Question about Olympus FE-340 Digital Camera
I have a Digital Camera U Digital 500. I have error when i want to get a picture. The error is (WRITE PROTECT). I tried my best but i fail to get the picture. Please help me
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 26, 2010
I have the same problem. After I take a picture, it comes up "System Error 2". If I turn the camera off and back on again, I can take another picture. I have tried a new memory card and the...
Hello dear sir bkapper, surely there was a flaw in the mechanism of image stabilization (VR).
The best solution , bring the camera to Nikon service.
Regards.
Mar 09, 2011 | Nikon Coolpix 8800 Digital Camera
Canon PowerShot SX20 IS Digital Camera keeps giving me a memory card error. The memory card is a 4gig PNY memory card (lower budget)
Make sure the slide switch on the side of the card is unlocked. Your camera may just want you to format the card in the camera. Download any pics from it first using a card reader if necessary.
Jun 22, 2010 | Canon PowerShot SX20 IS Digital Camera
Olympus E-500 digital camera
Card error usually means the card needs to be formatted in the camera. This will erase it so download any pictures first using a card reader if necessary.
Apr 20, 2010 | Olympus EVOLT E-500 Digital Camera
'olympus stylus 710.When i try to take pictures or erase them it would say write protect or picture error how to i qet it off
Look at your memory card it may have a small switch to protect pictures from being erased or changed. Download what you have taken and reformat card.
Nov 08, 2009 | Olympus Stylus 710 Digital Camera
Memory Card Error
either the card is bad or corrupted... try cleaning the contacts on the card, then try to format thru the camera menu
Sep 23, 2008 | Olympus EVOLT E-500 Digital Camera
E 18 problem
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're still worth a try. Good luck! :
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 13, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Saved pics
Hi,if dont have any very important picture stored in camera you may reformat it all protect picture will erase , the camera sim has no more vacant its full you connot store picture anymore best solution is to reformat it.press menu , press setup,navigate down select format. then okey.
Dec 11, 2007 | Cobra Digital DC6550 Digital Camera
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Nov 19, 2007 | Canon PowerShot S2 IS Digital Camera
Memory card error
Either the camera or the card is faulty. There is not a setting which will cause this problem. Try a different memory card, if the problem persists you will need to get the camera repaired.
May 07, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Olympus FE-340 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
