Question about Kenmore Elite Oasis 27052 Top Load Washer
At the end of the cycle when the machine goes to spin the machine stops saying DL. I looked it up in my manuel and that means door won't lock. But it was locked the whole cycle until the end. I emptied washer and tried it empty but still wont work and says DL. Do you know what I can try?
  • 15,935 Answers
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 18, 2010
Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
Jun 18, 2011 | Frigidaire GSTF1670A Front Load Washer
Washer goes through cycle, until around 11 minutes until finished it stops, and goes into dL. Will not finish load. What does this mean?
Hi.
the error F/dL means Door Lock Error
The error is prompted when the door cannot be unlocked.
Here possible causes.
Door Latch mechanism broken
Door Switch Assembly defective
Wire Harness from Central Control Unit to the Door Latch or Switch Assembly broken
Central Control Unit (CCU)
Door Lock or Switch temporary failure (it can be reset disconnecting power)
You will probably need to replace the door lock assembly. Parts must be tested first.
Regards.
Ginko
Apr 28, 2011 | Kenmore HE2 Plus Front Load Washer
Will start the wash cycle and DL come on and light blinks and lid lock unlock (Whirlpool Cabrio model# WED6400SW)
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Jul 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Our Kenmore Elite HE3 Model prefix is 110 stops during the rince and spin cycle,beeps, and desplays F dL or F 11. The door light is not on, but the door is locked. We were able to start and complete the...
wash another load and see what happens the f-dl code means door lock problem and f-11 means communication error between top control board and the bottom control board if you can wash a load completly everything will be ok but you can't let me know and we see where to go from there
Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
Error message of f dl on kenmore washer model he 4t
does your washer stop on spin cycle some time. your is 4/5 years old?. f dl means door lock system is bad but i don't think so. do you have other error code beside f dl if yes then i think your washer need new main control board.
May 24, 2009 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Wash cycle stops with 1 min left and clothes are sopping wet
dl mean door lock system fail. may be lose connection on your door lock or control board.
May 23, 2009 | Washing Machines
Get DL ...F ERROR CODE
hi,
Error dl f --
Condition:
Door Lock Error-
Check/Repair:
1. Door Lock Mechanism broken or removed from the Door.
2. Check Door Lock/Switch Assembly.
3. Check the wire harness connections to the Door. Lock/Switch Assembly and Central Control Unit (CCU).
4.Door Lock/Switch Assembly Failure.
good luck....
Mar 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer wont engage
The door may not have been fully closed. stop/clear cancel the cycle. ensure door is fully closed and attempt to resart cycle.
F/dL Door Lock Error
  • Door Lock Mechanism broken or removed from the Door
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Feb 08, 2009 | Kenmore HE2 Plus Front Load Washer
F11 and f dl errors
I hope that you have a serivce contract or something on this unit you need a main control board f11 means that there is communication error between the 2 computer boards the fdl means that there is is door lock problem. But that is incorrect that is how you know which board has the problem the door lock is controlled by the main computer board. it's just playing tricks on you I have tried changing the door lock with those codes and it did nothing. that board tends to be alittle pricey .good luck.
Dec 24, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Kenmore Elite Oasis 27052 Top Load Washer Logo
142 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
