Question about Whirlpool 3.2 cu. ft. Plus Washer
Wont spin dry completly going slow on spin only .with lid switch isolated i can easily stop drum from spinning on that cycle, every thing else works well its the 7 cycle 2 speed model thanks
  • 176 Answers
Cheng the clutsh or trans meshen
Posted on Aug 26, 2010
My Kenmore Elite Quiet pak 2 # 11045872402 HE3 washer doesn't go through the complete Cycle it stops when drain and spin,or doesn't Tumble through the cycle? could I have confused it by trying to keep
Spinning is prevented when the cover is open. Possibly a broken "door closed" switch is or its wires are broken. Lift the lid platform and check the switch. May be just debris preventing it from engaging. Remember, the lid and the close switch must be engaged before the control circuit will allow the high speed spin from happening. This is an essential safety feature and should never be circumvented. A high speed drum can literally pull an arm from its socket if caught so make sure it's working properly
Feb 16, 2017 | Kenmore Washing Machines
INDESIT WIB101 WONT SPIN
Have you checked the lid safety switch? Even if it doesn't spin, the cycle timer will continue.
Nov 16, 2013 | Washing Machines
Washing machine
check lid isolation switch. check for balance of clothes. I would go for the lid switch first. The balance second as if it starts to spin and wobbles violently it will switch itself off to prevent damage and you will have to move the clothes around to balance the drum.
May 18, 2013 | Washing Machines
My washer only runs until it's time for the rinse cycle and then it stops completely. It doesn't rinse or spin. What's going on?
hello, it sounds like a failed lid switch part #3949247 it wont rinse or spin with a bad lid switch. it also wont rinse or spin if there is no cold water to the unit.
Jun 08, 2011 | Roper RAS8445KQ Top Load Washer
Kenmore washer mdl#110.23832100 spin cycle motor
Hello, looks like your lid switch is on it's way out, replace it...you will find it normally about half way down under the lid. If not there you will find it in the control panel on the right side next to the water level control. The reason it works some times and not others is because some times it fails to push the lid switch down far enough to engage. the lid switch is a safety divice inteneded to stop you opening the lid while in a high speed spin. If you have any other questions please feel free to comment again. Mike
Oct 01, 2009 | Washing Machines
Washer won't spin. Belt is slipping. Tub is stuck.
The belt sounds worn out since its slipping. Change it out. Its cheap fix.
The drum brake does just what is sounds like. brakes the drum. For instance when u open the lid during a cycle and everything stops thats the drum engaging and stops the movement of teh drum. If the brake is malfunctioning two things will happen, you open the lid (assuming the safety switch is still good) or the drum will not spin at all.
Aug 24, 2009 | Maytag LAT3600A Top Load Washer
Kenmore 110 washer drum spins with lid open during Rinse/Spin
Slow agitator could be linked to shaft bearings going south. Pull the agitator off and check the block on top of the shaft. With everything turned off, try to turn the shaft. It should turn freely both ways. Other things to slow down the works could be a very worn drive belt from the motor.
The lid switch problem seems to be a wiring short--trace the wiring back from the switch to where ever it ends up (at the timer?). If it winds up at a relay, the contacts may be stuck together. It would be nice to have a wiring diagram--ah well. Don't know if any of this helps, good luck.
Jul 16, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Mar 10, 2009 | Kenmore Washing Machines
Kenmore 92274800 repair ... WONT SPIN
My 110.92274800 did the same thing 1hr ago. Ive isolated the Problem it is a 15.49 cent problem from the manufacturer's website Part # 285753A. I am going to order and try and tackle the problem myself unless i can find it at a local Appliance Center that has it on Monday. Will keep you informed. Doesn't look to Hard. if you lean your Washer forward you will probably find 1/8 inch white peg looking plastic pieces. assuming you can hear the motor running on the spin cycle. You may lean the unit forward put it on spin and look at the motor to make sure it is still in operation. Hope this helps
Jan 03, 2009 | Kenmore Washing Machines
Whirlpool 3.2 cu. ft. Plus Washer Logo
81 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
