I have set up my wireless router and it works fine on my computer but my other computer gets on the internet but will not get on a vpn network. what am i doing wrong
  • kbuzz40863 May 18, 2008
    thanks for your reply.the problem has been fixed the router was bad .replace it with a new one and was able to get connected the first time. kbuzz
  • rajkar
    rajkar May 11, 2010
    Which OS are you using in both the computers?
    Master:
  • 441 Answers
Make sure to open the ports of the VPN tunnel your are using to the router.Ask your tech support from your office (to where you are connecting to) and ask what ports needed to open ojn the router. Once you got the ports, contact router manufacturer to help you open those ports.(windows firewall might also be blocking the ports so try to disable it).
Posted on May 13, 2008
I have a D-Link DVG-G1402S router, I'm trying to setup VPN connect for a windows VPN server, which inside the network. I tried use modem directly connect to the server, it work, so it process my...
The router's PPTP passthrough and IPSec settings assume that you're connecting to an external VPN server on the public side of the network, but it sounds like you're hosting your VPN server inside your local network. If this is the case, you may just want to have your windows VPN box in a DMZ, or get a router that you can exert more control over. Be wary, if you're doing this at a residential location, your internet provider will probably block or "shape" this type of incoming traffic to your local network.
Mar 05, 2011 | D-Link DVG-G1402S Wireless Router...
I am trying to connect using Cisco VPN through my Motorola wireless router, but cannot connect. I check with my internet service provider and they do allow VPN. Our IT division has checked the...
The devices appear to be in functioning order. However, the connection network requires another computer on which signals are directed towards. The computer server on which network resources are acquirable is unavailable. For example, your devices can provide sevices to another computer if any were avialble. Usually an internet provider would allow acess to several computer with subscription. Consult an internet service provider, examples, at & t, T- mobile, Verizon, boost mobile, or consult any available at your local area. www.at&t.com, www.t-mobile.com, www.verizon.com, Goodluck
Jan 11, 2011 | Arris SURFboard SBG900 Wireless Router...
Using linksys wireless router like i have for 10 years, but since getting a new dell E4300 laptop, have not been able to access corporate email withOUT using vpn which isn't typically required. works...
You may have to link up with your IT department at work and have them list your linksys router for access to the corporate network.
This should help.
Oct 11, 2017 | Linksys RV042 VPN Router
How configurate this router? I lost the CD with configuration. Please ask me. Mabey in Polish language?:)
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
When you connect vpn router to wireless router set in wi fi lan property as your vpn network range set vpn router ip as gateway ip of wireless router.Then save settings and restart it.
Let me know if you need further assistance.
Thanks for using FixYa.
May 20, 2010 | NetGear WGR614 Wireless Router
Trying to set up a vpn server on windows XP using
Did you already forward port 1723? I guess you have done that. To isolate it, try to bypass the router and setup or establish the VPN session there. If it doesn't work, maybe your ISP doesn't allow port 1723 or it's just the modem.
Oct 22, 2009 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
I can access internet but cannot get in via cisco vpn(intermitent
Look at the number of users you have enabled in the router. If you only have 3 and you are using 4 computers, you could be getting the kind of behavior you are describing based on how many computers you have connected at the time.
Jun 18, 2009 | Belkin (F5D5231-4) Router
I can't connect through the VPN and Internet at the same time
when you have 2 connections open at the same time you need to tell the computer which one you want to use to connect to the internet. the way to do this depends on the operating system but in windows the setting is in advanced properties of the network connection in control panel
Jan 21, 2009 | Belkin Wireless Cable/DSL Gateway Router
Cannot connect to SonicWall VPN
My guess is that dhcp is using the same private network scheme. Try changing your home network scheme to something different than your office.
For example:
Office = 192.168.1.x
home = 192.168.2.x
Aug 26, 2008 | Westell Wirespeed VersaLink...
Linksys Wireless Router Disconnects Frequently
You just need to change the wireless channel of your router since you have a cordless phone because some devices like a cordless phone that is running on the same frequency like the router which is 2.4ghz really interfere with the router signal so it advisable you set the router to channel 11 to boost the signal if its still not solving your problem you can consider getting a wireless range expander that will expand the signal of your wireless router so wont have the problem anymore.
May 12, 2008 | Linksys Wireless-G Broadband Router
Vpn pass through problem with us robotics model 5461
login to the router and check these things
IPSec Passthrough: Enable Disable               PPTP Passthrough: Enable Disable               L2TP Passthrough: Enable Disable
Oct 29, 2007 | U.S. Robotics MAXg USR5461 (738168036790)...
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
