Question about Canon PowerShot SD110 / IXUS IIs Digital Camera
My SD110 problem sounds similar...any ideas?
As of this weekend--prom pictures--the camera turns on fine but with a catch: the lens extends with a repetitive click. And the view on the screen is out of focus. It feels like something is binding up...but I don't know.
Any ideas? I need help!
Mikal
co6foot7@aol.com
  • 2,016 Answers
It sounds like the gear train that extends/retracts the lens is not meshing properly. This can happen due to dirt/debris getting in around the lens units and into the gearing, or damage to the gears due to impact (dropping the camera with the lens extended). You might try blowing some "canned air" around the lens while turning the camera on/off to see if you can dislodge the debris, but the unit probably needs repair to get it functioning correctly again. That model is about 4 years old, and for the price it was selling for in 2004, you can get a really nice new digital camera at today's prices.
Posted on May 06, 2008
The camera was dropped while it was on. The lens is stuck in the open position. When the camera is first started it sounds like tiny gears spinning but not catching. It doesn't really grind or...
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon SD cameras:http://www../Device/Canon_Powershot_SD880 or
http://www..Guide/Disassembling-Canon-PowerShot-SD800-IS-Lens-Assembly/4093/1
Also you may try this Canon "Lens Error" troubleshooting guide >>http://camerarepair.../fixing-lens-error-on-digital-camera
6.To download the complete service manual for a similar camera model can be downloaded at the link below:
http://www../canon_powershot_digital_elph_digital_ixus.pdf/download.html
Wait 10 sec and click Get Manual .At the bottom of the page.
10_8_2011_7_21_11_pm.jpgCanon SD990 IS digital camera lens with ccd parts can be purchased from eBay >>PARTS-REPAIR-/140607486728#ht_483wt_1642
Oct 08, 2011 | Canon PowerShot SD990 IS / Digital IXUS...
On my powerShot SD 800 IS-Lens won't extend and retract properly-Seems to stick-Then camera screen gives me the message "lens error" Restart camera" which does not fix the problem..The last...
Hello there.
Unfortunately this is a well known problem, which affects many models of PowerShot cameras. Llease click http://www.e18error.com/ to find out more about this problem, with instructions included on how to attempt to repair the problem.
A summary of the steps are as follows:
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras. They are not in english but have a lot of pictures which help with the process.
Hope this helps.
May 03, 2008 | Cameras
My camera Casio EX-Z800 has a lens error
Digital cameras are extremely popular. However, with many cameras you will at one point be faced with a lens problem, more commonly known as the E18 error or lens error. It manifests by thethe screen. The lens either gets stuck in the extended position, or it tries to extend, fails, and then retracts. Here are ideas on how to repair the problem:
1. Call the manufacturer and/or visit their website to see if they will repair you camera. There arewill just send it to the manufacturer and then charge you more than what the manufacturer would charge. If you are in warranty, don't go to a store, call the manufacturer first.
Repair it yourself only if your camera is out of warranty, or if the manufacturer refuses to repair it for free, which may happen if, for example, they decide the damage was caused by abuse or neglect.
2. First, make sure your camera has fresh batteries and it is in recording mode.
3. Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
4. Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
5. Another method is to tap the padded USB cover part on a hard surface, for example, a desk. Sounds simple, but it works.
6. Place the camera on it's back and look at the lens from its side. It may look slightly crooked. If this is the case, power up your camera and apply pressure gently to the side of the lens to center it. It should then extend fully.
7. Try forcing the camera lens. Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended. Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a click as it pops back into place. If the lens is stuck at an angle, put the edge of the lens not the flat front, on the edge of a table and press the lens back towards the center. It will either click back in place and work or it will break off one of the three pins that ride in the grooves of the lens barrel. Try powering the camera back on.
8. If the lens doesn't extend at all or it extends and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a click as it pops back in place. Power the camera on.
9. Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a click. If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
10. If none of the methods work, you can dismantle the camera and try to clean the lens. A good guide on dismantling Canon digital cameras with pictures can be found in the external links.
Check this article fixing-lens-error-on-digital-camera.
Keep us updated and remember to rate this answer.
May 20, 2011 | Casio EX-Z800 Digital Camera
My camera says lens error, restart camera
Keep us updated.
May 18, 2011 | Cameras
Why when opening the camera the lens will no longer extend out?
  1. First, make sure your camera has fresh batteries
  2. Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
  3. Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
  4. Another method is to tap the padded USB cover part on a hard surface, for example, a desk. Sounds simple, but it works.
  5. Place the camera on it's back and look at the lens from its side. It may look slightly crooked. If this is the case, power up your camera and apply pressure gently to the side of the lens to center it. It should then extend fully.
  6. Try forcing the camera lens. Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended. Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a click as it pops back into place. If the lens is stuck at an angle, put the edge of the lens not the flat front, on the edge of a table and press the lens back towards the center. It will either click back in place and work or it will break off one of the three pins that ride in the grooves of the lens barrel. Try powering the camera back on.
  7. If the lens doesn't extend at all or it extends and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a click as it pops back in place. Power the camera on.
  8. Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a click. If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
  9. If none of the methods work, you can dismantle the camera and try to clean the lens. You will need a professional to help you on this. If you have to idea or expertise to fix the unit, better to bring the camera to any Olympus service center.
Hope this initial info/idea helps.
Let me know for any clarifications.
Jun 23, 2010 | Olympus Camedia C-50 Zoom Digital Camera
Camera freezing up
did someone spill some pop or anything near the camera? If so, then you'll need to clean that out with rubbing alcohol
Jun 03, 2009 | Olympus FE-170 Digital Camera
Ixus 70 dropped in sand, lens error & won't close
hi jasperke,
try the following:
1) Remove the batteries from the camera, wait for a couple of minutes,then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and drycompressed air (20 lbs) set the tip between the lens turret and thecamera body and turn on the air while moving the tip around the lens.It should remove all dust and sand. Turn the camera on and it shouldfunction fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but veryoften in works.
there is a guide to dismantle it with pictures: try it:
http://www.fixya.com/support/t102982-e_18_problem
good luck!
Dec 15, 2008 | Canon IXUS V2 Digital Camera
Lens will not retract
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse. Good luck!
Sep 11, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
Wierd Images in Viewfinder and Photos
sounds like ccd sensor faulty.the only thing you can try as you say fault happened when lens got jammed is to reset camera by removing batteries for a few secs and reinserting,if this does not work will have to go to service.,
May 11, 2007 | Canon PowerShot S1 IS Digital Camera
Canon PowerShot SD110 / IXUS IIs Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
