Question about Miele Premier-Plus Built-in Dishwasher
F14 problem with miele - Miele Premier-Plus Built-in Dishwasher
  • 177 Answers
This fault means low pump pressure in the circulation pump due to foreign particles jamming up the pump. you would need to remove the unit and tip it on it's side and remove the base plate and the pump and clear the blockage.
Posted on Aug 26, 2010
F14 fault. What do I do?
Miele Fault Codes
Different brand dishwashers have different fault codes. That said, this may well be your brand. It does list the F14 fault code as well as the others.
Jun 03, 2017 | Dishwashers
Miele g1220 dishwasher displaying F14
In my case, F14 appeared when the waste pump was not be able to exctract the waste liquids. This happened because lemon kernels (that I use to remove bad smells) has clog the non return valve and the circulation pump passage way. I followed the directions from manual to clean the valve. I found about 30 lemon kernels on the bottom of the dishwasher. After the kernels removal and valve cleaning and refitting, my dishwasher operated as usual.
Mar 11, 2012 | Dishwashers
F14 fault on Miele dishwasher
Hi
F14 means a fault on the heater pressure switch or the water intake.
It could be that either the switch is faulty or circulation pump is blocked, you can check if the pump filter is blocked
Dec 18, 2010 | Miele Dishwashers
F14 code Miele Dishwasher
This fault is low pump pressure. more than likely you have some foreign particles jammed in the circulation pump. you would have to remove the unit, tip it on its side and remove the bottom plate and remove the circulation pump and clear the blockage. the unit will start and stop and not work until the pump is clear.
Aug 14, 2010 | Miele Premier-Plus Built-in Dishwasher
F14 problem with miele dishwasher model G2270SCVI WOULD be grateful for your assistance asap as nothing in manual explains what to do. many thanks
Hi F14 is when the pump pressure switch does not operate. This can be caused by several things. Circulation motor blocked or defective. Insufficient quantity of water in appliance.Most commonly it is debris in circulation pump.This will require motor to be removed and cleaned.appliance will have to be un-installed
Jun 17, 2010 | Miele Premier-Plus Built-in Dishwasher
What is the error F14 in a Miele dishwasher ?
The error F14 in your dishwasher is due to water intake fault with heater or circulation pump, or something like that. The circulation pump would have been clogged. Try to clear it and your problem will get fixed
Apr 04, 2010 | Miele Premier-Plus Built-in Dishwasher
Machine turned itself off
F14 should be heater pressure switch fault - you pretty much have to call a service tech for this one.
Sep 07, 2009 | Miele Dishwashers
Miele Premier-Plus Built-in Dishwasher Logo
638 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
