Question about Samsung DLP HL-P5663W 56" TV
Samsung HLN507W 50" DLP Television
My son was watching TV and said he heard a pop / explosion. Now the the TV on plays in black and white and after it is on for a little while the picture starts to get smaller and flicker. From what the little I have read it appears I need DMD board. Does anyone have experience with this problem? The boards are very expensive is there anyway to repair the board or find it a cheaper price?
Thanks,
Bill
    Genius:
  • Samsung Master
  • 1,691 Answers
Parts are from the manufacture only unless you can find a used board from a scrap set. A used board may have a lower reliability than a new one, and there will be no warranty. After changing the board, there will probably be some calibration required to match the new board.
Almost all the repairs on modern TV's are done with board swapping. This is because of the complexity of the design of the circuitry, and the way that they are assembled. These boards are using multi layer assembly, with embeded component technology with very high density surface mount technology. To troubleshoot these boards and then change parts would require very extensive instrumentation and tools that would not be feasible for any service centre.
I suggest you give the set only to an authorised service rep to have it serviced properly.
As for the DLP sets, from the statistics that I have been seeing, they are general lower in reliablity than the Plasma or LCD sets.
The DLP sets also do not produce as nice a picture because they are using projection technology rather than direct view technology. If you go in to any of the TV stores and compare them to the Plasma or LCD sets you can see the difference right away.
Jerry G.
Posted on May 06, 2008
SOURCE:
I have a Toshiba 1080i DLP hdtv.. my son & i were
the lamp exploded it happens u need to replace the lamp ensure its the exact type, the lamp is the light source and without light the dmd cannot sync colours nor pix
Jul 10, 2013 | Televison & Video
After a few minutes of being on my Samsung HLN507w dlp tv the picture will freeze and turn black and white, but the sound still works, I have to unplug the tv to reset it then it will work again for a...
This tv have a colors wheel design in it.The tv make loud grinding motor noises or pictures flashes or freeze and pictures turn in black&white with sound.The tv colors wheel it is dying or worn out already.Don't tries to change the tv colors wheel ur self.If u don't any mechanical skills,because the colors wheel it sit way back of the tv,must take out many mechanical parts before even can come to the tv colors wheel itself to replace it.Best to hire a tv tech. to change the colors wheel,so no problems for tv funstions for later or damages more parts on the tv set,if u install the new colors wheel in the tv wrong way.
May 12, 2011 | Samsung HLN507 50" Rear Projection...
I took my Samsung HLN507W apart to replace the color wheel fan... is there a schematic somewhere in the TV or online so I can now put it back together?
You Tube have video by somebody take out the old colors wheel and steps by steps and a replacement of a new colors wheel put into the DLP tv.
May 08, 2011 | Samsung HLN507 50" Rear Projection...
Buzzing noise
COLOR WHEEL OR COOLING FANS
Mar 28, 2009 | Samsung HLN507 50" Rear Projection...
HLN507W picture is in black/white what componet or board is bad
Turns out wife bought a 5 yr service plan...I didn't know about...it expires in march...WoW; what luck. Tech is 90% sure it's the color wheel
Jan 12, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung 50' DLP Tv. Is it a lamp?
there is a lamp door in the back for end users open it up and check it out, could be the color wheel exploded also
Jul 08, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Whistle noise? POP? Black out
sounds like the lamp has shattered. check the lamp
May 18, 2008 | Samsung HLN5065W 50" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
131 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
