Yamaha RXV363 receiver shuts down every time when a loud DVD movie is played. It has only shut down oce or twice with a loud Directv movie. The cabinet the receiver is in, has about half an inch clearence around the receiver. I installed a small fan (5 in. blades) to blow across the receiver to help keep it cool. Would excess heat cause the reciever to shut down?
  • wille4d Aug 29, 2010
    Yes, but I wish I had been able to chat. I not quite sure I understand the term "source".
  • 11,800 Answers
Yes, heat could easily force a sudden shutdown of the receiver, but i don't think this is your case here - the volume of the sound should be very high, for a long period, to overheat the unit this much. Installing an extra fan and lowering the master volume should fix it. If it doesn't then my guess is most likely true.
My guess is that all of this has a different cause: when the sound spikes the amplifier is overstressed and draws a very high current from the source (or at least is trying to); the source of the receiver can't deliver it so the output voltage drops; the protection inside the source reads the drop as caused by a short and shuts down the source = the receiver shuts down.
The power source must be checked and the aged parts (the capacitors mainly) must be replaced.
Posted on Aug 26, 2010
  • Azrael SRL Aug 29, 2010
    Source, as in Power Source - the component that transforms the mains power (120volts AC) into the DC voltages needed by the components of the receiver.
Yamaha RX-V3300 Receiver shuts off on it's own.
A capacitor problem or overheat problem.
Feb 06, 2014 | Yamaha RX-V3300 Receiver
Hi, I have a Yamaha HTR - 6130 that seems O.K. until loud action scenes & explosions,then it shuts itself off.
There are two causes for this. One that there is a fault on the amp that is causing an overload circuit to trip and shut itself down. Or the settings of your speakers levels are wrong. So you are turning it up to hear the quiet parts of movies and therefore when louder sections come along your are driving the amp too much.
Some DVD discs that have THX on them have a sound set up on them. If you have one access the THX sound menu on the disc and adjust your speakers to produce the correct levels. If it does happen after that there's a fault.
By the way most of the George Lucas films (Star Wars) will have THX on them.
Aug 05, 2013 | Yamaha HTR-6130 Receiver
My yamaha rxv595a keeps on shutting itself off when im watching movies as soon that it gets loud it shuts off but its not even that loud how do i fix this problem i tried the ohms switch in the back and it...
That is a safety switch in most receivers. When something gets too loud it cannot give the load off to the speakers and shuts off to protect itself. This can mean that the receivers getting old, or that you might need to split the job. You might need an stereo amplifier to split the job. Check the cables and speakers. Recievers can only give so much to so many speakers at so much sound. That is what the whatts are for. The more whatts the better, the lesser whatts, the lesser speakers its going to be able to handle at high volumes.
Feb 28, 2011 | Yamaha RX-V595A Receiver
When playing dvd or or on video 3 playing a directv movie. Receiver keeps shutting off and the screen says protect. Seems to do it when the movie scene gets loud.
check your wires if there not touching behind the speakers and receiver. when it says protect this means something is shorting out or crossing over. one other thing it may be is if a speaker is starting to go bad. (please rate)
Dec 21, 2010 | Onkyo TX-DS595 Receiver
YAMAHA HTR 5560 KEEPS TURNING OFF
sounds like you have the polairity reversed on the speakers
and yes it does make a difference
check polairity also make sure unit is well ventelated
you wouldnt use your compouter if it was inside a card board box
so make sure the reciever can breath also
recievers get too hot and they start blowing chips off the board
Jul 25, 2009 | Yamaha HTR-5560 Receiver
I have yamaha v863 receiver. when i play movies on dvd. Any times
Check to make sure no wires are touching at the reciever. Next step is process of eleminaton. Unhook each speaker until it works or if you have a meter you could always check to see if you have a blown speaker or shorted wire. I would first disconnect all speakers and check to see if unit does it with no speakers connected.
Jul 06, 2009 | Yamaha RX-V863 Receiver
Shuts off after a loud sound
Hmmm...not sure but sounds like the vibration from the loud sound is causing the disk to jump. Not sure why that would power it off, but I think your thought to junk it sounds reasonable.
Dec 24, 2007 | Onkyo DV-CP704 DVD Player
Yamaha RX-V995 5.1 problem playing DVD's loudly
try using the analog mine had a problem with the dac. have any questions email me at facukoff@hotmail.com
Aug 13, 2007 | Yamaha RX-V995 Receiver
Shutting off during a loud part of a movie
Its eather a defect with the reciver top end shut down /over bias system , Or the speakers could be partially shorted, such as instead of being 8 ohms, the speakers could have a few shorted windings from a loud music event?? I would take the speakers in to be checked under load. NOT just checked for resistance.. A regular shop may not know how to do this BUT tell them you need to put the speakers under a load and then measure the resistance . GOOD LUCK
Jun 25, 2006 | Yamaha RX-V550 Receiver
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
