Question about Toshiba 50H13 50" Rear Projection Television
Broken front viewing screen
There appears to be three sections to this screen assy . Where can i obtain replacements?
    Problem Solver:
  • 14 Answers
Pacparts 800-338-6342 fox international 800-321-4330
Posted on May 06, 2008
What is Konica C6500 bizhub PGC sensor?
OK you going to open front door pull out mid section not where the paper is but where the drums and transfer belt are located. Once out go the right and look in DO NOT PUT ANY WEIGHT WHAT SO EVER ON ANY OF THE FOUR SHAFTS you will do some SERIOUS Damage!!!!!!!!!!!!!!!!!!!!!! So looking in there to the left you will see a assy. that is high up even with belt on the other side. That assy. as Three sensors one is your PGC two of thee sensor are in the front one sensor is in the back be care each has small spring that is used to pull the shutter down after the solenoid fires behind that assy. recommended that all three sensors be cleaned they get covered with toner from the belt cleaning assy. That hole assy. can come out to screws in the rear and one connector use a magnetic screwdriver and ensure power is off AGAIN NO PRESSURE ON THE DRUM SHAFTS!
Aug 07, 2014 | Konica Minolta bizhub Office Equipment &...
Sc28-03 minolta di 650
Pull out the middle assy. you will see a section that has a grill over it inside there are two/three very thin wires. They carry a very HV during the copy process not with the section out. There is a clean device on them that goes from one end to the other, your code deals with the motor that drive the cleaning device. Remove the assy., two screws front rear whole assy. comes out remove the tiny gear bring the cleaning device to the rear re-install gear re install assy. if the code comes back burn out motor, can also get a tech to turn it off for ever, not really that important.
May 08, 2014 | Konica Minolta Genuine Di650 Di551 Di5510...
How can fix this code C-2105 in konica minolta bizhup 600
Check the Transfer/SEP assy. it is directly below the drum when you open the front section of the machine it will be a assy. with three very thin wires covered by a plastic guard there is cleaning device that cleans those wires when you turn on the machine. Check the drive for the cleaning motor, assy. can be removed two screws one in the front one in the back on the section you open. Motor is under the front part of the assy. Can be completely turned off via service mode soft switches.
Jul 21, 2012 | Konica Minolta Developer 02xk Dv710 for...
1997 mercury grand Marquis driverside rear window motor works but window won't go up. Inner door panel off. Metal cable with a black foam cover and pink plastic clip off. Can't figure what it fits to.
usually this means you need a new window regulator.
Section 01-11: Glass, Frames and Mechanisms 1997 Crown Victoria, Grand Marquis Workshop Manual
REMOVAL AND INSTALLATION Window Regulator, Power Front Door
Removal
  1. If front door window glass (21410) is in the down position and is inoperable, the following steps must be taken; if front door window glass is operational, go to Step 2.
    1. Remove front door trim panel (23942) and front door trim shield (237A04). Refer to Section 01-05 .
    2. Disconnect battery ground cable (14301). Refer to Section 14-01 .
    3. Disconnect window regulator electric drive harness connector.
    4. sva~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Be careful not to strike or scratch front door window glass because it can break.
      Remove window regulator electric drive retaining screws through holes.
    5. Remove window regulator electric drive (23394) from front door power window regulator.
    6. Raise front door window glass to full up position by hand and secure with tape.
    7. Go to Step 5.
  2. Remove front door trim panel and front door trim shield. Refer to Section 01-05 .
  3. Remove front door window glass as described.
  4. Disconnect window regulator electric drive harness connector.
  5. NOTE: Use care not to enlarge sheet metal holes in the door inner panel.
    Remove two 1/4-inch rivets retaining lower bracket of front door power window regulator to inner panel. Use drift punch to knock out center pins for each rivet. Using a 1/4-inch diameter drill, drill out remainder of rivet.
  6. Remove three window regulator electric drive retaining screws from inside door to remove window regulator electric drive from front door power window regulator.
  7. Remove two window regulator retaining nuts.
  8. Remove front door power window regulator from front door (20124).
Installation
  1. Lubricate regulator mechanism with Teflon® Lubricant E7FZ-19590-A or equivalent meeting Ford specification ESB-M1C111-A.
  1. Install front door power window regulator minus motor (23208) into access hole in inner panel.
  1. Position front door power window regulator using upper studs and tabs on window regulator electric drive mounting bracket.
  1. Install rivets retaining front door power window regulator to door inner panel (1/4-20 x 1/2 inch screw and 1/4-20 nut and washer assemblies or equivalent metric fasteners may be used).
  1. Install two upper front door power window regulator retaining nuts.
  1. Install window regulator electric drive with three screws. Do not overtighten screws.
  1. Connect the window regulator electric drive harness connector.
  1. Install front door window glass.
  1. Adjust front door window glass as described.
  1. Install front door trim shield and front door trim panel. Refer to Section 01-05 snorkelbobby_38.gif
Feb 14, 2011 | 1997 Mercury Grand Marquis
Minolta Copier EP 6000 copier error codes: C:C0010, C:C0992, C:C0410. Any ideas what these mean?
As for the C0992 code that deals with a paper draw fault, looking at the control panel do you see a small wrench located at the left hand lower corner. Touch it , it will take you to another screen when there open and close the front door, if the code comes back you have problem with main draw.
The C0410 is a problem with the very, bright lite under the big glass is bad. try to reset, open the front door to your left is a small access plate open and press trouble reset, if the code comes back replace the exposure lamp.
C0010 code main motor fault, remove the fuse unit the hot part and check for broken gears check the section where it goes look in the back for broken gears, remove the drum assy. check for broken gears, open close the front door to reset, If it comes back get a new main motor and or main control board,
Dec 03, 2010 | Minolta Office Equipment & Supplies
Need a diagram for installing a drivers side electric power mirror on a 1995 mercury villager van
here's 1996, all I have. Please rate.
Mirror, Power — Outside Rear View NOTE: This procedure applies to both RH and LH power outside rear view mirrors.
Removal
  1. Remove the front door trim panel (23942). Refer to Section 01-05 for the removal procedure.
  1. Remove the two outside rear view mirror inside mounting hole cover screws and the outside rear view mirror mounting hole cover (17K709) from the front door (20124).
  1. Remove the wire clip.
  1. Disconnect the power outside rear view mirror electrical connector.
  1. Remove the three power outside rear view mirror bolts and the power outside rear view mirror.
Installation
To install, reverse the removal procedure. Tighten the three power outside rear view mirror bolts to 3-4 Nm (27-35 lb-in). Glass, Outside Mirror
Removal and Installation
Refer to the glass replacement procedures in Manual Mirror for power outside rear view mirror glass (17K707) Trim Cover
Removal
  1. Remove the front door trim panel. Refer to Section 01-05 for the removal procedure.
  1. Remove the two outside rear view mirror inside mounting hole cover screws.
    Remove the outside rear view mirror mounting hole cover.
Installation
To install, reverse the removal procedure. Mirror Control
Removal
  1. Use a small flat-blade screwdriver to pry the power outside rear view mirror control switch from the instrument panel (04320).
May 13, 2010 | 1995 Mercury Villager
Is it possible to fix the view screen if just the glass (not the ldc) is broken? Fuji FinePix Z5fd
There is a plastic cover over the LCD. Is only the cover broken? The plastic cover is easily replaceable.
But there is also a sheet of glas over the LCD. This is a part of the LCD assy and cannot be replaced without replacing the entire LCD.
Feb 08, 2010 | Fuji FinePix Z5fd Digital Camera
Sony handycam dcr-sr40 cracked 2.5 lcd view screen
LCD in DCR-SR40 part number is as follows..
A-1202-054-A TP BLOCK ASSY (25ESTGU06)
Available in Part Store.
LCD cabinet has few screws as mentioned in below exploded view image that will be removed, unplug flexible wire (orange color) take out broken lcd and put new lcd, put things in reverse order.
Thanks.
Oct 01, 2009 | Sony Handycam DCR-SR40 Camcorder
View Sonic monitor
I have Viewsonic 15" CRT Monitor (model E53)
When power ON, ther is only a colour patch appears on the middle of the screen . I observed some resistors and three transistors in horizontal sections were burnt.
I cannot read the real values of them because they are burnt.
Please kindly can you tell me those real values in that section.
Jun 13, 2008 | ViewSonic Computers & Internet
No view on viewfinder or screen
If the lcd screen is black even with the lens cap off,the ccd base assy. needs replacing.
May 28, 2008 | JVC GR-D20EK Camcorder
Toshiba 50H13 50" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
