Question about LG 24 in. LDS 5811 Built-in Dishwasher
Error Code I just put my dishwasher for a cycle. It started making some weird noises during the rinse cycle and now it came up with a code LE. What does this mean??? Please help.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
LE stands for a locked motor. If the motor has gone it has to be replaced. In some case though, depending on the age of your unit, it could be a broken wire in the door. If you remove your front panel (6 screws) you can have a look, but turn off the power first. Alternatively you can call for a service call.
With the noise, it could also be that your unit has been siphoning and as a result the motor has burnt out. The proper water level for these unit is the water should be up to the second rim on the inside of the cabinet.
Sgt 48
Posted on Jun 02, 2008
Machine Running noisy during cycle
lift off spray arm and remove motor rotor and remove any debri this can cause a noisey motor.
Sep 04, 2012 | Fisher and Paykel 24 in. DD603H W Built-in...
I got the 'LE' error code for the LG LDF6810ST dishwasher.The serial number is 604KW02152. I removed the door cover as some of the other solutions suggested, but the wires looked fine. I was...
This error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Jun 29, 2011 | LG LDF6810ST Stainless Steel Built-in...
Loud squeeling sound during wash cycle, and sanitary rinse
If you’re hearing a fast knocking sound, then it is your motor going bad. This will result in an LE code and the unit will no longer work as this gets worse.
You can get a replacement sump assembly that has the motor and all new sensors to resolve this issue.
Good Luck.
Jul 23, 2010 | LG LDS4821BB 24 in Builtin Dishwasher
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
Error code LE and OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Apr 12, 2009 | LG LDF8812 Stainless Steel Built-in...
LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Oct 22, 2008 | LG LDF6810ST Stainless Steel Built-in...
Lg wm2032hw
check the pump filter and if necessary clean it up.
if you stop the programme and hold the start/ pause button for 3-5 sec the programme will cancelled and the drain will work.
if you hear a slow noise from the pump it may be blocked with external objects from your clouthes pocket,
so you need to contact a repairman.
Jan 28, 2008 | LG WD-1280FHD Front Load Washer
LE ERROR CODE
This new....just call out LG to repair under warenty!!
Jul 22, 2007 | LG LDF6810 Built-in Dishwasher
LG 24 in. LDS 5811 Built-in Dishwasher Logo
119 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
