Question about Microwave Ovens
My griddle burner pumps out propane; the temperature dial doesn't seem to have any affect on the gas coming out of the jets and the fumes are extremely strong that we barely use the griddle. Is there a way for me to adjust it down? Also, there is a green fabric wrapped wire that extends from the back of the range in the area of the griddle that is not plugged into anything. I'm assuming that this should be plugged in. If so, where?
  • 1 more comment
  • Dea Traverso Aug 26, 2010
    This should be posted under Kitchen Ranges not microwave ovens.
  • Dea Traverso Aug 28, 2010
    Hi Greg,
    I've pulled the drip pan out and used a mirror to see the underworkings of the griddle burner, etc. I see the "metal kind of box" that is right behind the temperature dial but I can't seem to locate any spot where that green wire would attach to. I've run the mirror under the propane line but still didn't see anything. The connectors to the other burners are very easily located and those wires connect directly under each burner but I don't seem to see anthing related to the griddle. The "ribbed" metal tubing which I gather is the gas line coming into the range does connect directly to that metal box behind the temperature dial for the griddle and I do see where two wires could attach to it and both of them are already inserted. They are both white covered wires with peach colored clear plastic/rubber protectors on the connectors. Perhaps the green wire isn't for the griddle; perhaps it is an auxillary wire to use if say, I had opted for the grill burner vs the griddle. In any event, what controls the amount of gas that is pumped through the jets because it is way too much for the griddle. (The other burners are not at issue; just the griddle.) Is it something I can adjust, and if so, how? Thanks Greg for your help... Dea
  • Dea Traverso Aug 31, 2010
    Thanks Greg...I'll have to go ahead and call for service. Too bad it wasn't just any easy fix; I think I would be foolish to try and take anything apart on my own. --Dea
    Genius:
  • 1,340 Answers
The green fabric should contain a wire/connection coming from the thermocouple since it has temperature and not just an adjust it to where you see it type.Know what I mean?The thermocouple should be a somewhat long,thin metal tube and the connection should plug in somewhere in the regulator,which would be a metal kind of box(something other than the tubing)be in the propane line between the tank and the dial probably close to the dial if not directly connected to it.Can you see the tube?If you need help just reply to this post and i will get an auto link.
Good luck! Greg
Posted on Aug 26, 2010
  • 4 more comments
  • Greg McCarthy Aug 28, 2010
    Okay Dea.So what you said was that there was an option to have either a regular grill or a griddle,it's one or the other you can't have both correct?Also did the dial used to work,it seems as if it did since you're posting.It sounds like the burner is pretty low too.Would you give me the make and model number of your grill?It may help me find a parts breakdown or something very useful.Another thing,does the dial have any numbers on it for temperature or is it a high/low or just basically on/off.
    Thanks,Greg
  • Dea Traverso Aug 30, 2010
    Hi Greg,
    Yes the stove has the option to accept either a grill or a griddle; it just slips in so I am able to remove it to look at everyting underneath the actual griddle pan. The dial has always worked; I am not the original owner of this Viking range but for the past 5 years I've had it, the dial has always worked and yet it really seems to pump out to much propane. The dial is just like those for the ovens, with low, degree temperatures starting with 200 up to 450 and then high. The model of this range which designates the option with the griddle is: VDSC485-6GCB. Sorry for the delay, been out of town. Thanks again! Dea
  • Greg McCarthy Aug 30, 2010
    http://www.specsserver.com/CACHE/FREOGPX...
    Forget the link for now.I put it there for a reference for myself.Couple more questions.Do you have to open the gas valve every time you use,if yes,it and is that normal or did you have to do it since this started.When you start it does it go straight to high flame?If yes how do you turn it off and is that normal procedure or not?I have found out that it is controlled by a thermostat.A part that measures the heat your dial wants compares it to the heat it is sensing in the chamber/burner section and tells the regulator to adjust the flame according to what it is required compared to what you want.Got that?lol.Anyhow,depending on how you answer the questions,we should be able to figure it out.I would imagine that the green wire does not seem to be an issue because 1.It would be obvious to where it plugged in and you found nothing2.It would not likely just disconnect unless someone was in there just moving their hand around back and forth and since you also had to use a mirror just to SEE it,nope.3.The way they talked about how you could select different options as to how the oven is set up,you already said it.It probably was just that they are all made the same,different options require different things.It looks like it had 4 burners but now has 2 griddles correct?Yes,there will be "leftover" parts.(I hate that).They do it in car fuse boxes too.Be looking for your reply.Hope you went out of town for something fun at least Dea! Greg
    Greg,
    No, I don't have to open a gas valve, just turn the griddle temperature knob; just like you would turn on any oven.
    Regarding the green, wire: I thought perhaps I had disengaged it when I pulled out the 48 wide drip pan to clean at one time or another that is under all of the burners; it is a huge piece of equipment; 22 x 48.
    The range is a 6 burner configuration: 2 griddle 4 viewed from left to right.
    ---Dea
  • Greg McCarthy Aug 31, 2010
    If you turn it on and it goes straight to high flame,I would say the gas regulator is bad or needs servicing.Some are designed with a spring inside which helps control the gas flow.I am not positive about this particular case but that sounds like an example of that type design.I did find their number
    1-888-VIKING1 if you want to double check or request service or do you want to self-repair?Doesn't sound like you want to self-repair but I always ask.Let me know how you make out Dea.Greg
    Yes,if you are unsure about anything as far as gas appliance repair,it's not something to BOOM mess with.lol.I'll tell you now too,I think regulators are probably close to $100+ labor+house call+repair centers normally have a 20% parts price markup from what they pay. :( I also saw pictures of those things on their site.That thing is pretty big. Cya Greg
CAN a ZANUSSI gas cooker be converted to utilize NG ? Without affecting its programs and controls ?
usually any gas cooker can be converted as long as the gas jets are changed to the right size. they also have to be the right fitting. it would involve a lot of work as you will need to get into the nitty gritty of the gas lines inside the cooker and if you make a mistake it can cost to get it fixed.
Jul 02, 2017 | Microwave Ovens
Ignitor keeps clicking on burner
A creda microwave oven doesn't have an ignitor or burner, so I assume you are talking about either a BBQ grill or gas range.
A suggestion: Clean the ignitor tip with a CLEAN and DRY green scouring pad; check that you have gas coming out of the burner.
If you have gas at the burner and the ignitor is clicking (sparking) then it is usually an ignitor alignment problem where the ignitor got bumped out of position.
Jun 06, 2011 | Creda Microwave Ovens
How do I use my Griddle for the first time? We did not get a manual I would like one sent to us.
I can't help you with the manual because you did not provide the make and model number.
Typically, you wash the griddle with soap and water (DO NOT WASH ANY ELECTRICAL CONTROL UNIT!). Rinse and let dry if it has a non-stick coating. If it does not have a non-stick coating (bare metal), towel-dry the griddle, then put some vegetable oil on a paper towel and wipe the entire cooking surface so it is covered with a thin film of oil. Heat it to about 250 °F for about one on-off cycle on the electrical control. It is now "seasoned" and ready for use. If the griddle does not have an electric heater but is designed for use on a range-top burner, set the burner to just below medium heat and heat until water droplets splattered on the griddle boil off quickly.
May 30, 2011 | Microwave Ovens
Has a very small flame does not heat the griddle
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Apr 17, 2011 | Microwave Ovens
Gas jets on stove keep going out after a few minutes
Your problem could be or probably is with the regulator...not enough gas pressure...
or you are out of gas....
heatman101
Feb 11, 2011 | Fisher and Paykel Microwave Ovens
I would like to upgrade one of my burner grates for a GE "Gas Slide-in Range (Model #JGSP20). The individual burner grates are 8 5/8" square and 7/8" high. I would like to locate one...
Hi!!
A new OEM grate for your unit will cost about $62.00 + S&H at this place http://www.repairclinic.com/PartDetail/Grate-or-Griddle/258336
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Jan 08, 2011 | Microwave Ovens
How to convert from natural gas to propane
You just need to replace the burner orifice. The Propane gas LPG has orifice with much smaler holes.
Sep 30, 2010 | Microwave Ovens
Top left burner (propane) does not seem to be receiving gas when trying to ignite it with electrical igniter (control knob). However the burner can be lit with a match when the control knob is turned past...
The igniter usually sparks for all burners on the stove at the same time. Usually a little water or gravy, or such has gotten on the little spike that stick up and throws the spark to the burner. If you will take a small brush, like a tooth brush and carefully clean around the little spike it normally starts sparking again. As it is right now, you should be able to see the spark on all the burners whenever you start any of the burners. Check to see on the one that is not lighting, I think you will find that it is not sparking at all right now.
Sep 21, 2010 | Microwave Ovens
I have a Viking Professional VGRT Gas 4 Burner + Griddle Cooktop. The griddle stopped working all together. The burners still all ignite and work fine. The griddle does not heat up. When we turn the...
I just had a tech come to my house and he told me that I need a new glow plug, It's the box to the right of the flame. Looks easy to replace, his visit took 5 minutes and it cost me 143.95 (this doesn't include the cost for the part or to have him come fix it, that will be sometime next week) so if you can get the part and do it yourself I would suggest that.
Jul 29, 2010 | Microwave Ovens
Microwave Ovens Logo
12 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
