Question about Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator
My fridge is making a funny noise in the freezer section, sounds like someone is snoring
  • Fisher and P... Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
Fisher and paykel xrss 267BB fidge freezer
The system is either blocked or you have a gas leak but i would expect it is blocked and the only way to find out is to get a refrigeration engineer to check it for you, but explain the problem to him first and make sure he can help before you spend money.
Jul 19, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
Hello. My fridge freezer is playing up. It's from John Lewis and is about 4 years old. The fridge was not reaching the right temperature and it was making a funny noise, so took it apart and found that...
most fridge-freezers send cold air from the freezer to cool the fridge. the flow is usually controlled by adjusting a 'warmer-cooler bar or wheel in the fridge. maybe you disturbed its original position while working on the fan.
Jun 19, 2017 | Refrigerators
Freezer cold /refrigator warm . we have a side by side unit a couple of years old the freezer seems to work fine but the refrigator is warm .It don,t seem to make any funny noises and the back is clean
When the compressor is running, if the fan by the compressor and the fan inside the freezer are both running, and there is no frost on the back wall of the freezer (if there was frost would indicate a defrost issue) then check the air dampener. It is located at the very top left back side of the fresh food section. If it is not opening up, no air will flow from the freezer compartment (where all the cooling takes place) into the refrigerator section.
Jul 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool gold refridgerator light not working and is making funny noise
switch of your refrigerator then try replacing the light that doesn't work then try to switch it back on. the light might be the cause of the noise. it might be grounded. replacing the light might reduce the noise then observed the noise for a week then if it still making noise that's the time for you to get a technician that could fix your refrigerator.hope it helped... send us a message for more concerns thank you...
Jun 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer Noise. Water leaking in Fridge.
you need a repair man.you have a defrost problem and your drain is clogged.
Mar 09, 2009 | Haier HTE18WAA Top Freezer Refrigerator
HISSING SOUND FROM FRIDGE FREEZER
I poked a hole in the freezer with my knife while trying to defrost it. Now it is making a constant hissing sound. what should I do? is this dangerous?
Jan 23, 2009 | LG LRFC25750 Refrigerator French Door
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
My Zanussi fridge/freezer is making a funny little noise
What you may be noticing is the system going through a defrost cycle. Check the time of the day that you notice this event. If it happens at the same times it could be a normal situation if at all other times normal temperatures are being maintained. A popping sound can be caused by thermal expansion during the defrost.
Sep 13, 2008 | Freezers
Lg fridge freezer model gr-s352gca fault
Buy another brand. LG are cheap and nasty when it comes to whitegoods even though the price tag is still up there. I have done nothing but research for my next fridge and i might go with the same brand as i have had for the past ten years and have not had a single problem.(it is definately not a LG of Samsung or one of these other brands that have all the advertising and have only been around for a little while)
Jun 01, 2008 | Refrigerators
Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator Logo
584 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
