Question about NetGear SPH150D SKYPE CORDLESS HANDSET IP Wireless Phone
Netgear SPH200D Skype phone cannot register new handset with base
5 Suggested Answers
SOURCE: sph200d not getting ip address from router
I had the same problem. I set up a static address instead and it works very well. I just copied the details form my laptop, diabled the laptop and set up the phone with the same details as I had on my laptop. Once I start the laptop again, it will get another address. --Jonas
Posted on Feb 03, 2009
anandg27
  • 1272 Answers
SOURCE: cannot change skype username of user of phone
Please note that when you turn on the Skype Phone, it prompts you to connect to the wireless network. After connecting it to the network, It will prompt you for your Skype login and password.
You can enter the required login credentials here. IF you have set the auromatic Sign in option on the phone then you can change it by going to Settings menu and then to General .
Please rate, If it helps.
Posted on Jun 23, 2009
merva147
  • 79 Answers
SOURCE: netgear skype phone
try to make hard reset to the phone if not tham download the skype program from the site and insert it to the phone
daniel
http://rylwy.com/
Posted on Aug 14, 2009
SOURCE: How do i reset philips voip4332b ip phone base unit to company default.
This should solve your problem:
1. On your phone select: Menu > System > Base Select
Select "Auto" and press "ok"
2. On your phone select: Menu > System > Register
(you might be prompted to enter a PIN if so the default is "0000" )
3. On the base station press and hold down the  "Page" button for 4-5 secs until the green light starts to blink. At this point the phone should be now able to find the base station.
Posted on Feb 02, 2010
How do I register new handset for AT&T cordless phone el51359
1. To de-register the orphaned handsets from their old base:
When the orphaned handset says "Connecting..."
enter *331734 [menu]
and it will soon beep and display "Not registered"
2. To register the new handset to your base:
press the "Handset Locator" button on the base and hold
it until the "in use" light comes on ( ~ 4 seconds ),
then release the button and set the new handset into
the base phone cradle. After ~ 30 seconds it will beep
and display "Handset #" (next in sequence).
3: Note: the base handles a maximum of 12 handsets.
If your system was fully populated ( ie, a handset is
already # 12 ) you will have to clear all the handsets
from the base and re-register them all in sequence.
( it is the only way to 'rescue' the places occupied
by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button
until the "in use" light lights and then starts to blink
( ~ 10 seconds ), release the button --
then press it again briefly while the "in use" light
is still blinking.
2. The base will beep and all handsets that were registered
will display "Not Registered"
3. Follow the instructions above for each handset
in turn to re-register them:
press "Handset Locator" ~ 4sec ( in-use light on ),
set handset into the base cradle, etc.
The manual is available from: www.manualslib.com
but does not fully describe these procedures.
Good luck !
Dec 30, 2015 | AT&T Lands Phones
How to register additional handset for AT&T EL52300
Easy to do, even if the new handset is used & orphaned from
its original base...simply de-register it from the old base and
re-register it to your base.
1. To de-register the orphaned handset from the old base:
When the orphaned handset says "Connecting..." or "Out of..."
is still blinking.
Good luck !
Mar 04, 2015 | AT&T El52300 Cordless Phone
My cordless phone says "to register see owners manual for help" How do I get the phone working, it is a uniden DECT 6.0 Model DECT 1588-2
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
Dec 21, 2009 | Uniden DECT 6.0 Cordless Telephone...
MY NETGEAR SPH 200D IP PHONE NOT CNNECTIONG TO INTERNET . I GET MESSAGE SYSTEM STARTING UP BUT NEVER WORKS. I DONOT HAVE INSTALLATION CD
Follow the steps below to resolve the issue:
1. Disconnect the power to the base station.
2. Remove the batteries from the handset - leave them out for a few minutes and when you replace them, don't try to turn the handset on: just put it in the charger base and leave it for 15 minutes or so.
3. Plug in the power to the base station and leave it for a minute to settle down.
4. Take the handset out of the cradle and turn it on.
Rate it, if it helps.
Apr 13, 2009 | NetGear SPH200D IP Wireless Phone
Sph200d not getting ip address from router
Jul 23, 2008 | NetGear SPH200D IP Wireless Phone
Sph200D phone - can't make landline calls or answer incoming landline calls...
-- First u can change the ADSl filter.
-- And then check that its working or not..
-- then u can resett the SPH150D and reconfigure the device..
In case of any queries feel free to get in touch with me...
Jun 15, 2008 | NetGear SPH150D SKYPE CORDLESS HANDSET IP...
Unable to register my phone
You can reset it by doing this
1. Press Menu>Settings>Advanced>Reset Device.
2. Scroll and select either Reset All or Keep Network.
hope these helps
May 03, 2008 | NetGear SPH200D IP Wireless Phone
No sounds after starting the connection
Check whether you have accidently got the mute button on
Apr 10, 2008 | NetGear SPH200D IP Wireless Phone
Phone rings, but once answered its not possible to hear a voice.
Similar issue - brand new phone - but incoming calls (skype or landline) would ring - and then nothing, and outgoing calls the handset would just reset.
The handset would just lose signal constantly (less than 2 meters from the base station).
The phone shipped with the latest software - but eventually I reinstalled it - no change, then de-registered the handset, powered everything down and re-registered the handset and that *seems* to have done it .....
So
1 - reflash / re-install latest software from philips website (even if the phone already has the same version)
2 - de-register handset (follow instructions)
3 - unplug base station and remove batteries from handset
4 - turn on base station, put batteries in handset
5 - re register handset (follow instructions in manual)
and that seems to do it.
Nov 18, 2007 | Philips VOIP8411B/37 IP Phone
Logitech internet handset "UNAVAILABLE" error
Mine was working fine at one point. I had been using it the night before without issue. However later on when I went to make a call the next day the handset said Disconnected.
Any Skype functions said "Unavailable". Rebooting the PC, Restarting the Headset Software and Skype didn't fix the issue.
The fix for mine was to go into "Menu" then "System" on the Handset and do a reset. Soon as it was done, the Skype info popped backup on the handset and it was fixed.
For those who haven't changed it, the default PIN on these handsets is 0000 <-- Zero's
Oct 03, 2007 | Logitech Cordless Internet Handset Phone
NetGear SPH150D SKYPE CORDLESS HANDSET IP Wireless Phone Logo
103 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
