Question about Whirlpool AD50USS Dehumidifier
I've had the dehumidifier since Sept. 2006 and worked fine until recently I noticed more noise and discovered that it was frozen up. I turn it off to clear the ice, but now it freezes up in about three or four hours. It's located in the basement and the temp. is about 70 degrees.
  • Anonymous Jun 05, 2008
    I have had a dehumidifier Whirlpool model AD50USS2 for less than one year and it won't pull any moisture from the air. Tried cleaning filter but did not work.
    Genius:
  • 1,073 Answers
The unit has a sealed system leak that has to be repaired by a whirlpool servicer
Posted on May 06, 2008
This model is being recalled faster than high school sex-most are duds withing 6 months
Posted on Aug 25, 2008
Pause light is constantly flashing
Pause is not a term ive seen on a dehumidifier , but one would assume that its waiting for something to occur in that mode , and with these the only logicial reason to wait is to "wait" for Moisture to return to room , maybe your room has been voided of %rh to the setting on unit and its waiting for more water to return ??
Dec 13, 2014 | Dehumidifiers
Haier 45-pint dehumidifier unit cannot be turned on. It has been running fine last few days.
The first thing that comes to mind, is have you emptied the water collection bucket recently? If so, be sure that the bucket was properly reinstalled and is making contact with the bucket safety removal switch.
If you haven't emptied the bucket in the past few days, it may simply be full and will not start until it's emptied.
Hope this helped you and thanks for choosing FixYa.
Sep 13, 2011 | Haier 45-Pint Dehumidifier
Our Friedrich D50C humidifier is six years old. Worked great until a week ago it seems to turn on- then an unordinary noise occurs and moisture is not pulled out.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 04, 2011 | Friedrich D50C Dehumidifier
I have had the Whirlpool GOld dehumidifier for 4 years. It was working great. Recently, I noticed that it stopped working. When plugged it, it trips my GFI socket. I have tried various outlets and checked...
Obviously, there is an electrical short within the unit. Should it be repaired? Yes, if you want continue using it. But, is the cost of troubleshooting, finding the necessary part and repairing it worth it? Most of the time, the cost to repair a dehumidifier is about the same, as what a new one would cost. Now, if purchased an extended warranty, when you originally bought the unit 4 years ago, then you're probably covered for the repair.
In the end, the decision is yours to make.
May 26, 2011 | Whirlpool Dehumidifiers
It will not run.It cuts on then cuts off. There is plenty of moisture in the air, so it's not the lack of humidity. Any help would be appreciated
Yes, you're right. There's probably enough humidity. But, the level that you have the dehumidifier set on is to high. Please understand, the percentage on the LCD screen is what the humidifier is the humidity that it will maintain, not what it will remove. If it's set on say, 65% or higher, it's not going to remove anything. That's why it turns ON and then OFF. It needs to be set lower than 50%. Probably more like 45%, then when it turns ON, it will continue to run until the humidity level reaches 45% or the unit shuts OFF, because the bucket is full.
I had a previous questioner recently, who after reading what I just told you, said, "Now, I've got it. It works opposite of a refrigerator?" Which is a perfect analogy.
Let me know if it works for you. Thanks.
May 07, 2011 | Haier 45-Pint Dehumidifier
Ice on dehumidifier coils
most likley low on freeon gets colder when it leaks out stat could be not working correctly
May 10, 2009 | Frigidaire FDL50R1 Dehumidifier
DH30 Dehumidifier Compressor Does not Operate
I just picked one up at a tag sale, seller said it worked sometimes. Seems to have the same problem as yours. I took the time to tweak all of the connections and then re-soldered the control board with no luck. I finally disconnected the humidity control and it worked fine. By disconnecting the humidity control the unit defaults to it's highest setting and you have to unplug the unit to turn it off. Conclusion so far is that the humidity control rheostat is bad.
Note: Now while running the fan runs continuously and the compressor cycles on and off every 10 to 15 minutes. This may to be normal since the unit appears to be doing its job and I'm not sure how it is supposed to run since a purchased it broken.
Aug 05, 2007 | LG DH30 GoldStar Dehumidifier
Dehumidifier does not collect water.
My unit does not collect water any more. It was fine until I lent it to my brother in law and it was returned damaged. Do you know how to fix this
Dec 06, 2006 | Kenmore 54501 Dehumidifier
Whirlpool AD50USS Dehumidifier Logo
596 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike Squire
Mike
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
