activate the sensor.
Sometimes there is a tab on the toner itself, that if it breaks off then that error will appear.
Try the old cartridge, see if it does the same thing. let me know.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Jan 21, 2011 | HP Office Equipment & Supplies
Sharp MX-M450N getting F2-00 error and the AR455NT toner not working.. i know it means sensor open it is a new machine and already getting error... cant find nothing in manual on how to repair this issue
F2 00 Content Toner control sensor open/sensor
trouble
Detail Toner control sensor output open
Cause Connector harness trouble
Connector disconnection
Sensor trouble
Check and
remedy
Check connection of the toner control
sensor.
Check connection of connector and
harness to the main PWB.
Check for disconnection of harness.
Replace the sensor.
This is right from the service manual...one thing you can try.
1)copier must be up to ready state.
2)press #,*,clear,*(that will enter you into a simulation mode)
3)press 14, execute,yes.
4)or 14, print button.
5)press CA (clear all) button.
that should reset it to a working state without causing any damage to the copier.
Jul 29, 2010 | Sharp AR-BC260 Color Copier
Our Dell 5210N printer gives the error: 929.00 service toner sensor. What should we do
  • The most likely cause of this error is the toner cartridge itself. This is especially true if it is a new cartridge and the error started after you installed it.
    1. Take the cartridge out of the printer and locate the encoder wheel on the right-hand side of the cartridge. The encoder wheel can be found on the right side of the cartridge (usually over a bar code sticker). It is a thin, black, plastic wheel with small rectangular notches cut into it. This wheel will sometimes get stuck, but you can free it by turning it by hand.
    2. Try moving the wheel forwards and backwards a little. If it does not turn correctly, you will receive a 929 Toner Sensor error on the printer when you try to use the cartridge it is attached to. Note: The encoder wheel moves only a little bit each way. It should not make a complete revolution. If it does, the wheel is probably broken.
    3. Try to move it a little bit each way a couple of times to see if you can free it up. Caution! DO NOT force the wheel as you could break it.
    4. If the wheel on the toner cartridge is stuck, try another new toner cartridge. ( If you do not have another new toner cartridge available, an old toner cartridge or another cartridge from a working printer of the same model will also suffice for this test.) Power the printer off and install the second toner cartridge. Then power the printer back on. If another toner cartridge clears up the 929 error, the printer is fine and the problem is with the toner cartridge. If the error does not clear, there may be a problem with the printer.
    5. If you narrow down the problem to the toner cartridge, call the point of purchase and explain the situation to them. They may have a replacement policy. If they cannot help you, call our Technical Support Center and we will see what we can do to replace the cartridge that is causing the error. We will not be able to reimburse the price of the cartridge, but we can offer you an exchange. To do this, we may ask you to send in your cartridge first. Please note that we cannot offer an exchange on a refilled or refurbished cartridge. For this, you must go through the point of purchase.
      Click here to order toner cartridges and other supplies for your printer.
  • If you receive this error with a second toner cartridge, you may want to check if the Front Harness Cable is plugged into the Toner Sensor. Do the following:
    1. Turn off the printer and remove the toner cartridge.
    2. Look inside the printer at the place where the cartridge goes (on the right). You should see the Toner Sensor. On the back of the sensor assembly, you should be able to see a white cable connector.
    3. Push this white cable connector into the toner sensor assembly by pushing the connector towards the front of the printer.
  • If you continue to receive the 929 error, your printer will probably need service.
Source: Lexmark KnowledgeBase
May 20, 2010 | Dell 5210n Laser Printer
Problem with Dell 1720 printer
Hello
You have to check couple things in this case.
Ensure that the printer cover is closed.
  1. Remove the toner cartridge.
  2. Firmly shake it side-to-side and front-to-back several times to redistribute the toner.
  3. Reinsert the toner cartridge, and continue printing.
Repeat this procedure multiple times until the print remains faded. When the print remains faded, replace the toner cartridge.
or
The imaging drum is approaching full and needs to be replaced. Order a new imaging drum.
Apr 30, 2010 | Dell 1720dn Laser Printer
COF36 error on a Bizhub C350
Hi
C0F36 error means abnormally low toner density detected Black ATDC Sensor. Check for the black toner and try reinstalling the cartridge if replaced already. And if the toner crtridges are empty then replace the cartridge.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 21, 2009 | Konica Minolta Office Equipment & Supplies
929 service toner sensor error
Error: 929 Toner Sensor
Jul 03, 2008 | Lexmark Optra T620 Laser Printer
Phaser 7300 error message...
The problem is a crazy design in the printer itself! I've now found a reliable fix for this problem which is relatively easy to carry out. You will find the details of how to do it here :
www.michelsplace
Jan 24, 2008 | Xerox Phaser 7300DN Laser Printer
well i was having the same problem and what i did was open up the side of the printer. the same side that the toner sensor is on. the sensor consists of three metal parts. i took a screwdriver and pressed them on the outside. i pressed them in and up to ensure that the sensors are connecting. and i have not had that problem since.
Nov 02, 2007 | Lexmark T630n VE Laser Printer
Canon FAX L-120 Plain Paper Laser Logo
278 people viewed this question
old marine
old marine
