Question about Onkyo TX-SR605 Receiver
Zone 2 cut off on onkyo
My reciever cuts out everytime I turn on zone 2 on my onkyo tx-sr605. we have checked our connnections and everything seems good but could we be missing something?
    Sergeant:
    Champion:
  • 319 Answers
Your program source may not support a 7.1 format. Try switching to 5.1
Posted on May 07, 2008
I have the Onkyo TX-SR605 system. My Zone 2 used to work and now it doesn't. I tried to activate it under the Hardware Setup, but Zone 2 does not show up. Any suggestions where else it can be found
Hello, When you say Zone 2 doesn't show up do you mean that its not there at all, or is it just greyed out? I would suggest a reset of the unit it seems as though either way it could be a glitch. Thanks, FJD
Mar 28, 2016 | Onkyo TX-SR605 Receiver
Tip
Onkyo TX-SR605 Remote Codes
Download Onkyo TX-SR605 Remote Codes
4 Digit Onkyo Remote Codes
Models: RC-682M / TX-SR605 / TX-SA605 / TX-SA8560
Have you misplaced your Onkyo TX-SR605 Remote code list / Owners Manual?
Would you like a digital, searchable, pdf version of the Onkyo TX-SR605 Universal Remote Code List Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
_________________________________________
Download Onkyo TX-SR605 Users Manual Here.
on Apr 20, 2010 | Onkyo TX-SR605 Home Theater Receiver 7.1...
Tip
I hope that helps.
on Apr 20, 2010 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 cannot get Zone 2 to work on any setting other than FM Mode
Have you assigned the zone 2 configuration to the device that you want to play on zone 2?
This is part of zone 2 settings.
Otherwise the problem is with the amplifier circuit and will need replacement.
If the unit is not more than 3-5 years old , then depending on where you are there is a factory warranty.
Check with your Onkyo service centre before touching the unit.
Mar 19, 2011 | Onkyo Audio Players & Recorders
Zone 2 must be on to hear zone 2
there are 2 ports for sub woofer, try using the other sub port.. I dont have to use zone 2, and not sure it even has a zone 2 sub port.... I use zone 2 for a cd player and speakers on the deck.. no sub woofer
Jan 02, 2009 | Onkyo TX-SR605 Receiver
Receiver keeps turning off after I turn it on.
CHECK THAT YOUR SPEAKER CABLES ARE NOT TOUCHING.ALSO DID YOU NOTICE THAT THE SPEAKER CONNECTIONS ON YOUR 605 ARE SIDE BUY SIDE NOT ABOVE EACH OTHER?
Jun 02, 2008 | Onkyo TX-SR605 Receiver
Code for the onkyo tx-sr605
Try 1789. I just set it up it seems to work.
Jan 03, 2008 | Onkyo TX-SR605 Receiver
It keeps shutting off
If you have zone 2 active with the level turned up too much it will cut out the whole unit. Try disconnecting zone 2 speakers, then turn the volume level way down on zone 2 and it should stay on if that is the problem.
Jan 02, 2008 | Onkyo TX-SR803 Receiver
Brand new Onkyo Tx-sr605 won't leave stand by
If the unit will not leave standby I would remove all power, disconnect *all* connections at the back, reconnect to a power source and try powering on. This will eliminate any connection causing the Onkyo to stay in standby due to a short. If it still will not enter power-on mode, you may want to look at the power source (is it properly grounded?), but beyond that the unit probably needs to go back.
Nov 03, 2007 | Onkyo TX-SR605 Receiver
Subtitle Problem: Onkyo TX-sr605
The only remote that will definitely turn the sat subtitles on/off is the sat remote. The other subtitle buttons on the other remotes refer to the DVD subtitles and the subtitles generated by the tuner in the tv. The subtitle option is greyed out on the tv because you are not on the tv tuner.
Sep 03, 2007 | Onkyo TX-SR604 Receiver
Onkyo TX-SR605 Receiver Logo
279 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Dennis McCollum
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
