Question about Sport & Outdoor - Others
I have a 2001 Yamaha 15 hp four stroke outboard motor that has been blowing oil though the air intake into the carb . As I rev it up it will foul the plugs . What would cause this ?
  • 662 Answers
Could you provide me the model number of the motor to assit with your query
Posted on Aug 26, 2010
  • Luke Bradford
    Luke Bradford Aug 26, 2010
    do not worry about the model number, i have done some research and it is farily common to most model types......it is called blowby.....a term for combustion gases escaping into crankcase and causing oil to be blown thorugh all vent pipes...in your case, back through the pcv system into the intake..........bad news...this is only caused by poor sealing of piston compression rings...so will require a full engine overhaul..........
    unfortunately with the high revs that an outboard goes through, it is a fairly common issue.......
    one cheat is by putting a thicker grade of oil in, but this would cause a harder to start condition, especially when cold...so i dont entirely recommend this.
How do I remove air intake screen on 15 Hp 2005 Yamaha 4 stroke outboard
Mike, why are you needing to remove the screen? Its there to prevent larger particles from entering your engine..if its stopped up, use a pressure washer to CAREFULLY clean it.. other wise leave it there.
Jul 08, 2017 | Yamaha Boating
I have a 2003 yamaha 40 hp four stroke outboard, this year started up seemed to run great after about 25 minutes i shut it down an hour later checked oil crankcase full of water
water in the engine crank case oil --major seal or corrosion problem in the motor
water in the leg gear box --
pump seal on the drive shaft
Jun 01, 2017 | Yamaha Boating
How to Clean an Outboard Carburetor?
didnt specify unit --generic answer --best way is to buy a rebuild kit [should have instructions]--carb cleaner --disconnect carb --and tear down the carb becareful their are small parts inside using cleaner cleal all parts and housing --in the rebuild kit should be instructions on putting it back together
15 minute Carburetor Cleaning Rebuild Yamaha 20HP outboard 4 stroke How to Clean an Outboard Carburetor Outboard Motor Carburetor Cleaning
Oct 20, 2016 | Boating
Where is the oil filter located on a 2004 Yamaha outboard two stroke motor
Some links including a video of how to change the filter. In such questions horsepower is useful along with year :>) Oil filters would only be on a 4 stroke though to protect the engine oil. Your two stoke doesn't have filters in the lower unit. There may be a strainer in the two stroke oil tank.
check page 31 here
http://www.yamaha-motor.com/assets/service/manuals/1/LIT-18626-07-03_1415.pdf
Google
year make HP manual
http://www.bing.com/search?q=oil+filter+located+on+a+2004+Yamaha+outboard+two+stroke+motor&form=PRHPR1&src=IE11TR&pc=EUPP_HRTS
Jul 04, 2016 | Yamaha Yamalube Outboard Oil Change Kit...
Fuel mix ratio for outboards
oil not required in a 4 cycle motor only 2 cycle requires oil mixture .
Jun 05, 2014 | Boating
Free outboard repair manuals
very basic carbs ! clean all jets and emulsion tube then check the float needle is clean and the tip isnt grooved , blow threw all ports etc and then refit and set the mix screw 1.5 turns out for starters then run up in a tub of water and fine tune till its happy to idle and rev up ! make of engine ??
Apr 16, 2014 | Clymer Marine Maintenance and Repair...
50 hp yamaha outboard mid 1990's
2 stroke ?? choking up do you mean ? what oil make and mixture ratio ?
May 11, 2013 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
I have a 2002 Yamaha 15 hp four stroke outboard motor that is have carburetor problems . It seems like the float valve is not working or something . It blows fuel out the top of the carb . ( that is where...
I have to same motor with the same problem. Its the injector, it gets gummed up from the ethenal in the fuel. within the carbourator there is a little pin that is stuck and then fuel spills right out the corburator. People will tell you its the diaphram but not the case. It needs a little tap on the side of carburator and will correct itself(likely).
Feb 21, 2011 | Sport & Outdoor - Others
Sport & Outdoor - Others Logo
64 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
