Pilot light seems to have gone out in the wind and I don't know how to re-ignite it
  • 107 Answers
Get long lighter such as kind for BBQ pits and turn gas knob to Pilot and hold it down. Once pilot is lit hold button still for 30 seconds then release and turn valve to on. If pilot keeps going off.. the problem is a bad thermocouple
Posted on Aug 27, 2010
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
Lighting the pilot light on a Worcester 24CDi combi boiler.
Most of these boilers don"t have a permenant pilot light they have electronic ignition that lights the burner when you are calling for heat or hot water, is there enough water pressure in the boiler ( there is a small gauge on the bottom r/h side of the boiler the needle should be sitting at between 1 - 2 if not enough pressure the boiler won"t light )
Apr 23, 2010 | Heating & Cooling
Pilot light went out..
Here you go... http://www.jandy.com/html/productsupport/launchManual.php?url=Lite2_LJ_IO_H0248900F.pdf
Apr 22, 2010 | Teledyne Laars Teledyne_ Laars Lite2...
Pilot light gone out. How do I relight? Which
In general, large button from gas valve push in & hold 20-30 secs at same time push electronic lighter/ignition button to light pilot. Remember to hold in only gas button. the pilot light heats up a thermo couple [u can see this in the flame] and when hot enough allows the main gas through and the pilot to remain on.
If not then either thermo couple not heated for long enough or
it may need replacing
Oct 22, 2009 | Bosch Water Heaters
Burners not lighting off pilot
Sorry, no solution, but I have a similar problem, so if you could let me know how things get resolved, I'd greatly appreciate it.
On mine (a 2100 model R405A), this is especially likely to happen during or after wet weather. Not sure if the ignitor is the problem. After power on, I hear the ignotor clicking for a bit and often then I hear an odd sound and then the clicking stops. My LCD is totally gone (a whole separate issue), so I can't tell you what message is there. But, usually after a good period of drying out, the unit fires up ok.
Seems to be getting progressively more prone to this as it ages (installed 2002).
If you have any more info, please let me know @ sroche@tellink.net or here
Thanks,
_Steve
May 28, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
My pilot light also just went out on my water wizard 13P when you relight ensure all buttons are equal in height or none depressed then hold far left button down whilst striking ignition button till pilot light ignites keep left hand button depressed for a further 3 seconds after pilot light has ignited I hope you have hot water then
May 22, 2009 | Audiovox Bosch 718 World Cellular Phone
I have an old ideal elan 2 boiler. The pilot light has gone out and wont re-ignite. I have pressed the ignition switch in but there is not even a spark. Does anybody know where the re-set button is on...
Hi, to light the pilot you must first ensure the gas valve button (Grey with 3 symbols on it) is placed in the ignition position, then, while holding the button in towards the gas valve depress the orange ignitor button several times, hold the gas valve button in for about 30 seconds once the pilot lights. If it fails to light and you cannot see a spark when you depress the ignition button the cable could be faulty, the ignitor corroded or damaged or the pilot could be blocked or the gas turned off. If it is an Elan 2 CF boiler there is no reset button.
Apr 26, 2009 | Kitchen Appliances - Others
Pilot light has gone out onmy Ideal Elan 2 Boiler
TAKE A SHPO VAC AND CLEAN AREA. MAKE SURE YOU PAY SPECIAL ATT. TO THE PILOT LIGHT. FIND BUTTON HOLD IN AND IGNITE DONT LET GO WHEN IT LIGHTS FOR AT LEAST FIFTEEN SEC.. YOU MIGHT ALSO HAVE TO TURN THE THERMASTAT OR KNOB TO PILOT FIRST. AFTER IT HAS LIT TURN UP FLAME
Oct 25, 2008 | Water Heaters
Why frequently relight my pilot?
check for water run off from above or sprinklers directed at heater. A high wind stack may be needed due to heater location. Millivolt models have a thermocouple or pilot generator that may be faulty or weak. Loose or rusty connections of the thermocouple to the gas valve or loose coil connection, or short in these wires can shut off a pilot.
Aug 27, 2008 | Raypak REFRACTORY KIT
Heating & Cooling Logo
122 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
