I have a mitsubishi wt 46809 . When im watching it it kind of flashes red possiably other colors outlineing the people and things on the set. Then it will go back and intermittenly do it again. Its doing it more and more . Please help
  • 8,617 Answers
Need to replace the convergence ICs both of them Number STK392-570 you can get replacement ICs at the following link and they provide free instalation instructions with pics as well as free tech support so you can do the job yourself. Heres the link.
Posted on May 06, 2008
I have a Mitsubishi wt 46809 with a error code of flash flash pause flash flash
That is error code 22 which means the unit had a momentary recovery from a reset. You should unplug it for 30 minutes, then plug in and try it again. This will reset the fault and if there are no other problems the unit will work ok. Let me know if you need more help. Thanks for using FixYa and for the generous rating.
May 07, 2010 | Mitsubishi WT-46809 46" Rear Projection...
I think the color bulbs are going out. I called
3D pic?Ur convergence it dead.U know how to solders?Tries these websites for convergence kit.Use replaced what in the convergence kit. Tv repair,or
Dec 14, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi problem
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
    Colors don't line up
    One or more colors can't be adjusted when using the convergence menu.
    Screen is bowed or warped.
    No Audio / No Video
You can see some examples and find a fix here...
Sep 25, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Color Gun Help?
this tv will need some testing to determine the exact cause but most likely it will need a conversion done, you will need to call your local repair shop to come out and fix the problem
sorry about your tv
Oct 26, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi wt-46809 not turning on
Your convergence amp ICs have most likely failed and that will shut the TV down. You need to replace both convergence ICs they are both STK392-570 you can get replacement ICs with free instalation instructions at the following link.
Jul 18, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Rear projection set
Convergence circuit repair = replace STK392-570 IC's........
Located on center circuit board on large heat sinks........T.
Please rate this solution...................
Nov 07, 2007 | Mitsubishi WT-46809 46" Rear Projection...
MItsubishi WT 46809- not staying on when turned on
One or more fuse devices open==caused by convergence IC
shorted. Solution==replace fuse(s) and STK I.C.(s).
Oct 08, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
