How much concrete fills a circular 500mm diamiter steel 6.3m long
Volume is Area x Length
Area = Pi*D^2/4
Pi=3.141592
D= 500mm = 0.5 m
D^2 = 0.25m^2
Area= 3.14*.25/4 = 0.196349 m^2
Volume = 0.196349 * 6.3 = 1.237 m^3
1.237 cubic meters
Posted on Aug 26, 2010
What is the advantage of adding glass fiber in concrete?
Fibers are usually used in concrete to control cracking due to plastic shrinkage and to drying shrinkage. They also reduce the permeability of concrete and thus reduce bleeding of water. Some types of fibers produce greater impact-, abrasion-, and shatter-resistance in concrete. Generally fibers do not increase the flexural strength of concrete, and so cannot replace moment-resisting or structural steel reinforcement. Indeed, some fibers actually reduce the strength of concrete.
Dec 07, 2016 | Cars & Trucks
If I clean up concrete contaminated by a post-1987 spill pursuant to state clean-up standards, can I continue to use the concrete? If not, what are the requirements?
definitely not a television question
commercial or residential ?
If clean up was done to state regs that concrete is good for any use
just in case
define contaminated
hazardous , carcinogenic ,nuclear, bio hazard
solid concrete slab poured post 1986 will have reo
if sound condition can be used, painted over, carpeted .sealed , tiled.what ever
if cracked up due to demolition
still ok to use for land fill or other rubble type back fill
Jun 17, 2016 | Televison & Video
What is the best method for retro-fitting a residential water line with a protective shroud, so that a concrete driveway can be poured over it?
Depending how deep it is underground there might not be a solution.
First of all waterline should be below the frost line, about 36" to 42". Anything shallower that that it might be asking for trouble from freezing if you live in a cold climate. If you can open one end of the water line you might try putting a steel pipe (schedule 80) around it then back filling with gravel prior to the concrete install. If you can't open one end of the water pipe cut a piece of culvert pipe in half, place both sides around the pipe, then use tie wire or clamps to keep the halves together then back fill with gravel.
Aug 24, 2013 | Plumbing
6.0 liter 2006 ford engine glow plugs location
THE BLOW PLUGS ARE UNDER THE VALVE COVER HOWEVER YOU CAN REMOVE THEM BY REMOVING THE GLOW PLUG HARNES FROM THE HEAD ( IT IS ON THE EXHAUST SIDE AND EACH GLOW PLUG HAD A "CONNECTOR THAT GOES THROUGHT THE HEAD ITS CIRCULAR ABOUT 1/2 - 3/4 INCH IN DIAMITER) AND REMOVE THE GLOW PLUG WITH A 10MM DEEP 1/4 INCH WITH AN EXTENSION
Dec 03, 2010 | 2006 Ford F-250 Super Duty
Us to cut off a 1"steel pipe
Only if you use and metal cut off blade and an insert to make it fit the shaft.
Jun 23, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
Use of a Sait Cut abraise wheel to cut PVC Pipe
I worked at a tool rental business while going to college and became familiar with OSHA requirements as it pertains to construction. There is an old saying that if you follow the rule-book by the letter things will quickly come to a grinding halt. I checked on OSHA web site and could not find anything on you question. I recall that using the correct blade only results in a cleaner cut, however there is the possibility that the pvc material can load-up on the blade and cause jambing. An inspection of the blade will answer this. More important is that all safety items are in place like the blade guard and that all workers in the vicinity of the saw are wearing eye protection. We used Norton brand abrasive blades and the following is their guide. APPLICATION GUIDE:
Concrete:
For concrete/masonry - silicon carbide specification for brick, block, concrete, and other masonry materials.
Metal: For metal/steel - aluminum oxide specification for mild steel, stainless, and metal decking.
Asphalt: For use when cutting mostly asphalt.
Asphalt / Green Concrete: For asphalt and green concrete - silicon carbide in coarse grit range. For high performance, hot pressed wheels provide significantly longer life.
Ductile: For ductile iron and cast iron pipe - formulated with a special blend of silicon carbide (for cutting) and aluminum oxide (for long life). This specification is also suitable for cutting PVC.
Hope this helps, enjoy
Dec 09, 2008 | SAIT Portable Saw Cut-Off Wheel TM 12 x...
44 people viewed this question
k24674
jasbo
jasbo
