Bizhub c350 copier lcd screen not working, The machine was working turned off printer and then back on then the LCD didnot come back on.
    Guru:
  • 366 Answers
Hi
Reset all and try once again please ... it should work.
thanks
Posted on Aug 26, 2010
Konica minolta bizhub c350 error codes c-0510
eror code c-0098 meaning ??????????????pls tell me the solution
Jul 31, 2012 | Konica Minolta Bizhub C350 Digital Copier,...
How to fix C-0500 error for BIZHUB C350 konica minolta printer
Open the front door with the machine on, get down on the floor and look up on the right side of open area there is a slanted section in that slated section is a small hole you will not see it standing! With a small screwdrive gentle push the small switch located in side the hole that will reset the code if it comes back DO NOT RESET the copier is telling you something is wrong with the FUSER UNIT the HOT part continued reset might catch the machine on fire and that would ruin a perfectly good day. Have a qualified Tech look at it from Konica Minolta.Check this web site out for a rough idea of cost to replace the fuser.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jan 31, 2012 | Minolta Office Equipment & Supplies
How do you clear error code on a bizhub C350. A piece of paper was fused on the fuser unit and we were able to get the paper off. Now we have no access because the panel is locked.
while powering up machine hold down utility/counter key until trouble reset appears on screen. select it and ok should apper under it. power down machine for atleast 10 sec and turn machine back on.
Jul 22, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Konica minolta Bizhub C350. Following message appeared on my printer: Malfunction detected. Please call your Technical Representative and provide code: C-0F36 What does this code mean?
Hi katienash,
C-0F36 on the bizhub C350 means the machine has registered a really low toner density in the Black
Imaging Unit. I'd take the unit out, give it a shake and pop it back in. Also worth checking you have some Black Toner in it.
Good luck
Regards
m-press.biz
Jan 25, 2011 | Konica Minolta Minolta Printer stand...
Konica Bizhub C350, need to setup ip address
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start.
Dec 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Problem.
open right side door of your machine and check check all gears are working properly this code belong to main motor
Oct 26, 2008 | Office Equipment & Supplies
LCD Display displays Error C0510 Can't do anything about it.
low temperature issue. There is a trouble reset procedure that should be performed by a Minolta tek
Erroe code
You post a wrong printer nr, you must have bizhub C350 not bizhub 350, beacause 350 doesnt have that kind of code.
In Bizhub C350 that code means:
C12C0: Hard disk recognition error
You have the following options:
- reinstall the hard disk
- change hard disk
or as a last chance change PWB-MFP
good luck
Feb 06, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
71 people viewed this question
k24674
jasbo
jasbo
