Question about Nikon COOLPIX L3 Digital Camera
Lens error so How do you fix it??
  • Anonymous Oct 16, 2008
    when i turn on the camera the screen says zoom error and the screen is blury
  • 797 Answers
First what is the problem? What is not working?
Posted on Jun 21, 2008
  • Dave Lundmark
    Dave Lundmark Jul 28, 2008
    Please explain the error in detail and note everything. Is the camera quitting when the error comes up? When you see the error is there any other message in the LCD?
    If the lens error happens when the lens is partly extended, something in the lens is broken or out of sync. This can also be caused as a result of sand or dirt in the lens mechanism.
    If the lens does not move, and you hear no noise from the lens, then there are internal problems such as disconnections of cables, or corrosion, some other problems could be what is causing it as well.
    Lens errors and other errors could occur if the battery is low on charge. Always use full charged or new batteries.
    Of all the cameras I have worked on in the last few years, the lens is the biggest cause of problems. Some of the problems I have encountered:
    Lens errors such as: lens error, E18, Lens error restart the camera, and other such messages.
    They are caused by: (not in order) sand or dirt in the track, broken gears, stripped gears, out of sync or off track, bad connections due to loose cables or corrosion, and lost parts on the front of the lens.
    All of the above problems many times could be avoided if the person who uses the camera will simply remember that this unit is a very sensitive unit. Treat the camera like eggs, by that I mean handle it like it is very precious. Always use the wrist strap...that is what it is for. Never use the camera in a sandy area or beach area where there is a danger of getting sand in the camera. You may think it is not going to get in the camera, but if any wind with sand blows up... problems. And the possibility of dropping it in the sand does exist.
    My suggestion if you take your nice camera to the beach. Be very careful how you handle it, and be sure it does not contact any sand or water. Water is a killer on anything electronic...bad news. Put the camera in a self-lock bag such as a ZIP-LOCK
    bag when you put it down. On top of all that, put it in a padded bag to protect the LCD and surface of the camera.
    I do sell used/refurb. cameras on Ebay and use the same name as here.
My Coolpix camera lens won't open, says lens error, any ideas how to fix.
Hi Connie:
Lens stuck, is common defective that need new lens unit replacement or just repairable.
Causes of a Lens Error: There are a number of ways with which a lens error can be caused. Particulates might have managed to get into the mechanical bits that allow the lens to retract, a purely physical interference with the lens mechanism. If the camera was dropped, especially while the lens was extended, there's a pretty good chance something might have been knocked loose, such as the guide pins upon which the lens withdraws and retracts.
How to Repair a Lens Error: As scary as a lens error might seem, there are some easy fixes. Before trying any of them out, however, first take a good long look at your camera warranty and maybe have a chat with the company. If the lens error will be covered under the terms of the warranty, go for it. Even some of the simple fixes mentioned below might void the camera warranty. Sincerely, however, it's unlikely that a lens error will qualify for the warranty.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 16, 2011 | Nikon Coolpix S210 Digital Camera
Lens error
How to Repair a Lens Error: As scary as a lens error might seem, there are some easy fixes. Before trying any of them out, however, first take a good long look at your camera warranty and maybe have a chat with the company. If the lens error will be covered under the terms of the warranty, go for it. Even some of the simple fixes mentioned below might void the camera warranty. Frankly, however, it's unlikely that a lens error will qualify for the warranty.
Additional details could find in this article link: fixing-lens-error-on-digital-camera.html
Keep us updated.
Jun 03, 2011 | Nikon COOLPIX S200 Digital Camera
How can i fix a lens error on s610?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 13, 2009 | Nikon COOLPIX S610 Digital Camera
Lens error,restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Jul 03, 2009 | Canon PowerShot A460 Digital Camera
HP Photosmart M425 Lens error
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 30, 2009 | HP Photosmart 945 Digital Camera
Lens error, restart camera
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Apr 26, 2009 | Canon PowerShot SX100 IS Digital Camera
Lens Error on NIkon CoolPix L2
Jul 31, 2008 | Nikon COOLPIX L18 Digital Camera
Lens error 25 and 15
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Mar 25, 2008 | Kodak EasyShare C330 Digital Camera
Nikon COOLPIX L3 Digital Camera Logo
41 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
