I do not have any power in the tv. It will not turn on and the sleep(red) light on the front is not on. there is power going to it but it will not come on. It is a sharp palsma screen. I believe 20 inches
  • boohdaboo Jul 05, 2008
    I press the power button and the light comes on then off then back on three times and then I can't do anything for 5 minutes. But it's only to do the same thing again since it wont come on. It kind of happened before, but it came on after a couple times. Is it the power supply? And do I need a new TV.
  • cris1surf Oct 14, 2008
    I have a Mitsubishi WS-65905 HD TV. When I try to turn on the set it does not come on. Nothing turns the TV on, I tried both the remote and than the on and off button from the tv control panel with no success. Does anyone know the problem solution to this annoying concern, or is anyone familiar with the power issue for this specific model...? Your help is appreciated, thank you.
    Cris
    Problem Solver:
  • 14 Answers
You're standby power supply is not running
Posted on May 06, 2008
SANYO LCD 24K40 TV instead of Red or Green the power indicator display Amber color
press the helpful button,
the amber light may be for stand by or sleep mode, go into your tv setup and check that these are turned off
Jan 12, 2016 | Sanyo Televison & Video
Wont turn on
Yes that is an error light. If you give me a minute I will try and get you more info on your tv.
Thanks,
lee
Jun 21, 2008 | Sony KP-53S35 53" Rear Projection...
The tv will power off all by itself and then it may or may not turn back on. If it does turn on, it will be on for a short duration then shut off. The interval in between being on has become shorter over...
Try pressing the Menu button and selecting the Sleep timer. You should be able to disable it from the menu choices. The timer may have been activated during a storm or from a power surge. If this doesn't fix it try putting a piece of black tape or duct tape over the "IR eye" on the front of the panel - you may have a bulb or some other source of Infra red that's telling the TV to go to sleep.
Sep 10, 2011 | Vizio E370VL 37 in. LCD HDTV
Toshiba 61PJ7UA, turn itself off and will not start. Power on light is red but when you hit the remote to turn TV on it clicks but dosent turn on(no green light). I have the circuit boards (particularly...
HERE'S THE ANSWER TO YOUR PROBLEM:
I think the problem has nothing to do with your TV. I bet the culprit lies on the setting of your remote control. Maybe you set your remote into a sleep mode. When a TV has set into a sleep mode. It's power on light is still red but doesn't work. So all you've got to do is keep pressing the sleep button. After a few presses, it will definitely work. And, you can now enjoy your day watching TV. Thanks.
Jul 10, 2011 | Televison & Video
Ilo LCT32HA32 tv wont turn on, no red standby light
It could be the power or main board that is giving issues...if your able pull the back off and look for a pin on connector marked PSON or PON...that is line that tells the power board to come out of sleeping and go to work, you should see a change in the voltage when the on button is pushed, if you do then the main is doing its work and its the main if you don't see a voltage change then chances are its the power board
Dec 14, 2017 | iLO LCT32HA36 Television
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
May 08, 2009 | Emerson SpongeBob SquarePants TV
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Pioneer sd532hd5/kuxc/ca powers down on its own
Could be a few things.First check your sleep timer.Sounds like a fail safe mode that when the tvs left on accidentally it shuts itself down so it wont overheat and die prematurely.The last resort is to remove the circuit board and carefully inspect the solder joints near the power supply with a magnifying glass and a bright light.Then resolder those.
Nov 09, 2006 | Pioneer PRO-100 TV
Televison & Video Logo
Top Televison & Video Experts
