Question about Nokia e65 Cellular Phone
My nokia e 65 keypad is not working .. what i do
Problem in my keypad in nokia 6070
My Dear your phone keypad ic default so please change keypad ic
and keypad problem will solved
Sep 24, 2012 | Nokia 6070 Cellular Phone
My nokia E-65 key pad light not working
these are the causes..
* might be in lose contact
* might all bulb (light) is busted (possible if series line connected each other)
* need to replace keypad flex
* need to replace light coil
if it is hard to you to fix,go to the mobile service center and ask assisitance.
if the solution helps...please rate me...thanks
Jun 03, 2011 | Nokia e65 Cellular Phone
Water problem with nokia 6300
my nokia 6300 has fall down in water then i switched off and on continuously at starting keypad worked then keypad stopped working after some time
Aug 03, 2010 | Nokia 6300 Cellular Phone
My Nokia 5200 (Number keypads) will Not Working
u need to change the key pad until then it wont work.
two keypad IC's under the keypad and next to the keypad connector unfortunately all the keypad points are linked to the IC's and so even if one key doesn't work it is related to these IC"s in question UNLESS the keypad connector is dirty or sticky please do service your phone or take it to a reliable technician
Jul 01, 2009 | Nokia 5200 Cellular Phone
Nokia 6233 Keypad NOT WORKING!!!
change keypad and use k750i see the keypad socket on up side and do some changes their
Jun 14, 2009 | Nokia 6233 Cellular Phone
SELECT KEY NOT WORKING IN NOKIA 6600
i can solve that but first ad me at my ym ken_craze
Mar 14, 2009 | Nokia 6600
Nokia keypad is not working
good day ! the problem of your phone is keypad main brain try to clean that or chagne the mainbrain ! good luck ! thanks ! ....
Sep 09, 2008 | Nokia 1600 Cellular Phone
Number 7, 8 & 9 key is not working
change your keypad or clean keypad.
Feb 21, 2008 | Nokia 6600
Keypad not working
pleace hitting the keypad driver on your phone it will not working change it.
Jul 23, 2007 | Nokia 6600
Nokia e65 Cellular Phone Logo
126 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
