Question about GE Refrigerators
GE PSH23SGPABS will not cool at all. Board replaced by GE technician so fan works but no cold air. Any direction where to look next would be greatly appreciated.
5 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: Control Board Programming Code
the code is most likely printed on your model number label located inside the refrig compartment and entering the code instructions are on your tech sheet that is taped to the underside of your refrig.
remove the toe grille and feel under the cabinet for a plastic bag/envelope taped to it. just follow the instr for entering the code..
ps if the code isnt on the model label it may be on the tech sheet..
Posted on Dec 19, 2007
SOURCE: ge model gsh25jfrfww not cooling just clicking
Replace the main board on the back i got the part for $130 at a wholesale parts store
Posted on Mar 06, 2009
SOURCE: GE GSS22 refrig wont get cold, freezer does.
Hi, it's possible you have a defrost problem, to know if you have a defrost problem, you should unplug/disconnect refrigerator, remove your produce, leave doors open, for faster defrost, clean and leave unplug/disconnected for about hour, be cautious you will get excessive water from defrosting. let freezer defrost completely, then plug/connect refrigerator, let it work/run for an hour, if it's o/k, put back your produce, if it work good/ o/k for 3 to 4 days and start doing the same thing, you got a defrost problem, defrost problems are caused when excessive ice build up on your evaporator, two things could cause a defrost problem. (1) excessive moisture/ hot air entering refrigerator, hot days,hot foods, regular opening, to close heat source, range/ oven. in cases like that, cleaning of refrigerator will normally solve that problem. (2) faulty defrost heaters, defrost thermostat , located in back of freezer side, you will have to remove shelves and back panel, to get access to it,also check your defrost timer and speed of fan, but first disconnect refrigerator, clean and try , before changing any parts. it could just be excessive moisture. always remember to disconnect your refrigerator before attempting any repairs, let me know what happened, then i could tell you exactly what's problem. good luck
Posted on Aug 19, 2009
  • 110 Answers
SOURCE: hola: my GE PSC25PSTBSS sometimes is not cooling
edtorres: if the freezer side and ice maker are working fine then the problem may be the damper that allows cooling into the refrigerator side is having trouble opening or the controls to the damper are defective.
Posted on Mar 06, 2010
Hotpoint CTX21 ELA
Check and lobe the fans! The evaporation coil fan could be stuck, worn out or blocked. That fan is the cold air circulator and if it doesn't work, nothing will get cold! Also check the condenser fan usually located next to the compressor to blow room temp air across the condensing coil and across the defrost drain water pan. It's the hardest working fan and really takes the worst beating with dust, pet hair and heat.
Aug 21, 2014 | GE Refrigerators
Side by side GE turbo-cool Gss25XSRBSS, the freezer seems to be fine, the fridge is not cooling. Fans seem to be running smoothly, no weird noises. Turbo cool turns on. It hasn't been running for
if you go here you can see the damper,fan assy. that's in the top of your machine in the fresh food side
http://www.repairclinic.com/PartDetail/Damper/WR49X10091/1055112
this is a damper with another fan in it,when the t-stat calls for cold air the damper door opens to let the cold air in from the freezer and the fan in it blows the cold air around inside the fridge,if the freezer is fine and the fridge side is warm most likely this is your problem,part number WR49X10091 and it's around 130 dollars.unplug the machine,remove the light cover on the ceiling,remove the 1/4 inch screws and drop the light assy.remove thhe filter cover on the right side so you can remove the damper assy.pop off the cover on the piece that runs up the back center,remove the screws to the damper,read the instructions and put it back together again.should take you around 45 to 60 minutes.hope this helps and good luck.
Sep 27, 2012 | GE Refrigerators
What causes the coils behind the panel in the freezer to freeze up and stop the freezer fan? top half of freezer defrosts, lower half stays cold.Fridge is side by side and freezer fan keeps turning of
When the evaporator fan motor stops running the top half of the back wall of the freezer will frost over and the the only reason the lower portion stays cool is because cold air falls. More than likely you have a a dc motor fan and its bad, but be wary with ge, the main control board could also go bad causing the fan not to run.
Sep 05, 2012 | GE Refrigerators
98 buick century , with auto climate control ,
is it HOT or just not as cold. If its HOT, like heated air, there is a door problem, if its just not cool, the a/c refridgerent is low and will need a recharge, most likely the comp is leaking.
Sep 18, 2009 | 1998 Buick Century
My GE GSS22SGMBBSCC side by side refrigerator does not cool the upper freezer portion
Most newer GE fridges have dc fan motors controlled by a computer board. Sometimes the board just fails and sometimes the fan can cause the board to fail.
Jun 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrig model PSH23SGPABS
The main board needs to be replaced.
May 05, 2008 | GE Refrigerators
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
