Question about Nintendo Wii Console
My wii will not turn on no lights nothing after a fuse fliped in my fuse box that my wii was pluged into what can i do?
  • 2 more comments
  • johnny miller
    johnny miller Aug 26, 2010
    isnt there a fuse in the wii. my fuse box tripped not the wii.Im guessing the fuse in the wii triped and needs to be fliped back. how do i get to the fuse in the wii?
  • johnny miller
    I got the most obvious answer that was not help full. My wii fuse was tripped when my girl friend turned off the fuse in the fuse box in my hall way. Now it want turn on
    my wii will not turn on no lights nothing after a fuse fliped in my fuse box that my wii was pluged into what can i do?
  • johnny miller
    thank you . Were both on the same page but how do I get to the fuse in the wii?
  • johnny miller
    Not what I wanted to here. But thats what i was afraid of. Thanks for not suger coating the answer . Later and Thanks again.
    Genius:
  • 1,035 Answers
Hi. Have you tried plugging in the Wii console to other wall socket?Have you tried checking the fuse or try replacing the fuse.
Posted on Aug 26, 2010
  • 11,800 Answers
The fuse flipped because there was a big current thru it. Since the only thing that was powered thru that fuse was your Wii that means it was the one that caused that. The only way a Wii would draw so much power is when its power source is shorted - your Wii has failed. If you take it to a repair shop they might be able to fix it - but i doubt it it, at least not for a reasonable price.
Your console is dead as a dodo, junk it and buy a new one.
  • 6,993 Answers
its obvious that the fuse is the cause of the problem, since it was working before the fuse flipped.
Do a fuse replacement and your WII should turn on again.
Take care.
  • Walesarumi
    Walesarumi Aug 26, 2010
    i just hope the fuse that flipped hasn't affected the power board of your Wii. The wii certainly has a fuse and you will have to open the wii in order to gain access to the fuse inside it.
    The this problem is a power related fault. So go ahead and check the fuse on the power board of your wii.
    Also, don't overlook the AC adapter. Maybe the AC adapter is defective, that's why it not powering the wii. I would advice that you borrow a wii adapter and test with your wii. test the adapter before checking the fuse inside the wii
    Good luck.
Not powering up
It could be the fuse in your power plug box. My fuse blew in mine when I went to Switzerland I just bought a cheap one on ebay for around 9 bucks at the time that'll work over seas as well. If you have a friend with a wii try their power cord on yours.
Oct 31, 2012 | Nintendo Wii Console
Console will not turn on. pluged it into different outlet still no power.
there could be a ripped fuse. perhaps an animal chew ed on it. happend to my wii sensor bar.
Jun 29, 2010 | Nintendo Wii Console
We can't get our wii to turn on. Our electricity went out this morning for just a second, but the wii was not on. But, now it won't come on at all.
Try a diffrent outlet or check your Breaker box and see if the breaker got fliped.
If that dosn't work make sure all the wires in the back of the console are plugged into a working electric socket on the wall. If it's still not working, contact Nintendo Hardware Issues Department and they'll be sure to send you a new one (although it may take up to a couple weeks).
Jan 17, 2010 | Nintendo Wii Console
The wii console its not turning on !!
Make sure the batteries are not dead in the controllers for turning it on.
Next, check all plugs on the console to make sure theyre pluged it all the way if any. Try it again, if it still doesnt work, check to see if your warranty expired yet. Most likely it hasnt. Next call nintendo for support and see if you may have to ship it in. Whatever is wrong with it right now, is nothing that cant be fixed or replaced.
You can also try using a different power adapter to see if thats the problem. If its not turning on, or no lights are, obviously not enough power is getting to the WII. Sometimes the fuse in the power adapters plug in can blow, check that and replace it if needed.
Dec 23, 2009 | Nintendo Wii Console
Lights on my wii guitar keep flashing constantly
try pressing the button on the little white box with the usb cord that connects to the wii
Jun 13, 2009 | Nintendo Rock Band for Wii
Wii will not power on
Apr 13, 2009 | Nintendo Wii Console
Wii new out of box not working
have u checked to make sure ur on the correct channel also u have to make sure all USB cables are connected to the same area
Dec 25, 2008 | Nintendo Wii Console
Trying to connect nintendo wii to philips tv
If I have the right manual you should connect the wii cable from the package to th backside of the tv. You will see four pluges. Choose with VGA you want to use, this is not important. Use the cable from the wii and plug in two of three pluges, you must match te coulors. If you have a cable box installed you will probably have scart (a big cable with a large head) connect this and it would run smooth. You can also connect the three pluges from the cable to your cable-box, use the red, wihte, and yellow pluge.
Dec 25, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Trying to connect nintendo wii to philips matchline tv. the model no is : 42FD9944/01S
Nintendo Wii Console Logo
391 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
