Question about Zodiac Baracuda Zippy Pool Cleaner
Pool cleaner starts only when i allow it to **** some air then stops after a few minutes
  • 640 Answers
If your pool cleaner is not working properly, there are several things that you will need to check. First, make sure that your filter and pump debris baskets are clear. Also, make sure that you do not have an obstruction in the throat of the cleaner or the hose. Make sure the diaphragm is not damaged or worn. You will also want to check your water flow. Use the Star Control that comes with your cleaner and try to get your water pressure into the yellow or orange zone.
Posted on May 11, 2011
Booster pumps
Make sure the main pump is running while the booster is and make sure there is no air in the lines. You may have to open the pump to see if any debris has gotten into the impeller.
Aug 05, 2013 | AO Smith Pool & Spa
Dolphin diagnostic motor replacement
May be the circuit board - There is an on-line group called Circuit Board Medics who can test and repair the board.
Jun 22, 2012 | Dolphin Maytronics Diagnostic Robot...
My cleaner works for a few minutes, climbs a wall and rolls over onto it's head.
If the problem always occurs when the pool cleaner starts to climb walls, there are a few things that you will want to check. First of all, if your pool has a vinyl liner, this pool cleaner has limited climbing ability. You need to check the flow of water through the cleaner with your flow gauge. It might be low. If it is, increase the water flow. Also, make sure that your hose weight positioning is correct. The cleaner should sit at a 45 degree angle at the bottom of the pool when resting when the weights are right.
Nov 08, 2010 | Zodiac Baracuda G3 Automatic In Ground...
I have a dolphin pool cleaner and it won't sink. Any advice?
If these automatic pool cleaners will not sink, 9 times out of 10 it is because air is caught in the filter bag. The best solution is to turn the Dolphin upside down under water for a few minutes to remove the air or to machine wash the filter bag.
Jun 11, 2010 | Dolphin Maytronics Advantage
My Legend cleaner (8 yrs. old) starts off fine but after a few minutes runs very slowly. any ideas what may be causing this?
First check the metal screen inside the fitting that connects to the pool wall. Make sure it is clean. If there is no inline screen on the feed hose then the jets inside the pool cleaner could be clogging. If there is a screen that keeps getting clogged with debris(like every couple days) then there is a problem with your pool filter or multiport valve that is allowing dirt to pass into the pool cleaner and the pool. Also it could be the back-up valve hanging up(due to a bad bearing or bushing) The back-up valve is the large canister on the feed hose about 3-6 feet above the cleaner. Check for holes in the feed hose and in the cleaner tail.
May 31, 2010 | Pentair White/Gray Legend Platinum...
MY POOL CLEANER WILL RUN FOR A FEW MINUTES, THEN STOP. SO METIMES IF I SHAKE THE HOSE IT WILL START AGAIN. ANY ANSWERS?
Hi , most pool cleaners run by the force of the sucked up water moving gears inside the cleaner .. if yours is this way, then any blockage in the cleaner or in the hose attached would restrict the flow and keep the cleaner from moving.
Apr 30, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Cleaner is floating on top of pool
First, remove all of the air from the cleaner head and stop all air from entering the pool2_bing.gif through the return lines. Also, if the head and hose are covered with bubbles, give the hose a good tug. This will release the air bubbles and allow the pool cleaner to settle son the bottom of the pool. Also, the cleaner head may actually be being lifted off the bottom of the pool by the hose or the pressure in the return lines. Make sure that the hose stays untangled and the pressure from the return lines is not too low (not enought pressure to power) or too high (too much pressure that cause the unit to lift off the floor).
Apr 20, 2010 | Hayward Navigator Pool Cleaner
Keeps tipping over
With these automatic pool cleaners, this is often a problem with the treads or having air in the head. Make sure that your treads are not worn and are getting proper traction. If they are worn, you might need to replace. To rid the air, try turning the Aquabot upside down and submerse in the pool for a few minutes. This should force the air out.
Jul 12, 2009 | Aquabot In - Ground Robotic Pool Cleaner
DOLPHIN DIAGNOSTIC AUTOMATIC POOL CLEANER STARTS AND STOPS
There may be moisture building up inside the motor housing. Try to Open it. http://www.i-love-my-aquabot-automatic-pool-cleaner.com/Maytronics-Dolphin-Repair.html
Then make sure no moisture accumulated in the circuits. Mine got the same problem.. after running trouble free for several years it suddenly stop running after the first few minutes..when i opened it a lot of moisture in the circuit. I tot it was toasted. so i took my hair blower and sealed it back and replace the moisture absober (it was soaked).. after first run it would run only the SELF TEST mode.. i tried several method to make it run all the way to the main program.. the solution.. start it and make sure it will not tilt in the first 10 minutes before you let i run sideways to the walls, this makes the program run back to normal.
Jun 28, 2009 | Smart Pool Inc Dolphin Diagnostic...
Zodiac Baracuda Zippy Pool Cleaner Logo
156 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
