Question about Vector 955 Radar Detector
No sounds at all. As if it in on "mute". Light is on and modes function fine.
Mute light flashing
Is the amp otherwise functional? If not- check to make sure the speakers are hooked up and not shorted.
If it is functional and on AM or FM mode, it may just be the station signal is not adequately centered so part of the carrier is not being detected by the PLL and the between station muting is kicking in.
Oct 29, 2012 | Marantz PM-15S1 2-Channel Amplifier
I have a Clarion XMD3 am/fm marine cd player that came with my 2000 Searay boat. I was somehow able to turn the inside cabin speakers off last season and only have the outside speakers on. I must have...
Might be set on mute !
Mute instructions
Use this function to turn off the sound immediately.
1. Press the [ M ] button.
The sound turns off and "MUTE" appears in the display.
2. Press the [ M ] button again to cancel the mute mode
in this other user manual it is a mute button[m] page 4
http://www.clarion.com/us/en/MungoBlobs/552/388/XMD3.pdf
or
Adjusting the fader
1. Press the [ A-M ] button and select "FAD 0".
2. Press the [ w ] button emphasizes the sound from the front
speaker, press the [ z ] button emphasizes the sound from the
rear speaker.
? The factory default setting is "FAD 0". (Adjustment range: F12 to
R12)
3. When the adjustment is complete, press the [ A-M ] button
several times until the function mode is reached
May 04, 2017 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
Auto muting on when on am/fm and no sounds come out. everything else is fine.
That's normal.
The Auto Muting mode mutes the audio output of the tuner if the station is not sufficciently strong to be accurately tuned. Otherwise you would hear all that interstation hash noise.
Press the FM Mode button to change it to Mono if you want to manually tune a hard-to-reach station. It will be in Mono.
Page 26:
AUTO MUTING
Normally select this.
When a program is broadcast in stereo, you will hear stereo sound; when in monaural, you will hear monaural sound.
This mode is also useful to suppress static noise between stations. The AUTO MUTING indicator lights up on the display.
Mar 31, 2010 | JVC RX-D205 7.1 Channels Receiver
Lost the sound on my compaq key board has a orange light on by the mute button but i can't get the light to turn off
That definitely means the sound is muted, is the rest of the keyboard functional? I believe there is an option to turn off the mute in control panel under hardware and sound. However, I am unsure.
Mar 19, 2010 | Compaq Presario 5000 PC Desktop
Backround sound is fine but voices speaking are muted
I'm not sure of this system but if this was mine I would say it sounds like your playing this in a 2-Channel mode which eliminate the center channel.
you music may be set up fine, but the mode you play a dvd in may be set up for 2-channel mode. try a dolby prologic 5-channel or some other mode if you have one.
Mike
Oct 18, 2009 | Audio Players & Recorders
My Jabra BT500 is on mute. Callers can not hear me. It worked fine at first now nothing.
When powered up and in "talk" mode (during a call) hold the volume up and down "bumps" simultaneously. This engages/disengages the headset's mute function.... Hope this helps...
Mar 08, 2008 | Jabra BT500 Wireless Headset
No Sound
The camcorder may be in what may be called "narration mode." This function mutes the playback audio so you can narrate with you own voice when playing tapes back. Check for a function like this in the playback sound menu.
Nov 06, 2007 | Panasonic NV-DS60 Mini DV Digital...
Yamaha RX-V793 flashing light on volume control and no volume
Per Yamaha support page: The volume light on my Yamaha AV receiver is flashing, what does this mean ? The "MUTE" function on your remote control has been activated. The reason that you can still hear a very low sound is that the muting circuit within your stereo is not a full mute, but rather a -20dB mute. To deactivate the "MUTE" function, simply press the "MUTE" button on your remote control. (Make sure the volume control is turned down to avoid damage to your system.) If you misplace or lose your remote control, you will have to purchase a new remote control unit, as there is no duplicate function on the front panel of your stereo. Unplugging the stereo will not deactivate the muting circuit, as the microprocessor "remembers" if the muting circuit was active prior to being turned off or unplugged. If you need to purchase a remote control, you may order one directly from our parts office. You may reach them by dialing (714) 522-9888 from 8 am to 3 p.m. Pacific Time, Monday through Friday. If you have any other questions, please contact our customer service department by dialing (800) 292-2982 Monday through Friday from 8:00 a.m. to 4:00 p.m.
Sep 03, 2006 | Yamaha RX-V793
Vector 955 Radar Detector Logo
Top Beltronics Vehicle Parts & Accessories Experts
John Nolan
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
