Question about RCA D52W19 52" Rear Projection Television
Rca tv repairman states I need to replace the HV transformer and the horizontal output transistor. His quote to fix it is 225. Is this too much. Is this something I can replace myself, little to no experience. Kevin
  • 3,037 Answers
The price sounds very reasonable, the fix can be done by someone who knows how to solder. It is fairly simple but should only be attempted by someone who can solder and knows what is dangerous such as the capacitors. The tv should be unplugged overnight to give time to discharge and to fix it, simply cut off the old soldered connections and solder the new pieces back on.
let me know if you have any further questions.
If you don't know how to solder, then having the repairman do it wouldn't be a bad idea, but you could also see what someone else may charge you.
good luck
Posted on May 06, 2008
The tv is a Magnavox 51MP392H/17 and has sound but no picture. Any ideas?
TV is in high voltage shutdown protection mode. Check to see if Horizontal output transistor is shorted or open. If not then resolder all solder joints on HV transformer. If this does not fix it then you will need to do voltage checks off of H.O.T. and then possibly a bad HV transformer.
Apr 30, 2010 | Philips Magnavox 51MP392H Rear Projection...
Find a horizontal output transistor or flyback
Flyback transformer part number for a tv RCA F32648
Mar 06, 2010 | RCA F32648 32" TV
RCA32V434T
The Horizontal Output transistor needs to be changed as it is most likely shorted. The current transistor on this set is a 2SD3402 (no longer available) it's new replacement part number is the 2SC5902.
Order 2 2SC5902 Horiz Output transistors.Replace the transistor by it self once and if all is ok then fine.
If not replace it again and also the the Flyback HV transformer. The HOT transistor is probably shorted again and the transformer is causing it.
Dec 27, 2008 | RCA 32V550T 32" TV
My tv has no picture or sound. it makes a sound like its about toi come on but it doesn't. a red light just flashes
Dec 21, 2008 | RCA 32V550T 32" TV
RCA 52 rear projector tv makes chirpping noise wont turn on
You have a bad high voltage transformer. It is the white square device about 3inch square with large red wire coming out. Must be replaced with RCA original NO GENERIC. Also the horizontal output transistor must be checked to see if it is good. Recommend honest qualified tv repairman
Dec 30, 2007 | RCA P60921 60" Rear Projection Television
My tv rca
there is loose contact on the high voltage section in your tv.what you are going to do is open it,and reheat  with soldering iron and a piece of soldering lead the video chroma section and the high voltage section,near the flyback
Oct 23, 2007 | RCA 32F531T 32" TV
RCA F27669 27"
The F27669 uses the CTC203 series chassis. The most common cause of that symptom is a shorted horizontal output transistor, caused by a cracked solder joint on a small coil connected to that transistor's base. When this happens, the main B+ supply is shorted to ground so the power supply squeels. Every once in a while I also see the horizontal output transistor shorted due to a shorted flyback (high voltage) transformer. A good tech will replace the horizontal output transistor, resolder the coil and drive transformer, test the flyback (replacing it if necessary) and your set will be back to perfect.
Aug 08, 2007 | RCA 27V570T 27" TV
No power
The P52937 uses the PTK195 series chassis. If the TV makes a squeeling noise the instant it is plugged in then unplug it immediately and do not plug it back in. I have seen this many, many times. The flyback (high voltage) transformer has shorted out and the extra current it was drawing has shorted out the horizontal output transistor, so the B+ supply is dead shorted and the power supply squeels as a result. This is very common in that chassis. The flyback and output transistor will have to be replaced by someone with experience in RCA projection TV's. The HV block in the PTK169 sets is the one known to be bad a lot - the block in the 195 is very reliable and I have never seen one of those bad.
Jul 05, 2007 | RCA P52937 52" Rear Projection Television
56" RCA projection TV
If you can find the horizontal output transistor which is located near the flyback transformer,one lead of this drive transformer is connected to the base lead. (horizontal output transistor). There may be a little coil in series with this lead going to the transistor.
Jan 17, 2007 | RCA P52921 52" Rear Projection Television
26in rca colortrak 2000
Very common problem The Highvoltage transformer and the horizontal output transistor has to be replaced. If you have no tv repair experience, this is not a repair for you. seek a professional. Should cost about 175 to 225 for this repair. Good Luck
Jul 12, 2006 | RCA F32450 32" TV
RCA D52W19 52" Rear Projection Television Logo
54 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
