Question about Intel Motherboard
I got a motherboard p4m900m2..no display but it has power..then it beeps one at time..continuous for a minute.
    Sergeant:
  • 223 Answers
This sounds like either the memory card that is installed is the wrong type or faulty, or incorrectly seated in the slot. Also, check to make sure the video card is fully seated, as this could also cause the beep error. If your computer has two ram cards installed in it, take one out, try it, then take the other out , try again with the other ram module. Ram cards are easy to damage via static discharge. hope that help you.
Posted on Aug 26, 2010
MSI PM8M-V Motherboard with Power no Display No power on keyboard
A continuous beep POST error usually means there is a RAM problem.
Try re-seating the RAM, and if you still have a problem then take the RAM to your friendly computer repair shop to test the RAM for you.
Jan 20, 2013 | MSI PM8M-V Motherboard
My pc is booting but no display
Did you check your monitor with other system or individually. If it works fine in these conditions then the issue belongs to your pc.
First of all, you have to confirm that is it the problem of VGA itself or the motherboard. For this, you have to see that does system beep when you start it because system with beeps having the error and the beep sound with continuous or 2-3 beeps relate with different issues. I am going to write down the beep conditions.
1 short beep Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
best of luck!
Mar 13, 2012 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Boot failure, beeps and no display
Hi.
Do this solution first in the motherboard only processor installed need no memory.then power on your PC.if your motherboard no continues beeping.that need replacement of parts specially capacitor
leakage,became big or burn parts.
See beeping code.
Beep Code:
Description of Problem:
No Beeps
Short, No power, Bad CPU/MB, Loose Peripherals
One Beep
Everything is normal and Computer POSTed fine
Two Beeps
POST/CMOS Error
One Long Beep, One Short Beep
Motherboard Problem
One Long Beep, Two Short Beeps
Video Problem
One Long Beep, Three Short Beeps
Video Problem
Three Long Beeps
Keyboard Error
Repeated Long Beeps
Memory Error
Continuous Hi-Lo Beeps
CPU Overheating
Jun 17, 2011 | Dell Motherboard For Precision 470...
My 741gx-m2 motherboard produces continuous beeps when i turn on the power, when i remove the ram i get a long 1 second beep followed by a few beeps, i return the ram i get continuous beeps but no display.
reset your cmos see if this helps pull the jumper on the jp3 circuit on the motherboard and short the 2 and 3 pins with the power off and unplugged then put the jumper back to 1 and 2 ! the bios settings are wrong and this will reset the bios to defaults.
Oct 14, 2010 | EliteGroup 741GX-M Motherboard
Where can i download the vga driver of p4m900m2?
there is an F and L model go here and choose the correct board and you can download the driver http://www.msi.com/index.php?func=searchresult&keywords=p4m900m2
please take a moment to rate this solution thanks
robert
Nov 28, 2009 | Intel Motherboard
Erro sound/pip when ibm 8310 netvista starts, no error message are show on the screen, the screen are black.
how many times it beeps is an indication of the problem
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard cardhope this helps.
Sep 14, 2009 | IBM (09N5424) Motherboard
I have a mecer computer, LGA 775 motherboard asus and the problem is the computer turns on when switching on and there is no display it beeps non stop . CPU and power supply fans are working ,lights goes...
continuous beeping is Power supply, motherboard, cpu, or keyboard problem. somecases it can also be the memory.
start with the memory then cpu and powersupply and finally motherboard.
let me know if the beep code changes as you change components, count the short and long beeps.
Jan 07, 2009 | ASUS P5VDC-X Motherboard
Audio driver of MSI P4M900M2 motherboard.
hello
May bee you looking for this?
http://global.msi.com.tw/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=1123
choose vista or xp and download the driver.
if its wrong driver use the driver guide to get the right drivers for your motherboard.
http://global.msi.com.tw/index.php?func=downloadindex
Oct 19, 2008 | Intel Motherboard
Computer beeps three times and will not start
Clear CMOS/ Remove battery for 10 minutes, reinstall battery & wait for another 10 minutes before turn on. Three Beeps means RAM is defective/ not detected.
Jun 27, 2008 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
NO DISPLAY
If the motherboard still power on it. You can test it to identify where is the fault.
first remove the memory..if you use ad on video card then remove it. if it is built in then only the memory to be remove.
Power on/switch on the PC. If here any beeps then probably ..You rmotherboard is OK and the Processor. If not hear any beeps.. then, examine the processor and the motherboard..You can check the processor by inserting it to the other motherboard with thesame socket to your motherboard.
and motherboard can be determine if it fault tru seeing touching some chips which overheating. or by inserting other working processor in it.
If hear beeps on the PC, then insert the memory and then test..if not resolve then, remove the memory and clean with soft material or eraser. then insert it back, Again if not resolve time to replace the memory.
may this help,
melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
May 08, 2008 | Computers & Internet
Intel Motherboard Logo
51 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
