Question about Mitsubishi Vehicle Parts & Accessories
Mitsubishi magna TR 2.6 SOHC(4G54)Engine will crank but won't start when it is hot.I wonder if the cooling temperature sensor is giving some problem that it won't start the cooling fan
stormbrewin
  • 426 Answers
SOURCE: help with my mitsubishi magna 1994
Could be a few things.If you check radiator fan and its ok move down to the thermal power switch usualy at the bottom of the radiator.Make sure you have power in and out of the swich when the engine is at operating temp.Use a test light/probe easy to use and cheap to buy.If the switch is ok the next step is the relay in the box with lid next to the battery.Sometimes just pulling the relay out and putting back in will fix the problem due to poor contact.To sum up its usualy the thermal temp switch but check every thing else before wasting money on the wrong things.Good luck
Posted on Nov 08, 2008
SOURCE: Location of temperature sensor on Mitsubishi WS-65907
bendake,
It's been a little over a month, since your post, hopefully you have your problem resolved. If not, perhaps I can help. I'll call my response a SWAG rather than a WAG, so I hope it's helpful to you. First of all, let me answer your question, I'm not aware of any temperature sensor in that model. Less than 2 months ago I got a WS-65907 with a power problem. When I turned the TV on, the green power on light would come on for a few seconds then it would go off. The problem was a couple of pico fuses (5amp) and the convergence IC's. One of the IC's was shorted and that's what was blowing the fuses. Anyway, the IC's run hot, they are on a large heatsink. You may be able to purchase some thermal paste from Radio Shack, etc and put it on the back of your IC to help dissipate the heat. It's good that you're getting a 1-2 error code which indicates no error detected. In my research on the Internet, I read that Mitsubishi didn't put enough of the themal compound on the back of the chips and that's what caused them to eventually go bad.
If you've removed the front panel (and you can see past the neck of the 3 tubes) you should be able to see the vicinity of the IC's. they are located on the Middle board, they are attached to a metal heat sink (approx 4"X 8") the IC chips have a narrow metal strip holding them onto the heat sink. You may also consider getting some freeze spray that can be put on electronics. It may be useful in determining if this is your problem area. If so, you may luck out by applying some paste to increase the thermal transfer and keep the chips running cooler. Good luck with your TV.
Posted on Mar 12, 2009
joe7379
  • 93 Answers
SOURCE: 2000 Caravan-Engine cooling fans not running, replaced temperature sensor and fan relay, still not working-HELP
Did you replace the sensor by the thermostat in the engine block or the one under the drivers headlight, There are two, the one next to the thermostat controls the temp gauge in the vehicle. the one under the headlight assembly controls the actual fans and is a electronic module. You have to remove the head light assembly to get to it.
Joe
Posted on May 29, 2009
SOURCE: 1992 Ford Taurus with a 3.8l V6 the cooling fan
The Taurus has Two temp sensors. One for the dash, which is isolated, then one for the PCM, it also controls when the fan relay should actuate. Its a 2 wire sensor, just above the thermostat. If you remove the harness from that sensor, and the cooling fan comes on, at any temp, (should take 5- 10 seconds) then thats your fault.
Posted on Mar 11, 2010
cansmo
  • 2431 Answers
SOURCE: 1998 Ford Explorer, 4.0 SOHC No
You are at thhe right trail what controls spark is coil pack crank sensor sparkplugs and plug wire but the most important is power . I mean 12 volt connections and ground This includes checking fuses you need a simple volt meter doesnt have to expensive or fancy just to pick up 12 volts let start with fuses in the engine juction box (there not mark to what it belongs to) make sure none are open. especially fuse 19 and 24 , next go to the crank sensor make sure the tabs are snuggly on now to the coil pack there is a red and light green wire this comes from ignition and feeds 12 volts at the coil pack measure that voltage is it 12 volts if not correct it this is from ignition switch ( you can make a tool that feed 12 volt with a wire and a fuse in series and attatch it to battery and the primary wire this is known as hot wire) next go to the ECM wiggle the wires see if that get a connection going if not go back to the ICM here are the wire you are to measure the tan light green, this is from ECM and it is pulsed it measure 5vlts to 0 volts switched then measure the tan orange the same thing 5 volts to zero,then tan white again 5vlts to zero. any one of these 5 to zero fails you fix is the ecm
Posted on Aug 21, 2011
Yamaha XS 850 won't start when hot@
Hi, Anonymous and the usual suspects are:
1. Faulty ignition coil.
2. Faulty spark plug cables.
3. Faulty temperature sensor.
4. Faulty starter motor.
5. Valves adjusted too tight.
6. Spark plug gap too wide.
7. Fuel has vapor lock.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Bike won start when engine is warm
Bike won crank when hot http://biobug.org/motorcycle/xs850/Yamaha-XS70-XS850-Service-Manual.pdf
https://www.partsfish.com/page/oem-parts-for-yamaha
Yamaha XS850G Owner Manual
Aug 08, 2013 | Yamaha Motorcycles
Bad cam shaft senser
You could have a faulty engine coolant sensor or intake air temperature sensor. Fuel injectors clogged or dirty flooding engine.
Clean fuel injectors, replace fuel filter and air filter, and see if the problem persists.
If it does ECT sensor is bad. If CMP sensor was bad, the vehicle won\'t start whether cold or hot. CKP senso and CMP sensor work together if either one fails, the vehicle won\'t start. Have the vehicle code scanned.
Apr 18, 2013 | 1999 Chevrolet Tracker
1983 Honda VF 1100 C will not start when the engine is hot
Hi, Alex and the usual suspects are:
4. HISS light not going off.
5. Faulty starter motor.
6. Valves adjusted too tight.
7. Spark plug gap too wide.
8. Fuel has vapor lock.
83 magna v45 wont start hot
Bike won restart right after shutting it off but will after it sits for an...
Honda V65 MAGNA Shop Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda Shadow VT1100 Owner Manual
Mar 24, 2012 | 1983 Honda VF 1100 C
How do u take off a fan belt on a 1997 magna??
Hooters2810,
Depends on why you want to remove it.
If for instance you have a siezed alternator preventing the starter motor from starting the engine, (not uncommon), - and you just want to "get the Magna home from the shops", or get to the nearest repair shop, do what the Australian Road Service operarors do, and cut it off with a pair of cable sheers or a sharp trimming knife. Watch the temperature guage on the way home though. Shut it down and park it somewhere to let it cool completely before starting out again as soon as the temperature gets above your normal running temperature. Without the fan and waterpump running, the engine temperature will skyrocket, and you'll be up for replacement if you cook it.
Cheers
If you are needing to replace it yourself, - you've got quite a bit of dismantling work to get it out, and a new one in. If you haven't done this sort of thing before, - get a service manual, and definitely don't attempt this with a hot engine. You'll burn yourself.
Cheers
Feb 22, 2012 | 1997 Mitsubishi Magna
Colorado 2005 3.5l start and not crank when the engine is off 30 minute at hot no fault. fuel pressure is good.Crank sensor is new.Start 2 times and engine crank. Eric Tank you
If this problem only occurs after shutdown when hot, check temperature sending unit. This is usually first thing to prevent starting until engine is completely cooled down.
Jul 14, 2011 | 2005 Chevrolet Colorado
Crankshaft position sensor
where it the crank potision sensor on a 92 mitsubishi diamante
Sep 15, 2009 | 1998 Mitsubishi Diamante
Australian Mitsubishi magna tr take off window handle
You need a small hook to get behind the base of the crank and remove the clip that retains the window crank.
May 27, 2009 | 1994 Mitsubishi Galant
I have a Mitsubishi Magna TP Series 1989-1991 the cooling fans will not start and the motor over heats. I am unable to find the heat sensor (water temperature) or the relay that controls the fans. Can you...
under the hood you should see a black box on the driver side, this is called the power distribution box. its in there. and as far as the temp sensor, follow the top radiator hose back to the engine when it stops, look for a two wire connector this is your temp sensor
Aug 25, 2008 | Mitsubishi Passenger Cars & Trucks
92 TR magna
1990 Mitsubishi Sigma 3.0 liter SOHC V-6
Good luck, and remember rated this.
Jun 21, 2008 | 1990 Mitsubishi Sigma
Vehicle Parts & Accessories Logo
64 people viewed this question
Top Mitsubishi Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Navin Sharma
Navin Sharma
Are you a Mitsubishi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
