Question about AMD Computers & Internet
It is possible to use rest as a switch button to open a computer?
    Guru:
  • 302 Answers
Yes it is possible. Just pug in the reset switch into the power port on your motherboard.
Posted on Aug 26, 2010
How to reset ipod touch
If you want to reset your ipod back to factory setting then this if what you do:
1. plug your ipod into the computer and open itunes.
2. click on your ipod and click back-up to backup your data on ur ipod.
3. If you have any photos that you want make sure you have a backup of them or transfer them.
4.After that you can just press the rest button in itunes.
-Or-
if you dont care about what on the ipod then you can go to settings, then general, then rest and chose which rest you would like.
Hope this response helps you!
Jul 17, 2014 | Apple iPod touch
I need rest i tried backside rest button but icant
Press and hold the reset button for about 20 seconds, it should reset.
Dec 27, 2012 | Raritan Computer DKX2-108-PAC - Raritan...
Electric window wont stay up
It sounds like you may have a bad switch. It could possibly be removed, cleaned and reassembled/ reinstalled and work fine, otherwise it will have to be replaced.
Mar 13, 2017 | 2003 Saab 9-3
Isuzu trooper 2001 battery replaced and key fob does not work with door locks but responds with 5 beeps when lock button is pushed. What might be the problem here. Thanks RJ
possibly it still thinks a door is open check out rear cargo door switch this is usually the culprit because its seperate from the rest of the doors. turn on rear cargo light to doors ,make sure it works then shut rear cargo door and see if light is still on. if light is still on theres your problem.
look at switch usually they get dammaged/distorted over time.
Feb 21, 2011 | 2001 Isuzu Trooper
How do i turn on my computer?
There are many different models of MacBook, most have the power button on the right side of the palm rest up by the screen. If you are pushing this button and there is no response, try removing the battery, remove the ac adapter and press the power button for 15 seconds. Plug in the battery and power adapter and try the button again.
Jun 10, 2010 | Apple MacBook Pro PC Notebook
Need to replace keyboard in HP Pavilion dv6626us Entertainment Notebook PC. thanks
Turn the computer off and close the computer lid.
Remove the battery and the AC power supply.
1st we need to remove the switch cover or keyboard bezel. This is plastic strip that runs above the keyboard.
Turn the computer upside down with the front panel towards you.
Remove the three Phillips screws that secure the switch cover to the computer.
Turn the computer display-side up with the front toward you.
Open the computer as far as possible.
Lift the rear edge of the switch cover and swing it forward until it rests on the keyboard.
Release the zero insertion force (ZIF) connector to which the LED board cable is connected and disconnect the cable from the LED board.
Remove the switch cover.
Now remove the panel directly above the battery compartment and remove the 2 keyboard screws there and another 2 screw in the battery compartment (they should me marked with icons of keyboards)
Turn the computer display-side up with the front panel towards you.
Lift the rear edge of the keyboard until it rests at an angle.
Slide the keyboard back to disengage the tabs on the front edge of the keyboard from the top cover.
Swing the keyboard forward until it rests on the palm rest.
Release the ZIF connector to which the keyboard cable is connected and disconnect the keyboard cable from the system board.
Remove the keyboard.
Just reverse the procedures to replace everything.
Good luck.
Sep 17, 2009 | HP Computers & Internet
Mu rear liftgate will not lock with the fob or the key. All other doors work fine.
is it possible there is a "lockout button " or switch that has been activated-either in the glove box, on the floor next to drivers seat(near door opening) or even inside the center console where u would rest your elbow?? THIS BUTTON/SWITCH would prevent key/fob from unlocking liftgate. ALSO CHECK to make sure that ther is nothing caught(fabric/clothes) near the LATCH WHERE LIFTGATE ENGAGES. this can definitely cause a problem!
Sep 14, 2009 | Toyota Sequoia Cars & Trucks
Power windows don't work
check your driver switch's(main) window lock feature button...Possible moisture inside, stuck or electrically damaged. The entire switch will need to be replaced if this is the problem. Hopefully this helps
Jul 30, 2009 | 2002 Toyota Camry
Power plug on laptop not working
Before you begin any removal or installation procedures:
1. Shut down the computer. If you are unsure whether the computer is off or in hibernation, turn the computer on, and then shut it down through the operating system1.gif.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power cord.
4. Remove the battery by following these steps:
a. Turn the computer upside down with the front panel
toward you.
Close the computer.
3. Turn the computer upside down with the front panel
toward you.
4. Remove the three Phillips PM2.5×5.0 screws that secure
5. Turn the computer display-side up with the front toward you.
6. Open the computer as far as possible.
7. Lift the rear edge of the switch cover and swing it forward
8. Release the zero insertion force (ZIF) connector 1 to which
the LED board cable is connected and disconnect the cable 2
from the LED board.
9. Remove the switch cover.
Remove the Keyboard:
Remove the four Phillips PM2.5×7.0 screws that secure the keyboard to the computer.
toward you.
5. Open the computer as far as possible.
6. Lift the rear edge of the keyboard 1 until it rests at an angle.
7. Slide the keyboard 2 back to disengage the tabs on the front
8. Swing the keyboard 3 forward until it rests on the palm rest.
Release the ZIF connector 1 to which the keyboard cable is connected and disconnect the keyboard cable 2 from the system board.
10. Remove the keyboard.
Remove the Speaker Assembly:
Disconnect the speaker assembly cable 1 from the power button board.
5. Remove the two Phillips PM2.5×4.0 screws 2 that secure the speaker assembly to the computer.
6. Remove the speaker assembly 3.
Reverse directions to replace everything.
Feb 05, 2008 | AMD BALANCE A535 NOTEBOOK MOTHERBOARD WITH...
Altec Lansing speakers in laptop
It seems as though the speakers wire connector may have become loose or disconnected. You will have to remove the switch cover above the Keyboard to check. Here is the typical instructions for removing it:
1. Shut down the computer. If you are unsure whether the computer is off or in hibernation, turn the computer on, and then shut it down through the operating system.
toward you.
Close the computer.
toward you.
from the LED board.
toward you.
http://static.tigerdirect.com/pdf/HP_Pavillion_dv6000_MnS.pdf
Jan 14, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
22 people viewed this question
Top AMD Computers & Internet Experts
David
David
rafnix
rafnix
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
