Question about Toshiba Office Equipment & Supplies
When making copies, the image has shifted downward about an inch.
  • 52 Answers
Please when you u are sending prolems indicate the model number of the machine, the problem is from the plate that hold the glass check the belt and the motor attached to the plate
Posted on Aug 26, 2010
How to replace imaginging on bizhub 35
Open the front door/cover.Slightly push down the imaging unit which you want to replace.Pull the imaging unit outward, make sure first push it downward then pull it out towards yourself.Imaging unit will come out easily.After doing this, open up the new imaging unit.Remove its covering.Now put it straight, Green drum should be downward.Fit it to the machine from where you pulled out the old one.There are sliding at both side of imaging unit.make sure it sits perfectly in the machine gap.after inserting the imaging unit push it inward until it stops.If you heard a clicking sound then it means imaging unit has been fitted.
Jan 14, 2012 | Konica Minolta bizhub C250 All-In-One...
Fault/error a fault has occured switch off the machine . ensure that the screen desappears before swithing it on. it the problem persists,call for service. 124-315
Solution : Perform an Automatic Gradation Adjustment (Color Calibration) Automatic Gradation Adjustment compensates for tones when the color tones shift in color copies / prints. Compensating for color tones maintains the quality of color copies / prints made by the machine at a fixed level.
NOTE: Output of the Automatic Gradation Adjustment chart is added to the metered copy count.
NOTE: When Gradation Adjustment is selected, the following changes will be made to default copy settings set in System Settings mode:
  • Copy Density = Normal or Auto
  • Color Shift =Normal
  • Saturation = Normal
  • Color Balance = 0
  • Sharpness = 0
  1. Press the [Access] button (key symbol) on the Control Panel. The Access button is located above the number "3" on the numeric keypad.
  2. Using the numeric keypad, enter your administrator password and select [Confirm] on the Touch Screen. The System Administration Menu screen will be displayed.
    NOTE: If you do not know the password, contact your administrator. The initial password at machine install is 11111. If the administrator encounters a problem with changing the password, or forgets the password, a service call must be placed.
  3. Select [System Settings]. The System Settings screen will be displayed.
  4. Select [System Settings] again.
  5. Select [Common Settings].
  6. Select [Image Quality]. The Image Quality Adjustment screen displays.
  7. Select [Automatic Gradation Adjustment].
  8. Load 8.5 x 11 inch (216 mm x 279 mm) or A4 (210 mm x 297 mm / 8.3 x 11.7 inch) paper in Tray 5 (Bypass Tray). Adjust the paper tray edge guide so that the guide gently touches the edge of the paper stack.
  9. Select the desired gradation adjustment screen.
  10. Press [Start]. The Adjustment Chart is output.
    NOTE: When printing the color chart for Auto Gradation and you get the message,'Auto Graduation Procedure has completed with an error' make sure that 8.5 x 11 inch (216 mm x 279 mm) paper is loaded into Tray 5 Long Edge Feed (LEF).
  11. Place the Adjustment Chart face-down on the Document Glass with both the Magenta color patches against the left side of the glass.
  12. Place 5 sheets of white paper on top of the Adjustment Chart and close the Document Glass Cover.
  13. Press [Start].
  14. To continue Automatic Gradation Adjustment with other screens, repeat steps 6 to 10. When you are finished, select [Close] until the System Settings screen is displayed.
  15. Select [Exit] to exit the System Settings mode.
Hope it helps!
May 02, 2011 | Xerox CopyCentre C128 Copier
Cyan and majenta tone is not good
  • Color Balance = 0
  • Sharpness = 0
  13. Press [Start].
Hope it helps!
May 01, 2011 | Xerox WorkCentre M-24 Color Copier
MY COPIER WONT COPY THE ENTIRE IMAGE, MISSING ABOUT 3/4" OF TEXT ON RIGHT HAND OF PAGES
Ensure that you do not have image shift or border erase activated.
Also many copiers will not copy 'edge to edge' as they require a void lead edge to ensure that the copy does not jam in the fuser unit and a void tail egde to ensure that the same is true when duplexing.This adjustment should be done by a qualified technician.Also make sure that your original is not larger than your copy paper as you will have to reduce the image.
Oct 10, 2009 | Sharp AL-1655CS Copier
Entire image shifted
Press the Select/Auto button. The monitor will then automatically adjust to match the incoming signal and will save that setting in the internal memory of the monitor.
Nov 06, 2008 | Hyundai L90D+ 19" LCD Monitor
HOW CAN I STOP THE COPIES FROM SHIFTING EVERYTIME?
Wide blank area on Lead Edge, or Misregistration possibly accompanied by noise. The noise may be described as a clicking, buzzing noise while making copies. The noise may stop for short periods while making copies. Cause:
The registration Sol. pawl is not capturing the clutch to keep it from turning. This is caused by the Registration Sol. return spring being out of position, or when installing the Main Drive Assy., the pawl is "trapped" in the actuated position.
Apr 16, 2008 | Xerox WorkCentre XD120F Laser Printer
Image wrap with adf
You have to reinitialize the software. I will be back in a few minutes with the procedure. I have to hunt it up.
Jan 23, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
23 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
