Question about Primera Technology Bravo Pro Disc Publisher-DVD (BRAVODVDPRO) Burner
Disc Publisher says unable to communicate after changing the computers domain.
Unable to create Google account with custom domain
If you unable to create Google account with your own domain name then visit my blog where you can get all information in detail
You can also contact Google support phone number for more information. How Do Create Gmail Account With My Own Domain Name
Dec 14, 2017 | Google Computers & Internet
Unable to log in and can't change Domain?
Log on with local admin account. When you can't do it, you have to reconncet it to the domain and take it out of the domain otherwise new installation.
Jul 27, 2012 | Dell OPTIPLEX 745 PC Desktop
We have a KM bizhub 250, and we upgraded our server to a SBS 2008 Server. Now our scanning is not working. What could be the problem?
If this server is also a domain controler that is usually caused by the following setting:
Microsoft Network Server: Digitally Sign Communications (Always), The default setting for domain controllers is enabled, for others is not configured or disabled. This usually causes problems when acessing the share from devices are not cable of Digitally Sign Communications, like some multifunctionals/scanners or linux machines. This does not happen on all machines since some are capable of Digitally Sign Communications. Usually older machines have this issue.
So, try to disable this setting on the server, on the Domain controller security policy and Default Domain Policy.
Administrative Tools
Local Policies
Security options
Microsoft Network Server: Digitally signed communication (always) -> should be changed to DISABLE
Execute Gpupdate /force or reboot the server to apply the policy change
You will not be able to change this setting trough gpedit , local computer policy since it is overrided by the Domain security policy.
On server 2008 one way to get there is the following:
Server Manager
Features
Group Policy Manager
Forest: ...
Computer configuration
Policies
Windows Settings
Security Settings
Local Policies
Security Options
- Define This Policy
- Disabled
Execute Gpupdate /force or reboot to apply policy
Trough gpedit you will be able to see the option but not change it, so I suggest that after the change you cannot scan to the folder check trough gpedit if it is disabled.
If it is not disabled, disable it at the top of the hierarchy. Something may be overriding the setting.
If it still does not work try the following, togheter with the previous setting
Domain member: Digitally encrypt or sign secure channel data (always) -> disabled
Dont forget to execute Gpupdate /force or reboot to apply policy each time you change something.
Also
are you scanning to the server using \\server_ip_address\shared_folder or \\server_name\shared_folder?
Just wondering about name resolution.
Is the domain field configured in the machine? if not you might have to specify the user for authentication like for example: user@domain.local
Dec 23, 2010 | Konica Minolta bizhub C250 All-In-One...
Domain controller is down or otherwise unavailable.
Hiii
Ok after assiging a workgroup to the domain, plz make sure u gpupdate ur system , certain times it does take 60mins for changes to take effect.
Regards.
Sep 08, 2009 | Microsoft Windows Server Standard 2003 for...
JN763. Access rejected from your IP address.
Jul 27, 2009 | Computers & Internet
Can't connect to internet- wired network -2nd computer works fine - OS XP
I have installed intex 8139D RTL lan card drivers are installed.in divice manager it will showing the device is enabled. And it will showing lan is connected. but when i change from workgroup to Domain it will showing an error message. to communicate with domain.How to solve this problem.
Jul 05, 2009 | D-Link DFE-530TXP Network Adapter
Unable to open a Publisher file a second time without rebooting PC
have you upgraded from xp to vista since you installed the microsoft publisher?
it sounds like your publisher is not closing the prior instance running. you can bring up the task manager and watch what is happening when you open and close instances in publisher. in task manager click on processes and watch what comes and goes as you work with publisher.
then if it continues, i would reinstall you publisher all together. the consensus among the gurus is it will running but it 11 yrs old and may have issues that can;t be patched for vista.
May 23, 2009 | Microsoft Publisher 97 Full Version for PC
I am unable to login our domain user account.
This is usually a computer trust issue, if the computer was previously used to logon to the network and has been rebuilt or had in problems it can have trust issues. First way would be to change the computer name and add the DNS Prefix for your domain. ex desktop.abc.com to desktop1.abc.com. when prompted it is best to use the domain admin or equivalent to make the change and then reboot.
Jan 28, 2009 | Microsoft Windows Server Standard 2003 for...
Windows cannot connect domain either domain controller is down or otherwise unavailable or because your computer was not found
The resolution and workaround to solve the error is as below.
  1. Login to the Windows 2003 domain controller, and delete the computer account object from the Active Directory by using Microsoft Management Console (MMC) which you can always access from “Manage Your Server”.
  2. Log-in to the PC workstation as local administrator. If you cannot logon as local administrator, try to unplug the network cable and logon to the computer by using a domain administrator user that used to logon on the PC before, by using cached logon credentials feature.
  3. Go to Control Panel, then click on System icon, then go to Computer Name tab.
  4. Unjoin the computer from the domain by clicking on “Change”. You should see that Domain button is now selected. Remember your domain name in the text box. Select (Click) on “Workgroup” to remove the computer from the domain, and put any workgroup name in the text box (e.g. workgroup).
  5. Click OK to exit.
  6. Restart the computer (optional)
  7. Go back to the Control Panel, launch System properties and then go to Computer Name tab, and click on “Change”.
  8. Rejoin the domain by uncheck the Workgroup button and select (check) Domain button, and put in the domain name noted above into the text box.
  9. Click OK to exit.
  10. Reboot the PC.
This should solve the unable to logon to domain error, without changing or losing the user profiles on AD.
Dec 18, 2008 | Microsoft Windows Server Standard 2003 for...
Dns error
DNS = Domain Name Server
This is a set of specialized servers on the Internet, needed to
translate user friendly internet address such as:
www.microsoft.com
into their binary IP address equivalents, such as:
www.microsoft.com =
207.46.192.254 = (IP address)
$CF 2E C0 FE = (hexadecimal)
1100 1111 0010 1110 1100 0000 1111 1110 (binary)
In order to communicate with Microsoft, your computer
first sends a request to the closest DNS server to resolve
the domain name into a binary address. Once it gets the
binary address of Microsoft, in then prefixes every packet
with a 32-bit destination address, followed by it own 32-bit
return address.
Other specialized computers on the Internet, called routers,
than manage the actual data transfers on a skip by skip basis.
A DNS error means that your computer is either unable to reach
the pre-determined DNS server, or the server is unable to resolve
the particular address due to a non-existent WEB site or a
spelling mistake.
The actual meaning of the message depends on which layer
of the internet protocol in your computer, (or outside of it)
generated it.
Martin.
May 08, 2008 | Computers & Internet
Computers & Internet Logo
184 people viewed this question
Top Primera Technology Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
ray gallant
Terry Hair
Are you a Primera Technology Computer and Internet Expert? Answer questions, earn points and help others
