Question about Lexmark Optra S 1855 Laser Printer
I am getting a 922 service fuser error on my lexmark optra s 1855
    Genius:
  • 1,087 Answers
922 Fuser Error message indicates that the fuser unit failed to reach the standby temperature. This usually requires a service call but try to turn off the printer for 30 seconds before turning it back on to give the engine board a chance to reset. Make sure the printer is plugged in straight to the power outlet in the wall. Bypass any surge device or power strip as they can cause low amperage. If the problem continues or if the error appears every time the printer is powered on, you will probably need service on the machine.
Posted on Aug 26, 2010
SERVICE PRINTER ERROR: 934 ON LEXMARK OPTRA S 1620
These error codes indicate a problem with the mirror motor circuit
in the printhead assembly or the mirror motor cable to the engine
board cable or engine board assembly.
The mirror motor cable or engine board would possibly needs to be replaced. Please contact our technical support team for assistance.
Sep 24, 2012 | Lexmark Optra S 1620/1625/1650/1855 Fuser...
LEXMARK OPTRA T614 REMOVING FUSERS
If your fuser is actually getting hot, then it is likely the temp sensor. It looks like a mylar pad that should be rubbing (in direct contact) with the teflon roller (the hard grey one, not red rubber). The sensor could be bad, or, if it is not being held against the teflon roller, then the clip has broken. If the fuser does not heat at all, then you have either a bad low voltage power supply, a blown fuse, or burned out quartz lamp (goes through the center of the teflon roller).
Jan 20, 2012 | Lexmark Optra T614 Laser Printer
922 service fuser
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $300, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
Nov 09, 2010 | Lexmark Optra S 2455 Laser Printer
900 service rip software error on our Lexmark Optra S1855 what does it mean? How do I fix it?
These errors indicate an unrecoverable engine software
error. Replace the engine board is the only solution
Apr 07, 2010 | Lexmark Optra S 1855 Laser Printer
I am getting a 922 Service Fuser Error what does that mean?
a 922 error means that the ac circuit is open. this is the heat lamp circuit. a burned out bulb, blown thermal fuse, or pitted contacts will be the cause. replace the fuser and your back up and running
Oct 06, 2009 | Lexmark Optra T610 Laser Printer
Lexmark optra s1855 makes knocking noise when printing envelopes from the mp tray
this noise is usuallt cause by a flat spot on the backup roller of the fuser remove the fuser turn it by hand if you feel a flt spot when turning replace the fuser
Sep 23, 2009 | Lexmark Optra S 1855 Laser Printer
Swap parts between Optra S 1255 and 1855
I can say for sure that these parts do not translate. The service manual says.
Jun 09, 2009 | Lexmark Optra S 1855 Laser Printer
I am getting a 922 fuser error on a Lexmark laser printer.
Hello. My dad had the same problem with his lexmark printer and he took it to a repair place where he was informed it is a problem with some part of the mother board causing the info from the computer to not be read by the printer. Long story short... is cheaper to buy a new printer than to fix the problem. He was also told this problem occurs in many lexmark models. Hope this helps you.
Mar 24, 2009 | Lexmark Optra S 1855 Laser Printer
My Lexmark Optra S 1855 is showing a fuser error. What needs to be done?
the fuser needs to be replaced its about 200 dollars just search for Fuser for the model of your printer
Thank You John C
Mar 03, 2009 | Lexmark Optra S 1855 Laser Printer
ERROR
921 Fuser Error Indicates that the fuser is below standby temperature when the printer is idle.
Error codes 920, 921, and 922 may display for a cold fuser failure. A 920 error caused by low line voltage can sometimes be cleared by turning the machine off and then on again.
Service Tip: Set the Fuser Temperature to NORMAL before starting this service check.
Manually spin the fan and check that
it rotates freely. Check the cable
connection to the engine board, J13
for correct installation.
Jan 23, 2008 | Lexmark Optra M410 Laser Printer
Lexmark Optra S 1855 Laser Printer Logo
291 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
