Question about Kenmore 74642 Gas Dryer
Dyer heats up for about 1 minute then, no more heat.
  • Kenmore Master
  • 17,130 Answers
Check the timer , the unit is shutting off when the timer is malfunctioning. If so replace the timer after trying to bypass to confirm that the gas supply is not cut off.
Posted on Aug 26, 2010
Dyer runs with heat but shuts off after a few minutes
The heating element may be defective.
Aug 07, 2017 | Dryers
Heating problem
There is a thermal cutoff built into the dryer to protect from fires due to overheating. This could be activating after the dryer starts running for a while. Is it possible that the exhaust duct is clogged up with lint? Check the airflow at the dryer vent.
Dec 17, 2013 | GE DCVH515GF Gas Dryer
The dyer is working, but the dyer is not blowning any hot air
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 27, 2010 | Kenmore 600 7962 Dryer
Dyer is not heating maytag dryer D8000
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
rtw
Sep 02, 2010 | Maytag Dryer Lint Filter Screen 33002970
Kitckenaid dyer KGYe6778WH1 Dyer won't heat
This is most likely due to the coils on the gas valve, they can become unstable and cause the symptoms you are describing. The coil kit is part number 279834 and runs about $20.00. It is replaceable from the front and not too hard to do.
Side note: the '8' in your model number is actually a 'B'
Apr 22, 2010 | KitchenAid KGYS850LT Gas Dryer
My dyer heats and tumbles, but doesn't dry
I'd check first for clogged vent hose or clogged lint filter or clogged vent flap on wall (outside).
If that's not a problem, it may be a faulty thermostat. Heating element is probably okay if it heats some of the time.
More info, let me know.
Charlie
Oct 01, 2009 | Kenmore Dryers
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
LGR4634EQ1-DYER WILL NOT HEAT UP
Go to: RepairClinic.com
There you can troubleshoot
your appliance.
You'll need make & model #.
Nov 15, 2008 | Whirlpool LGR3624JQ Gas Dryer
I HAVE A MAYTAG ATLANTIS GAS DRYER STOPS HEATING ABOUT 5 MINUTES IN
the flame going out is normal. the heat cycles on and off as called for by the thermostat. If the heat doesn't come back on i would start by changing the gas coils.
Oct 08, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer quit heating up,timer doesn't work,this happened all at one tim
no dyer run's just does not heat up,timer never move's,which I think need's too for dyer too heat up,i could be wrong,just happened all at one time
Aug 03, 2008 | Dryers
Kenmore 74642 Gas Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
