Question about Microsoft Office Professional 2007 Full Version for PC
Problem installing office 2007.
When I attempt to install Office 2007 I get an error message- error 25004.config.Xml not specified; A valid config.xml file must be authored when deploying '(null)'. What does this mean? Have tried to reinstall Office 2007 Teachers and students upgrades several times have office 2003 installed works OK.
Have same error 25004 as Gatorguy
    Genius:
  • 3,422 Answers
You need to uninstall any pre-release version of the Microsoft Office 2007 system .
it seems that if you have a version of the 2007 Microsoft Office Add-in or Microsoft Save as PDF or XPS installed, this may be the culprit. In both cases, by performing an uninstall on this add-in via the Control Panel, and then installing Expression Web, everything works okay. You can even re-install the Office 2007 add-in when you're done.
Goodluck,
Please don't forget to rate the solution
Posted on May 06, 2008
  • 3,037 Answers
Alright download "Your Uninstaller!" and use that to uninstall the remainders of Office. Download HERE
Reboot into safe mode and delete the folders....defrag, reboot normally and see if you can reinstall it now. You may need to register it again, so hope you have the key.
Let me know if you are still having this problem and I will get you through it.
  • Benjamin Patri
    Benjamin Patri May 07, 2008
    Please don't forget to let me know your thoughts about my solution.
    If your problem is fixed, please rate this solution as that is one of the biggest
    aspects of how this website works and in order to receive any credit in
    helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to help.
    Thank you
  • 156 Answers
Ok just run the windows installer cleanup wizard and after re-install.
Article can be found at microsoft click here.
    Brigadier General:
  • 6,966 Answers
To my knowledge this error would only occur if:
1. there was a prior version (Beta) of Office 2007 installed. Of course the solution would then be to uninstall the old version, clean the registry for any instances of the old version and do a clean fresh install;
2. a version of the 2007 Microsoft Office Add-in: Microsoft Save as PDF or XPS was installed. This could be corrected by removing this add-in through the Add/Remove Program(s) in the Control Panel.
3. any other program/application is causing conflicts.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role May 06, 2008
    Sorry mrsno, seems we are on the same track and failed to do a refresh before posting.
  • Louie  Role
    With indulgence of the others...
    It would seem that Microsoft is aware of some issues as you have described, you might find this informative.
    Sergeant:
    Novelist:
  • 166 Answers
Hello there.
If you have previous versions of MS Office 2007 they must be uninstalled prior to installing a different version. Please try this first and report back.
Hope this helps.
Error 25004.config.xml not specified
Hi chisge,
Try running all the Fix it tool from this link:
support.microsoft.com/kb/971179
After that, try installing Office again.
Nov 19, 2012 | Microsoft Office Standard 2007: Windows
Error 25004.config.xml not specified; A valid config.xml file must be authored when deploying '(null)'. i am installing microsoft office enterprise 2007 and i enounter this problem..how will i
If the version of windows installed on your computer is not activated you would face issues to use any applications once the product is expired.
But if you have an issue with office programs with an error 25004 on an activated version of windows
Then the reason might be corrupted installation of office 2007 on the computer.
Uninstall office 2007 manually from the computer then
re-install it and check if it helps.
Apr 25, 2012 | Microsoft Office Professional 2007 Full...
Ref Office Enterprise 2007. Tried to install from a DVD. Install would not complete. Tried to uninstall; but however much may have installed will not uninstall. System told me to reload/install DVD...
download this program to remove the software completely. The name is "revo uninstaller" the program will remove every vistage of the program. here is the link, it is safe use it myself.
http://download.cnet.com/Revo-Uninstaller/3000-2096_4-10687648.html
Oct 11, 2010 | Computers & Internet
Office 07 won't work on Vista
been there, have you tried getting it out from safe mode, if that dosen't work there is a utility called unlocker, here
http://ccollomb.free.fr/unlocker/
Iuse it when things like that happen, it will unlock it. But try safe mode first
Dec 21, 2008 | Microsoft Office Professional 2007 Full...
My Office 07 will not open, so I was going to try to uninstall it and reinstall it, but when I go into Control Panel to uninstall Office 07 a window pops up saying, "This product installation has been...
Try renaming the install directory. Normal install is located C:\Program Files\Microsoft Office\Office12. Rename office12 to office12bak (just in case you need to put it back again). This will normally allow you to reinstall office again.
Unable to install ms office 2007, upgrading from Office 2003
please first uninstall all the existing versions of MS Office. Then try to clean temporary files, cache and registry using tools like cCleaner (freely availavle), then install MS Office.
if you want to install only MS Office 2007, no need to install MS office 2003 and upgrade. directly install MS Office 2007.
If you want to keep both, pleas install MS office 2003 first, then MS office 2007, please dont uograde it, rather select Keep both version.
Please make sure that you have admin permission before doing all this and your system is free from any virus.
Thanks
Zulfikar Ali
May 20, 2008 | Microsoft Office Professional 2007 Full...
go to website www.martau.com download uninstaller and completely remove previous version office. Using this application every entry related to previous version will be removed
Dec 18, 2007 | Microsoft Office Professional 2007 Full...
Microsoft Office Professional 2007 Full Version for PC Logo
358 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
