Question about Bosch 36V Litheon Drill/Driver With 2 Compact Batteries
My Bosch 36v compact drill only works intermiterly, i thought this could be the bushes but have been told that there isn't any in this model. Please help somebody......
    Problem Solver:
  • 7 Answers
Definely brushes
Posted on Nov 25, 2011
SDS drill variable power
Ok about changing the brushes but have you searched if the place where the brushes are located allow the brushes to move forward freely or they are in a way were narrowed so that the brushes can only move for few millimeters?
Mar 06, 2014 | Rotary Bosch 11536vsr 36v Sds+ Roto Hammer...
Hi I've got a bosch 36 vf li and I'm struggling to open it up to change brushes. I've undone all visible screws but still struggling with top part of unit.
Have you removed the 4 gearbox screws? the cover should lift off. sometimes if a brush holder has over heated then the two halves get stuck together in places.
Dec 04, 2012 | Rotary Bosch 11536vsr 36v Sds+ Roto Hammer...
How do you change the brushes on a bosch 36 v-li
Once you have removed the 4 screws holding the gearbox to the main body take off the right hand half of the housing leaving the left half on the work bench. Unscrew the 2 screws that hold the brush holders down and remove the old brushes and refit with new ones. Rebuild in reverse.
Oct 24, 2012 | Rotary Bosch 11536vsr 36v Sds+ Roto Hammer...
I have a Bosch 36v LI cordless drill the batteries are fully charged. However, when I pull the trigger, it starts briefly and then shuts down almost acting as though It's batteries are dead. I have...
One possibility is that the trigger on your drill has a short in it. When you replaced the brushes did you clean off your commutator? I am assuming that you did. You only need to clean the brush dust off of it and ensure the copper contacts are clean. Your issue is definitely with your drill. I am not sure about Bosch but with some drills you can take apart the trigger and check for contamination. Hope this helps.
Oct 23, 2017 | Bosch Drills
I have a 36v ac 3640 cv charger with a burnt out thermistor i need to know rating for the thrmistor marked up on pcb as r2
hi mate i know its 2 years over later if u have red flashing led this normally fixes fault..replace R2 ON CHARGER,
www.uk.farnel.com then search this,,,:- B57236S500M
Mar 09, 2011 | Bosch Drills
I have te10 hilti 36v rotory hammer drill that works but slows down and cuts out under load ( jirky drilling motion), my first thoughts are the brushes any ideas?
It is more than likely the connections between the battery and the drill or the battery itself. If you look at the leads on the drill there are two large connections that can get bent along with smaller curved connection. If these connectors get bent It is hard to maintain a connection to the battery.
The 10A has not been sold in several years. I assume your batteries are old as well. Hilti has made great improvements over the years to their batterie tools. They still produce 36V hammer drills but now they are Lithium Ion batteries.
Aug 08, 2010 | Hilti Drills
How to repairreplace brushes for 36 volt bosch lion batt drill
There are black access panels on each side if the drill toward the rear. Remove the screw that holds them in, and remove the panel. This will expose the bruch holder, take a small screw driver and carefully remove the old brushes and replace them. Replace the panels.
Jan 24, 2010 | Bosch 36V Litheon Drill/Driver With 2...
Connnect drill to keyless chuck bosch 36vfl1
Push or pull the business end toward the body while gently pressing and rotating the bit into it. The chuck will snap back up to retain the bit when you have it lined up right.
Sep 19, 2009 | Bosch 36V 1" Sds - Plus Rotary Hammer
Bosch 36V Litheon Drill/Driver With 2 Compact Batteries Logo
361 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
