Question about Samsung Digimax D53 Digital Camera
Low battery display
Turn on camera and it immediately displays low battery, dings 4 times and shuts off, even with new batteriesl.
  • chaseraff1 May 12, 2008
    yeah the same thing happend to me.
    whenever i turn on the D53 after about 20 seconds it says "low battery" and beeps 4 times.
    what do i do?
  • Camera84 May 12, 2008
    turn on camera and it immediately displays low battery, dings 4 times and shuts off, even with new batteriesl.
I had a similar problem...my lense woudnt go back in either, but it kept saying low battery and bleeping. I realised that my lense was stuck skwint, and that was what was causing the problem, once i straigtend up my lense it folded bak into the camera and worked fine wen i turned my camera on :D
Posted on May 15, 2008
Yashica com
Depending of what you use, always be sure all batteries are the same, charged and suited for your camera. Most of the time even new Ni-CD rechargeable batteries won't work, because the voltage is to low, according to NiMH or alkaline batteries.
Always charge NiMH batteries before using them for the first time, or if they have not been used for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera.
Jan 03, 2014 | Cameras
Lens stuck open
hey, I had the same problem when I accidentally droped my camera, some parts in the mechanism are probably broken or jammed.
Most likely repairs required.
Apr 13, 2008 | Samsung Digimax S600 Digital Camera
Low battery
The manual says:
The camera turns off immediately even when battery power is full.
The remaining battery power is low even if new batteries are inserted.
•The remaining battery power may not be displayed accurately, and the camera may suddenly stop working, when the type of battery and the settings on [BATTERY TYPE] are not identical. However this is not a malfunction. Depending on the battery
brand and the operating temperature, or if exhausted batteries are used, the remaining battery power may not be displayed accurately.
and:
Use sufficiently charged batteries when using Ni-MH batteries.
You also should set the correct battery type in the setup menu. So put in alkaline / NiMH or oxyride. According to what you are using.
Before you panic, buy a set of alkaline batteries, to make sure your camera is ok. Perhaps you are using rechagable batteries who are not ok anymore.
Nov 09, 2013 | Panasonic Lumix DMC-LZ7 Digital Camera
Battery low indicator comes on even after new battery installed
I also have this problem. I put freshly recharged batteries in the DX3900 and the camera starts to turn on and reads the memory card (the green LED blinks) and then I notice that the in CAPTURE mode the lens does not extend out of the body housing. The top display shows a flashing low battery warning and after approx. 15 seconds, the camera shuts off with no function.
I have determined that the camera appears to have changed its low battery sense level as I have verified that the batteries are indeed fully charged by using a volt meter. If I have the camera in a warm environment, and do not have the LCD display on (removes a major power drain) the camera can be made to work for a short while. If I select the LCD to turn on, the extra drain seems to cause the camera's battery monitor to think that the battery voltage is too low and the camera shut down. I have yet to resolve this issue.
Aug 18, 2009 | Kodak EasyShare DX3900 Zoom Digital Camera
The camera wont turn on
hi...ensure that the camera is turned on. If applicable, ensure the lens cover has been removed before taking pictures. the LCD backlight is turned on by pressing the DISPLAY button several times until the screen appears. Depending on the camera model, the DISPLAY button may be labeled as DISP or with a display icon. This button could be a standalone button or it depends upon the camera model.....
If operating the camera with a battery, ensure the battery is fully charged.
Ensure the battery is inserted properly in the camera.
If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
Ensure no Audio/Video (A/V) cables are connected for viewing pictures on a TV; the LCD screen will not display when an A/V cable is connected.
Perform a reset procedure on the camera....
Apr 04, 2009 | Kodak EasyShare C743 Digital Camera
Battery Problem
The batteries u r using for your camera are of very low rating or low ampere output, you should use atleast 2100mAhr rating batteries and you will be very much satisfied with the performance.
Regards,
Manoj Joseph
+91 9352008418
Jun 16, 2008 | Canon PowerShot A640 Digital Camera
Low battery display
go to your local walmart and but a set of nimh rechargeable batteries and let them charg when done charging install them in to you camra then hit the menu button go to the setup display and scrool down to the battery type and choose Ni-MH this will save you battery life from 5-15 min to 5-6 hrs of life.
May 06, 2008 | Samsung Digimax D53 Digital Camera
Lens stuck open
i have just had the same problem. mine was stuck open, i gave the lens a slight twist and heard a bit of a crack. i switched it on again, now it is ok.
Apr 09, 2008 | Samsung Digimax S600 Digital Camera
New Batterys and camera indicates batterys low then shuts off.
Did the batteries come with the camera? If not, they might not be a high enough mah rating. Some batteries, even though brand new, may not be strong enough to power a camera.
Dec 06, 2007 | Kodak EasyShare CX7530 Digital Camera
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
Samsung Digimax D53 Digital Camera Logo
193 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
