Question about Cell Phones
I put in a 3 sim in a lg phone which originally had a vodafone sim in it and it just says usim locked and theres no button to unlock it
How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:". 7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG Prada (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security
Jun 06, 2014 | Samsung Galaxy S GTI9000 Smartphone
Unlocking the usim and then phone
Better get LG customer service
Oct 02, 2017 | LG KF750 Cellular Phone
I've an kp500 lg cellphone which is locked to vodafone, germany. I'm currently in Venezuela but i can't use the phone. When i insert a sim card its indicates unlock USIM. Pls, I need solution to this...
As you have mentioned, your lg kp500 cellphone is locked to vodafone in germany. It is clear that you cannot use the same cellphone anywhere else.
If you need further, please contact me.
Oct 15, 2010 | LG Cell Phones
I have a viewty ku990 v1.0 locked on orange, when I put the sim in it come up with inactive usim. I would like to unlock my phone so I use my old o2 sim.
To remove usim locked you need to get unlock code. You can get unlock code at www.FastGSM.com
They can supply unlock code for any LG. Once you have it you just type unlock code via phone keypad.
You MUST have sim card from network phone is locked to to be able to access phone menu! Without such sim card do not purchase unlock code.
Feb 12, 2010 | LG KU990 Viewty
Usim Locked Lg Veiwty
You just need to unlock your KU990 and then you will be able to use the phone with different network.
To purchase unlock code visit FastGSM KU990 Page
You must have sim card from network the phone is locked to. This is essential! Without the sim card you can not access phone menu and type the unlock code.
Jan 17, 2010 | LG KU990 Viewty
USIM locked for KP501 solve now I bought my phone in England so now I need my USIM
your phone is network locked. You can buy unlock code for LG at FastGSM. Please remember you need original sim card phone is locked to, to be able to enter unlock code!
gsmwong
Oct 21, 2009 | LG U880 Cellular Phone
Lg kf700 wont accept any sim cards,
it sounds weird that it worked before with same sim card. Generally USIM locked message means phone is locked to network and you need to unlock it with network unlock code to remove USIM locked and use phone on different network.
gsmwong
Aug 17, 2009 | LG KF700 Triband 3G HSDPA 3MP A2DP Phone...
LG U990 USIM locked
2. Press telephone icon at bottom of screen to bring up the phone keypad.
3. Enter 2945#*990#
4. A menu will pop up, select sim unlock
5. Enter your unlock code and press ok
6. The phone will then reboot and the unlock is complete.
Try this, this may solve your problem.
Aug 16, 2009 | Audiovox SMT5600 Smartphone
UNLOCKING USIM
my LG CEO168/KC550 previously a contract phone with virgin i have put a pay as you go virgin sim in it but its telling me emergency calls only help
Jul 20, 2009 | LG CU500 Cellular Phone
I need unlocking lg u890
i had a lg u890 mobile phone that i got unlocked but it had the same proble where i swithched on my phone it used to ask for the usim code..my old phone was locked to the 3 nt/wrk i got it unlocked so i could use my 3 nt/wrk sim card or any network simcard but i used vodafone 3g sim card.the code i used with my vodafone 3g network simcard in phone when switched phone on & it asked for usim sim code i inserted code i got & it shut the phone down then on again then it wld work with vodafone no bother at all it even came up with vodafone uk etc.but i had to reconfigure the sms/text telephone number aswell as reconfigure the mms settings & numbers etc aswell as reconfigure wap settings from 3g network to vodaphones.but after i got it all unlocked & settings changed etc & inserted a different 3g network simcard ie vodaphone/orange/o2/3g sim/t-mobile/tesco sim/virgin sims & switched phone on it asked for usim code i tryed the code i have & inserted the same code i have it/they switched phone off & then back on & all network usim card worked with no problems at all.the code i have is.>>> 142358#*# thats 142358# * # all 1 item/action.once you insert that 142358#*# thats it your phone will shut down then restart up & go onto the network usim card you want to use or inserted before using code.but 1 thing tho please remember if u switch off your phone or your phone switches off as batterys run out no power u will need to insert the code again.& another thing code wont work if your phone switches off or you switch it off & plug your mobile battery charger into phone to charge your battery up on the phone & you switch you phone back on when you are charging your phone as the phone will switch on & say insert usim code if you enter the code the phone will switch off & back on again but it will still request usim code.so you will have to wait unto there is plenty of charge in the battery to take phone off charge & swithch your phone on get the usim code message insert code above phone will switch off & straight back on again & then it will go onto your prefured usim card then you can plug your charger into phone again to charge phone up.you can use your phone on charger when u have entered usim code & it switched off & on again & registered with the prefered network.i hope this is of use to you as it is to me.if you try this code & either if it works or not please can you let me knows ty.email watsonwhizzy2001@yahoo.com
Oct 07, 2008 | LG enV VX9900 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
