Question about Cameras
Hello - My Olympus SP-550OUZ Camera was in a rucksack which slid of my shoulder and hit the ground. Although there is no obvious damage to it, nothing cracked, no marks etc., it has stopped seeing properly. Pictures already taken can still be viewed either in the viewfinder or the screen both work perfectly. The lens moves in and out not problem everything seems to work fine except when you look to take a picture either by viewfinder or the lcd screen all it sees is a blurry hazy purple picture and that is what it takes a photo of. Is my camera fit for the graveyard, is it something major or do you think it can be fixed. Many Thanks for taking the time to read. Any advice would be appreciated. Regards.
walkietalkie
  • 32 Answers
SOURCE: Blurry viewfinder
Your Canon camera falls in one of the models that had a bad CCD imaging sensor. I do not exactly know how your screen looks like, but try to visit the follow link to read the article that is related to these camera problem, or go to your country's Canon site to find the 'Service Advisories' to learn about Canon's updated comments on their products, new or old. The link that I mentioned above: http://www.imaging-resource.com/badccds.html If you have difficulties finding the related service advisories from the Canon site. Simply find their contact tel. no. and give them a call to find out how they will handle the situation. It's worth the time to do so, as it will be free of charge to get your camera fixed, including both way shipping costs if shippings are required. The link above will bring you to a web page containing sample images of the screens being affected by the bad CCD. Make sure they match the problem of yours before proceeding to the next step. Good luck. Paul
Posted on Sep 14, 2007
SOURCE: dark view field
This camera has been recalled and will be repaired free of charge regardless of the warranty status.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=227&modelid=9739&keycode=2112&id=48266
Posted on Aug 19, 2008
  • 4 Answers
SOURCE: Black screen for Shooting Canon S3 IS
I have a similar problem with my Canon S3 IS. Dark/black LCD in Shooting mode. However, I can view my existing photos in Display mode. I was about to spend money to get a Panasonic TZ5. Somehow I bumped into a solution post for S2 IS. Here is the link:
http://www.fixya.com/support/t1090569-black_screen
I tried their solutions twice and it WORKS. My S3 is working fine now.
Posted on May 28, 2009
BillB-SA
  • 2761 Answers
SOURCE: the camera turns on - but you cant take a picture
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Posted on Nov 08, 2009
  • 275 Answers
SOURCE: i have no picture coming through on the screen or
That is strange, maybe taking the batteries out and putting them back in could reset the camera to normal. Electronic problems are real tough.
Posted on Nov 29, 2009
My Olympus SP-610UZ camera get restarted when i click on button to take pictures, help please, thank you
This can happen when you battery does not have enough power. It protects the camera against damage and the pictures on the memory card. If the camera has not enough power while accessing the memory, it could damage all pictures you already shot.
Even when you just charged the battery, it can be it does not have enough power to work. Just try charging it again and if possible try another battery.
Jan 02, 2014 | Olympus Software SP-610UZ Digital Camera
How to open OLYMPUS SP570 UZ to fix flash lift
First, remove all visible screws.
Then use a magnifier to closely examine the hot shoe. You will see that there is a spring clip which can be slid rearward and removed. Under this clip are 4 screws. Remove these and the rear cover is free.
Jan 09, 2013 | Olympus SP-570UZ Digital Camera
Tried to install new camera but it has not brought up the users manual or IB programme. I can upload photos to the Olympus master programme.
The Olympus SP-800uz users manual can also be downloaded:
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1499
or English:
http://www.olympusamerica.com/files/oima_cckb/SP-800UZ_Instruction_Manual_EN.pdf
The Olympus [ib] software is on the cameras internal memory, if you did not format (delete) it. Look there for the setup.exe and run it. Although the best alternative free Olympus software is Olympus viewer 2 which replaces also Olympus Master 2:
http://support.olympus-imaging.com/ov2download/
Dec 28, 2010 | Olympus SP800UZ Digital Camera
I have an Olympus SP 560-UZ with zoom error.
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Jan 10, 2010 | Olympus SP-560 UZ Digital Camera
Blue line on pictures. SP-510 UZ
From what I am told your CCD is damaged. I have the same problem with my Z812.
Oct 29, 2009 | Olympus SP-510 UZ Digital Camera
Camera was dropped
The CCD could be damaged. It could cost nearly $200 to fix
Dec 31, 2008 | Olympus SP-350 Digital Camera
I have a problem with my Olympus SP- 510 UZ digital camera: Although it perfectly displays pictures taken recently, the screen remains all black when I intend to take pictures. It does take pictures...
Sounds like a repair issue with the image processing chip in the camera. You may want to call Olympus Customer Service to discuss repair options and pricing. Their telephone number is 800-622-6372 option 2 and then option 3
Dec 12, 2008 | Olympus SP-510 UZ Digital Camera
I have an Olympus SP 320 camera, zoom error comes up and it shuts off
I just pulled my 320 out after not using it for 4 months and the lens extended and zoom error began flashing on the screen. After reading a few other post on the net about how much it cost I decided the camera was a goner. For good measure I banged it on my mouse pad a couple times and the lens suddenly retracted and it is now working fine. Doubt it will work very often but might be worth a try. Make sure you hit it on something soft to prevent other damage.
Sep 15, 2008 | Olympus SP-320 Digital Camera
Olympus Camera
if you go to the olympusamerica.com/store you will see the telephoto lens but you will need the cla-10 adapter to use it with your camera
although you do get more telephoto with it... you can turn the digital zoom on in the camera and go to 90+ times zoom
Jan 28, 2008 | Olympus SP-550 UZ Digital Camera
Cameras Logo
59 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
