1. Consider the following output from DataDesk when analyzing the pH values of the 1986 data collected on precipitation events. Summary stats for 1986 NumNumeric = 55 NumNonNumeric = 0 NumCases = 55 Mean = 6.0673 Median = 6.1000 Std Deviation = 0.47339 1 Range = 2.4000 Minimum = 4.6000 Maximum = 7 75-th %ile = 6.4000 Which of the following is NOT CORRECT? (a) The 25th percentile is about 5.9. (b) Some outliers appear to be present below a pH of 5.4. (c) About 95% of the observations have pH values in the approximate range 6 ± 1. (d) About 10% of the values are in the range 5.8 to 6.0. (e) About 75% of the values are less than 6.4.
4 Suggested Answers
  • 101 Answers
SOURCE: Question no. 2
64 62 52 50 70 60 55 20 25 48 35 55 55 47 64 42 36 50 30 53 51 63 58 50 60 54 33 48 40 76 61 46 65 65 15 45 58 40 64 18 33 40 64 18 33 40 48 9 38 41
Highest value observed: 76
Lowest Value: 9
Standard deviation from the ungrouped data: 15.25
Frequency:
Mean: 46.94
Standard deviation from grouped data: 15.40
Posted on Oct 23, 2009
  • 29 Answers
SOURCE: Athlon processor upgrade assistance:
Go to this link:
http://us.msi.com/?func=searchresult&keywords=ms-7025
Select the model motherboard you have and click on the CPU support link, it will show you a list of CPU's that are supported. You have a socket 939 board and AMD CPU's are now AM2, AM2+ and AM3 socket, which are 940 pin. It may be difficult to find a new CPU for your motherboard that is new since they have not been made in awhile.
Posted on Feb 11, 2010
garethmt
  • 116 Answers
SOURCE: error event
Your power supply is not providing the correct voltage, it needs replacing.
Posted on Mar 30, 2010
Error stat
Are the data in L1 and l2 in any way related? If they are (being x-values and y-values of some data set) then you need to do regression analysis (2-var stats)
If they are not related (connected) you can calculate the mean of each group separately.
Do 1-var stat by specifying the L1 list first (may be the default), get your average of the values in L1. Then you can do 1-var stat on the data in L2 by specifying the list L2 on the command line.
1-var L2 ENTER
Note: What I am describing here is valid for the TI 83 Plus/TI84 Plus, but I suspect the steps are similar to the TI 82.
Oct 08, 2013 | Texas Instruments TI-82 Calculator
Sharp advanced EL-531x how to input number after number for stats
First you have to set the calculator in STAT mode, presumably Standard Deviation or SD. The display should show a STAT annoucer to the top. To enter values use the key M+ (or the key next to which is marked DATA. The screen displays the number of data values entered so far.
To get the statistics you must use the keys marked with x bar, n, Sigma x, etc.
Feb 27, 2013 | Sharp el-531x scientific calculator
My TI-84 plus silver edition doesnt allow me to use the comma when using the 1-Var Stats button.. I can't use more then one list and I need the mean of both lists
Pay attention to the name: 1-var statistics mean you have ONLY one list of data. So you cannot use two. However if some data values are repeated you may choose to create a FREQuency list. So at most you have two list, one for the data values and the second for their frequency.
When you use the 1-var stat, specify the list that holds the data value (Xlist) and one the FREQ line specify the list that has the frequency
If your data values are in L1 and L2 or any pair of lists, then you should do 2-var stats. You will get the stats of both lists, you can also perform regressions, etc.
Apr 09, 2012 | Texas Instruments Office Equipment &...
How to i do std deviation and sample mean
Example: Enter the following x variables, and determine the sample and population standard deviations.
x = {1,2,3}
  • Press [DATA] and begin to enter the data as indicated into the L1, L2 or L3 lists. To input a data point, type the value and press [ENTER]. Press the down arrow key to move on to the next data point.
  • Press [2nd], [STAT], and then choose 1-VAR.
  • For the "DATA" option, choose the listname the data is stored in (L1, L2 or L3). For the "FRQ" option, choose "ONE" since this data does not include a frequency list.
  • Arrow down to "CALC" and press [ENTER].
    Answers should be as follows:
    3:Sx (Sample Standard Deviation) = 1
    4:sx (Population Standard Deviation) = 0.816497
  • Press [2nd] [MODE] to exit STAT mode.
Oct 20, 2010 | Texas Instruments TI30XS Scientific...
How do I calculate pH from H+ concentration on a ti 30a? [H+] 1.2 x 10 -5 M = ? pH = 4.9 I worked out pH to concentration but struggling for the opposite figured it out once and...
You calculate the pH with the relation
pH=-log(c) where c is the value of concentration in mol/L.
ex: c[H+]= 3.57x10^(-6)
pH: (-) [LOG] 3.57 [2nd][EE] [(-)] 6 [ ) ]
Here you have 2 change sign key press [(-)]
If you have the pH, and want to calculate the concentration that yields that value of the pH you proceed as follows
c= 10^(-pH)
Ex pH=8.23
c: [2nd][LOG] [(-) 8.23 [)]
General shortcut.
If concentration is of the form c[H+]= 1*10^(-a) where a is an integer between 0 and 14, the pH is equal to the positive value of exponent.
Ex:c[H+]=1x10^(-5) Mol/L then the pH is just the positive value of the exponent, ie 5 because pH=-log(1.x10^-5) =- log1 -log(10^-5)=0 -(-5)=5
Above I use the rule log(axb)=log(a)+log(b) , the rule log(a^b) = b*log(a)and the facts that log(1)=0 and log(10)=1, the last being true if log stands for log in base 10.
May 20, 2010 | Texas Instruments TI-30XA Calculator
What are the steps to solving for pH?
What do you mean by solving for the pH?
Do you have the concentration? if YES, you CALCULATE the pH with the relation
ex: c= 3.57x10^(-6)
c= 10^(-pH)
Ex pH=8.23
Here is a screen capture to show you both calculations
Apr 25, 2010 | Texas Instruments TI-84 Plus Calculator
How to set the value for event log in the registry
If I understand what you are needing to do is to Disable Print Job Notification in Event Viewer for Windows Vista Home Premium
When you are in the registry editor
and at
"System Key: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Providers]
you should have seen and entry, right ?
name type Data
eventlog Reg_DWORD 0x00000000 (0)
To change the DATA value, double click on the NAME Eventlog
A small window will open that says "edit DWORD value"
Value Name: event log
leave this the same, it is not changeable
Value Data:
Change this data to 0
You can go back into the registry to confirm this value was changed, then turn off your computer and turn it back on again.
This should work for you.
Jun 25, 2009 | HP LaserJet 1020 Printer
Nokia phone wont connect to the GPRS
Creating Data Accounts
Steps:
1. Open Services Menu.
2. Open Data Account.
3. Open GPRS.
4. Create/Edit Data Account and enter the following values:
For Globe MMS Data Account:
Account Name: GlobeMMS
APN: mms.globe.com.ph
User Name: leave it blank
Password: leave it blank
Auth. Type: Normal
For Globe GPRS Data Account:
Account Name: GlobeGPRS
APN: http://www.globe.com.ph
Auth. Type: Normal
For Smart MMS Data Account:
Account Name: SmartMMS
APN: mms
Auth. Type: Normal
For Smart GPRS Data Account:
Account Name: SmartGPRS
APN: smart1
Auth. Type: Normal
5. Save the Data Account.
Configuring WAP/GPRS/Internet Services Using the Data Accounts Created
2. Open WAP.
3. Open Settings.
4. Open Edit Profile.
5. Create/Edit a Profile and enter the following values:
For Globe GPRS Profile:
Rename Profile: myGlobe GPRS
Homepage: http://www.globe.com.ph/globe.asp
Data Account: GlobeGPRS (this data account is the one you have created)
Connection Type: HTTP
Proxy Address: 203.177.042.214
Proxy Port: 8080
Username: leave it blank
For Smart GPRS Profile:
Rename Profile: SmartGPRS
Homepage: http://wap.smart.com.ph
Data Account: SmartGPRS (this data account is the one you have created)
Proxy Address: 010.102.061.046
Proxy Port: 8080
6. Save the Profile.
7. Activate the Profile.
8. WAP/GPRS/Internet services now ready to use. In case you encounter errors, double check the Data Account and Profile created. In some cases you need to restart the phone.
Configuring MMS Using the Data Accounts Created
1. Open Messages.
2. Open MMS.
3. Open Message Settings.
4. Open Server Profile.
For Globe MMS Profile:
Rename Profile: GlobeMMS
Homepage: http://192.40.100.22:10021/mmsc
Data Account: GlobeMMS (this data account is the one you have created)
Proxy Address: 192.040.100.020
Proxy Port: 8080
For Smart MMS Profile:
Rename Profile: SmartMMS
Homepage: http://10.102.61.238:8002
Data Account: SmartMMS (this data account is the one you have created)
Proxy Port: 8080
8. MMS services now ready to use. In case you encounter errors, double check the Data Account and Profile created. In some cases you need to restart the phone.
May 06, 2009 | Nokia 5310 Cellular Phone
[Stat] - Data numbers (frequency) < 1 (not integer) on TI 85 Calc
Frequencies are always integers. They indicate how many times that particular data value came up. The data values may be non-integers.
As an example, let's say you're measuring the weights of widgets. You may have 3 widgets weighing 1.1 kg, 5 widgets weighing 1.2 kg, and 2 widgets weighing 1.3 kg.
Note that the data are non-integers (1.1, 1.2, 1.3) but the frequencies are integers (3, 5, 2).
Apr 01, 2009 | Texas Instruments TI-85 Calculator
Computers & Internet Logo
David Payne
David Payne
