Question about Canon Office Equipment & Supplies
Hi I have canon IR3300 the copy and print both are faded/light from one side a horizontal white appear on top of vertical A4 please help me to solve the problem. thank you!
SOURCE: White line appearing vertically down the left side of the page
I had a line for months! Then I got a line going down the middle of the page. So cleaned and poked around inside put back together and another line! 3 vertical lines! Came on here and went back with a hairdryer on cold setting blowing around the inside of the printer and now its perfect!
Cheers all!
Posted on Apr 04, 2008
  • 3 Answers
SOURCE: On my Canon Pixma MP780 a vertical line appears on copies made using ADF
I tried the other solutions listed here - and no luck. After cleaning the inside of the ADF, like the manual suggested - no change. How are you supposed to do that anyway? Deep cleaning the inside of the machine also has nothing to do with it.
I finally figured out why things that I copied with the ADF had lines/marks on them, but those placed directly on the platen (big glass) were fine. When you copy with the ADF, the copy is not being made from the large glass area. Rather, there is a thin glass area right next to it.
Turns out, there were a couple of smudges (goo) on that thin piece of glass which were creating long vertical lines down every sheet. Cleaned the glass - problem solved!
Gosh, I hope this helps someone else save some time, and frustration.
Posted on Dec 03, 2008
yooperbud
  • 8637 Answers
SOURCE: half page printing
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
dirinda89
  • 214 Answers
SOURCE: need user's manual for imagerunner ir3300
Here's a link for your manual. Good luck. If this helps you plz rate this as 'fixya'. If you need more help leave a comment & I'll be happy to help. Thank you kindly.
http://ris-systech2.its.yale.edu/ris/driverdownload/CanonIrSeries/Manual/Rui_g.pdf
Posted on Mar 06, 2009
20YrsCompExp
  • 227 Answers
SOURCE: vertical black line on side of copies only when using autofeed
Clean the small piece of glass on the flat bed. Should be on the left side of the flat bed when you lift the doc feeder.
Posted on Apr 11, 2009
Ir3300 black page coming how to rectified this problem plzz help
True multi-functionality means you get more for your money in less space with the iR3300 black and white office photocopier. Handling the work of many in one compact solution, the iR3300 provides a cost-effective solution to your printing needs.
Features of the iR3300:
  • Provides copying, printing, scanning and faxing all in one unit.
  • Has a print speed of 33 pages per minute .
  • High capacity paper supply
  • Double-sided printing as standard.
  • Compact and reliable design.
  • Productive and space saving finishing options.
Jul 22, 2012 | Canon imageRUNNER 3300 All-In-One Laser...
Twosided copying problem
Try turning original in a different orientation i.e. horizontally vs vertically on top of glass, under lid. Jimmy
Apr 10, 2012 | Canon Office Equipment & Supplies
Hi i have ir3300 and the print is lighter from one side in a4 sheet
First of all You need to clean the laser unit and beneath the copy glass and lenses inside.
Second of all if cleaning doesn't help's try with cleaning the developing roller and replace the drum unit and transfer roller.
Hope that helps
Sep 09, 2011 | Canon imageRUNNER 2200
One side of my copy fades on the A4 sheet, i use IR3300 copier.what is the problem?
take out a internal report on A4 .if it ok then the problem is from optics and u have to clean it .if the report is also faded then the laser unit is dirty so u have to take it out if ur a rep and clean it with simple white cloth for dust on mirrors
Jul 30, 2011 | Canon ImageRunner 3320N Copier
The copier IR3300 print one side faded at the back on the A4 than the other side. on the same A4 sheet, one side is lighter than other. but when the paper is A4R, it okey. what is the problem?
it may be because of dirty laser unit or the iptics.try cleaning the optics and then the fuser.charging can also be a problem .check DP unit for toner layer .
My canon pixma 480 has thin horizontal lines. tried cleaning and deep cleaning where is the head alignment tool?
The instructions as copied from the Pixma 480 "onscreen manual." (Only the text -- not the images -- could be pasted into the solution. Hope you can follow the text.) Steve G.
Prepare 2 sheets of A4 or Letter-sized plain paper
1. Make sure that the power is turned on, and load 2 sheets of A4 or Letter-sized plain paper in the Rear Tray.
2. Open the Paper Output Tray gently, and open the Output Tray Extension.
3. Print the print head alignment pattern.
- Press the Menu button.
- Select Maintenance, and press the OK button.
- Select Print head alignment, and press the OK button.
Note: To print the current head position adjustment values, select Head alignment print in the Maintenance menu and press the OK button. See Selecting Menus on the Top Menu Screen.)
- Select Yes, and press the OK button to print alignment sheet.
- Check the pattern is printed correctly, select Yes and press OK button.
- Confirm the displayed message and press the OK button.
The Print head alignment screen appears.
4. Adjust the print head position.
- Check the printed patterns, and use the (Left) or (Right) button to select the number of the pattern that has the least noticeable streaks for column A.
Note: If it is difficult to select the best pattern, select the pattern that has the least noticeable white streaks.
(A) Less noticeable vertical white streaks
(B) Noticeable vertical white streaks
(C) Less noticeable horizontal white streaks
(D) Noticeable horizontal white streaks
- Repeat the same procedure to input the pattern number for each column from B to L, then press the OK button.
- Select Yes to continue printing, and press the OK button.
- The second page of print head alignment sheet will be printed.
- Confirm the message for print head alignment, and press the OK button.
- Check the printed patterns and use the (Left) or (Right) button to input the number of the pattern that has the least noticeable horizontal streaks for column M.
- Repeat the same procedure to input the pattern number for each column from N to R, and press the OK button.
Jan 12, 2011 | Canon Pixma MP480 All-In-One InkJet...
In my ir3300 xerox in very light
That means that you have to clean copy glass , lenses, ccd,...maybe even laser unit if you know how.
On digital machines dirty optics means light copy, on analog oposite, dirty optics dark copies.
Just one more question how do you mean " charge toner"?
Jun 07, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Info
Canon ir3300 is a black and white 33 ppm (A4) copier , printer (network), fax and scanner ( b/w).
For more info please visit canon website.
Sep 26, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
457 people viewed this question
old marine
old marine
