Question about Scientific Explorer My First Chemistry Kit
I have a doubt whether that in presence of tap water or salt water or air the nail gets rusted fastly
    Scholar:
  • 32 Answers
The short answer is Yes, it does. The reason is, because "salt" (NaCl) is a strong electrolyte, which facilitates the flow of electrons in a naturally produced mini-circuit on the surface of the nail, which is in contact with both air (oxygen) and moisture (water).
The "mini-circuit" mentioned above is the consequence of the kind of reaction (oxidation and reduction occurring simultaneously, called a redox reaction) that an uncharged metal atom (like iron, Fe) can undergo because of its ability to lose its valence electrons (loosely held) that normally move around the outermost orbital of its nucleus. This kind of electron transfer spontaneously occurs (i.e., by itself without any outside help) only if the iron is able to come in contact with an atom of another element, or the ion of that other element (which can be a metal or not), that has an attraction for electrons (standard reduction potential) that is stronger than the attraction of electrons by the iron. For a more detailed and technical explanation, please see my "Solution 2" for this problem.
What's salt got to do with all this?
An electrolyte (pronounced, electro-lite), is so-named because it is a substance that can conduct electricity (electric current). Strong electrolytes (salts) dissolved in water, melted (molten) electrolytes (in absence of water), and pure metals are good electrical conductors*. What makes a strong electrolyte able to conduct electricity is its ionic nature, that is, its being made up of ions, which have charges. When NaCl ("salt") is dissolved in water, it immediately breaks up (dissociates) into its constituent ions (Na+ and Cl-). It's these ions that make the solution a good conductor. So, the more ions in aqueous solution, the more effective the solution can support the flow (transfer) of electrons (current) that are involved in the type of reaction (redox) occurring in the rusting of a nail.
*Exactly how these substances are able to act as conductors has been described in complex theories, but most chemistry textbooks omit them, except for how metals behave as conductors - see more about this using the key search term, electron-sea model, a very well developed theory of metallic bonding. Probably, one of the most essential characteristics of a good conductor is the mobility of its charged particles. For example, though a solution of ions is a good conductor, the pure solid form of the same electrolyte behaves as a non-electrolyte! So, it is reasonable to deduce that when an electron contributes to an electron current going through a solution of ions, it hops a ride on those charged particles, or that the very rapid collisions between them are very effective in allowing virtually instantaneous net electron movement across them.
You also asked about the effect of tap water. See my Solution 2 for this problem.
Posted on Jan 09, 2011
  • DubbleA Jan 10, 2011
    For a more theoretical and detailed explanation of about how the mini-circuit is formed from the reaction of the iron and air, and how water (tap and pure) and salt are involved, please feel free to post another question requesting it.
How do I soak using hot water?
Epsom salt can also quell foot odor, help heal fungus or ingrown nails, and soothe dry skin. You'll find this healing salt at most **** stores and pharmacies. In a standard size tub, dissolve one cup of Epsom salt in warm water and soak your feet for 10 to 15 minutes.
Apr 10, 2017 | Washing Machines
Hi, i replace the thermostat and water pump flashed the radiator has coolant but still overheating, what else could it be its golf 4 tdi diesel 2002. Thank you
Radiator may have rust/salt deposits inside, if that is case its cheaper and better to change the radiator. Also for future don't use normal tap water in radiator, use a coolant + ph balanced water meant for radiators to reduce salt buildup inside radiator.
Also check the radiator fan is working ok and rotating in the right direction, sucking cool air inside not blowing out hot engine air to the radiator. Some electric fans can have wires mixed up so they start in the wrong direction. (make sure fan is sucking cool air outside towards the engine).
In some cars, radiator fan has a top cover that stops hot engine air getting sucked by the fan, if your car has it, make sure it is fitted properly and is in good order.
Some cars have a fan fitted on the AC condenser, make sure this fan is working as well.
Oct 01, 2016 | Cars & Trucks
If you put your hand in plain white flour after a burn, will that prevent burning and blistering?
No. no no and no. Flour will temporarily stop bleeding but should NEVER be used on a burn. Mild burns should be held under cold running water for a few seconds. carefully dried and sap from an aloe vera plant. Then covered to keep out air and germs. Blistered burns should always be covered with a clean cloth and medical dought . And never puncture a blister. It helps to keep the wound clean. Cover it ligtly and seek medical aid.o
Sep 18, 2014 | Kitchen Appliances - Others
Dropped elph camera in ocean while kayaking In and out fast. Ca photos be saved. The battery was NOT inside.
The salt water is the big worry, if the photo's were on the removable memory card you might have a chance, if the photo's were on the internal memory "game over" I will assume the pictures are on the removable card, gets some rubbing alcohol and Q-Tips now carefully clean the contacts and the switch on the card. Salt is extremely corrosive when combined with water so keep in mind that this will be a long shot and time is a factor, "good luck"
Mar 14, 2011 | Canon PowerShot A560 Digital Camera
Lost directions for using my Sisan Steamer. I have the water measure but don't know how much salt to add. Can you help?
The measuring cup holds 1/4 cup. Fill with tap water and pour one full measure into the hole exposed by removal of handle. Then measure table salt into small hollow on handle. Next, pour two (2) full measures of salt into a second measuring cup full of water, and pour into Sisan. Never use more salt than will fill the measuring hollow in handle. Remember that should the steam cease, unplug and refill with two measures of tap water, but no more salt.
Maintenance:
Add one (1) teaspoon white vinegar to two measures of tap water, put it in the Sisan Steamer and let it run a few minutes. Then pour this out of the Steamer and rinse well to scale the inside.
Nov 17, 2010 | Kitchen Appliances - Others
We used the camera in the ocean first time 10 days ago. We did not wash it afterwards. Was working fine till today. The lens wont open. The camera is dead. It does charge. HELP!
Unfortunately you have effectively destroyed your camera. Salt water is up there with fire and crushing as the absolute great unrepairables when it comes to assessing damage. Plenty of owners can and do repeatedly get away with what you failed to do, but you only need to be unlucky once.
Your camera is designed to be waterproof down to 10m (33') for up to one hour, but as with all such devices it must be thoroughly rinsed in fresh water after each exposure to salt water and then left well ventilated to dry. The user manual also clearly states this and gives particular instructions on the way to do so with slight differences depending upon whether the camera has additionally been exposed to sand or soil. A further preventative measure to protect your camera is to have the seals replaced at least annually as recommended by all waterproof camera manufacturers.
If the camera is not rinsed then salt crystals and/or rust form (stainless steel isn't totally immune to rust, and rust can form extremely quickly, especially in salt water). Whether it's salt cystals or rust the effect is the same as they will both tend to shift the waterproof seals slightly and allow water inside. It only takes a tiny drop of saltwater to get inside where, once trapped, it will gradually deposit corrosive and conductive salt traces which effectively destroy the electronics. Once it's in there the only slight chance of a fix is to remove the battery and memory card and then flood the interior with de-ionised water, but this has to be done immediately to have any chance of working. Your camera has now been left too long and so the damage is irreversible and in any case I know of no owner (myself included) who would have dismantled an apparently working camera to flood it with water unless it was known for certain that water had got inside.
Unfortunately your only fix is to replace your camera and to learn from your expensive mistake. I know of no professional repairer who will even attempt a repair to a flooded digital camera; there are simply too many expensive parts which must be replaced and there's too much chance of subsequent ongoing corrosion if even the tiniest mineral deposits remain in the camera.
Sorry I cannot offer you a more positive outcome, but I hope that you now understand why rising is vital and that my advice saves you from repeating the error.
Please take a moment to rate my reply, or if you have further questions regarding my answer then add a comment and I shall respond as soon as I can.
Sep 14, 2010 | Olympus Cameras
12500 gal pool began by adding 8 \ 40# bags of
Drain this pool, give it a good cleaning and start over. Clean the electrolytic cell. Your 24" x 52" size pool holds 12,481 gallons of water and requires 310 pounds of salt at initial startup. You should set the timer to run 11 hours per day. If the low salt light comes on add 85 pounds. You need an owner's manual. You can download one here. http://pr-rp.pmra-arla.gc.ca/PR_SOL/pr_web.ve1?p_ukid=5143
Jun 01, 2010 | Intex Automatic Salt Water System for ...
Water is leaking onto back seat from both sides on a v reg pug 406 , the seals seem fine and i`ve just cleaned them will see what happens but any more info on this problem will be grateful
This could be coming in from a few places. As well as checking seams, i would suggest checking your floor pans... Many times rust will slowly eat thru the floor pans, and allows water to be soaked up... Get the car up in the air ( or climb on under it). Tap on the "floor" from underneath where the rear Foot area would be. If it seems rusty or weak or you can see visable damage. this could be your culprit, even if it isn't rusted through completely. This is a very very common problem with cars in my area , as I live in northern USA. Alot of snow = alot of salt on roads = alot of rusty floor pans :)
This could also be coming from your B - Beams. When your tires displace water. it splashes them against the inside wheel well and tire guard.. Under that guard lies your car body. If this has rust in /on it that has penetrated all the way through, the water is getting thrown "into" the body panels, which is leaking through to your seats. Hope this gave you a little more information on places to look.
Feb 27, 2010 | 2006 Peugeot 604
Scientific Explorer My First Chemistry Kit Logo
205 people viewed this question
Top Scientific Explorer Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Scientific Explorer Toy Expert? Answer questions, earn points and help others
