Question about Sharp AF-S85FX Wall/Window Air Conditioner
It keeps flashing E1 on the unit , why ? - Sharp AF-S85FX Wall/Window Air Conditioner
  • Sharp Master
  • 43,501 Answers
Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Posted on Aug 30, 2010
2 Suggested Answers
  • 3 Answers
SOURCE: my unit shut off now displays E1.
Sharp updated the procedure for resetting the E1 code.
1. unplug unit
2. hold the Power button while plugging the unit back in
3. keep holding the Power button until the unit beeps
4. unplug unit again
5. plug it back in and it should be good
Here is the updated user manual
http://www.sharpusa.com/downloads/archives/product_manuals/air_man_AFS100FX_S120FX_S125FX_R100FX_R120FX.pdf
Posted on Jul 05, 2010
Igloo wine cooler FRW823 error code e1
E1 error code on display panel and
audible alarm sounding six times every
minute (Compressor fault - high/low
amps).
Items to check:
All of the below is in the back of the unit near the compressor.
Compressor wires disconnected.
Check wiring diagram on back of unit
and reconnect wires.
Faulty compressor.
Faulty control.
Faulty compressor overload.
Faulty compressor PTC starter.
Nov 19, 2017 | Furniture
Keep getting code e1
According to page 24 of your owner's manual, the E1 error is indicative of a short circuit in the Indoor Air Thermistor. The unit will likely require service.
Good luck,
Marty
Jun 21, 2014 | LG Electronics LP0910WNR Portable Air...
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
Codes
Flashing E-1 means your thermistor, a device attached to your thermostat that detects room temperature is shorted or broken. Replace or rewire thermistor. First turn power off to it. Second, clean air filter or replace if worn. Third, hit the reset button or scroll through menu until you find reset to factory settings. If no button or menu to scroll through unit then keep unplugged for 8 hrs to reset it. After that plug back in and power on and see if the e1 goes away. If not I recommend having it serviced. Also the owners manual is saying no pipe check operation check, try operating in auto addressing mode without pipe check. Sloution to check setting. Check piping connection and setting.
May 01, 2013 | Samsung MH050FXCA2A Free Joint Multi...
My unit shut off now displays E1.
1. unplug unit
Jun 05, 2010 | Sharp AF-S120FX Air Conditioner
LG dishwasher error code E1
E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
Nov 21, 2017 | LG Dishwashers
What does E1 flashing on display mean? The air conditioner comes on for 10 mins. and then flashes E1 in the display. I have cleaned filter b lown out grill and still no results.
if its a sharp ac ... it will need to be reset..
1) hold down the on/off button keep it held down and plug in the ac ..you should hear a beep...
2) hold down the mode button keep it held down and plug in the ac ..you should hear a beep...
one of two ways will reset the e1 error hope it helps..
Sep 19, 2009 | Heating & Cooling
E1 code flashing on my air conditioner
E1 indicates that it is time to clean the air
filter hope it helps
Jul 26, 2008 | Danby DAC8003D Air Conditioner
Unit stops working - E1
I wrote the solution #1 and have an additional comment. This really does work!! I fixed my neighbor's AC unit by following the instructions for clearing the E1 code. The unit will not operate until the code is cleared. The page is titled: Customer assistance for air filters cleaning (E1 code) on Sharp Air Conditioners
Aug 25, 2007 | Sharp AF-S80FX Air Conditioner
Sharp AF-S85FX Wall/Window Air Conditioner Logo
150 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
