Question about HP PSC 1410 All-In-One InkJet Printer
How to print with black/white only with brother MFC-3360C USB printer
  • Anonymous Jun 01, 2008
    HOW CAN I PRINT WHEN ONE OF THE CARTIDGES IS EMPTY
    Problem Solver:
  • 15 Answers
Set the product software print setting to grayscale. Follow these steps to change this setting:
  1. In the software application you are trying to print from, click File , and then click Print . The Print dialog box opens.
  2. Make sure your printer is selected, then click Preferences . The printer Preferences dialog box opens.
  3. Select the Color tab, then select the Print in grayscale option.
Posted on Dec 14, 2008
Fax will not print: I connected the fax machine and plugged it in. It sends faxes OK. When a fax is sent to it, nothing comes out. The sending fax doesn't receive an error message, seems like all went...
Does the machine print anything? such as a directory or print when making a copy? I rather suspect it does not. When an incoming fax is recvd does the paper get pulled in and come out blank? If so your problem is with printing (or lack of it). Perform head cleaning. Also make sure the black cartridge still does not have its deal stuck on it. Post again if you still have problem.
May 05, 2011 | Brother Multi-Function Center MFC-3360c...
Hi Guys I have a Brother MFC 3360C the problem is i have replace a new Black Ink Cartridge and the machine cant print black anymore it can only do color. What cause this to happen and also what is a...
hi...
as you repalced please check the following.
1.check weather the catridge is been placed correctly and in correct position
2.when you get a new catridge there is a protective cover placed in the outlel of the catridge so please check weather you remoced that protective coating.
3.the outlet may be blocked by the old ink which got dried up. so please clean the outlet of the catridge and try once
if may answer was usefull please vote
Jul 14, 2010 | Brother Multi-Function Center MFC-3360c...
Printed page do not match screen colors on a MFC-3360c brother all-in-one printer
Clean print head it may work properly. else
find out which color not working. replace the color ink cartridge
LC51BK Black color
LC51C Cyan
LC51M Megenta
LC51Y Yellow
Aug 25, 2009 | Office Equipment & Supplies
Black cartiage is not working
Sir,
Check the black cartridge it will refill or not? open the black cartridge and shake it and reinsert. Check with printer options, if any option selected with color only uncheck it and select the best quality option.
Thanks
Good Luck
Aug 05, 2009 | Brother MFC-3360C All-In-One InkJet...
Brother mfc3360 blank ink doesn't print
brother is good printer,there are many facitil as we can block one type colour as black or colour . look once a time in your printer option.or setting. , Is there on type colour is set only?
Jun 20, 2009 | Brother MFC-3360C All-In-One InkJet...
Print only black and white for brother mfc 3360c
Power off the printer.press menu and power on .do'nt release menu button until maintenance appear and flashes fax, scan and copy . type 10 . then next type 49. you will see 00000000.just change last 0 to 1. 00000001. press 99 to exit. you will find the printer only prints B/W only.
Feb 10, 2009 | Brother MFC-5440CN All-In-One InkJet...
Will not print.
What a ditz, it just needed a new ink cartridge.
Jan 23, 2009 | Brother MFC-3340CN All-In-One InkJet...
How do I remove paper tray on Brother MFC-3360C
you just pull the black tray you look doen infront of mfc-3360c
Jan 01, 2009 | Brother MFC-3360C All-In-One InkJet...
HP PSC 1410 All-In-One InkJet Printer Logo
99 people viewed this question
Ben Johnson
