FixYa.com
Tags:
Macromedia Flash MX
Macromedia projector error (by 5 users)
posted by budds59855 on May 06, 2008
This csi,crime scene investigation,pc game,the game installs and when i go to play this error comes up,any clues,ty
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by Guest, posted on May 25, 2008
My flip video starts up as expected, then as movies are being loaded I get the error message that it has to close
Comment by lizod007, posted on May 20, 2008
i've been using nero photo show elite for years importing pictures from my hp flatbed scanner.recently had to replace computer with vista system.got upgrades for my hp scanner and it would work a few times then i would have to reboot to get to work again.decided to get rid of old fax,printer scanner,copier and get an all in one machine.i imported one picture from the new vista ready machine and no matter what i do i keep getting the same message.it will pre-scan but will not import.thank you,robert
lizod007@cox.net
Comment by CABSH, posted on May 18, 2008
Other users with "identical" Active Directory profiles can run the TTaps program on teh same computer without problems... GPF is restricted to one user only (on any machine in the group).
Comment by Guest, posted on May 08, 2008
I get the message on TTAPS which uses macromedia.
Projecto caused a general protection fault in module TTAPS.EXE
Best Solution
posted on May 31, 2008
Helpful (85)
clayboi
Rank:Apprentice Apprentice
Rating: 85%, 2 votes
I had the "macromedia projector" error with the CSI game. This worked for me:
1). Open “QuickTime Preferences” (right-click the “QuickTime” Q icon in lower right corner of Windows taskbar).
2). From “Browser Plug-in” tab, click the button labelled “MIME Settings…” then click “Use Defaults” and hit “Ok”.
3). Now go to “Video Settings” tab and choose “Safe Mode (GDI only)”. (Note: QuickTime versions 7 and above, make sure “Enable Playback of Adobe Flash tracks” is also checked).
You should now be able to run the game without errors, good luck.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Graphics Publishing and Multimedia Software problems?
Macromedia Flash MX (FLM060D000)
macromedia flash 8.0
can u tell me hoe to give a... Answer This...
getUrl syntax probelem
I use "getURL" syntax... Answer This...
setting custom volume control...
how to set the volume control... Answer This...
input textbox
Hi, I am Mahesh .how to a... Answer This...
back previous button
I want to make back previous... Answer This...
Repair Service
Find Graphics Pub. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
