Question about Bose Wave Radio II
Bose Wave AWRCC2 CD "not playable"
Cd's won't play. I receive this message every time I try to play a CD. Any help would be great.
I had the same problem yesterday on my new Bose Wave Music System. I just kept on pressing reinsert everytime the CD got rejected and suddenly it started accepting CD's again.
Posted on Dec 28, 2008
  • 975 Answers
What kind of CD ?? all kind ? or CD-Rs , IF SO try cleaning the optical lens w/ a Qtip dry , and check again , if still getting message then OPTICAL LENS need to be replaced , hope this helps, AJ
Posted on May 06, 2008
2 Suggested Answers
  • 5 Answers
SOURCE: Cd "not playable" on Bose Wave AWrcc2
Sounds like a weak or bad optical pick-up. You could try gently cleaning it, but you'll probably have to send to Bose for repair.
Posted on Oct 08, 2009
Bose wave radio cd won't play cd's
If your CD is not scratched,the optical lens need replacement.
Apr 02, 2013 | Bose Awrc1g Wave Radio Cd Player Only -...
When i put in a cd, a message "not playable" comes
The problem is in the laser pickup assembly, over a period of time the laser pickup becomes weaker until it can no longer track the cd properly causing skipping, and plays off and on. One possible solution "if the laser lens is accessible", you can try cleaning it with a Q-Tip and rubbing alcohol very carefully allowing several minutes to dry. If this fails, Bose will need to be contacted since they do the authorized repairs on their products.
Feb 04, 2011 | Bose & Wave& Music System
My Bose Wave radio/cd won`t play cd`s anymore. The radio works great. The cd player worked tonite, the would stick in a certain part of a song. Very intermittent. Now tries to read the disc, then says disc...
"I`ve used an aerosol air can to clean thru the cd slot"What type? not an "empty" can of paint, hairspray, chemical of some sort i hope. Compressed air at most I hope. If not, that's your Bose out the window!
The lense sounds like it needs a clean, you can buy these in disc for with tiny brushes on. Made by BIB and Allsop amongst many brands
Aug 30, 2010 | Bose Wave Music System CD Shelf System
CD not playable
call bose for repair on this unit. The laser could be dirty but in most cases there is another failure. Possibly in the motor control circuit. They have a flat rate repair service.
May 03, 2010 | Bose & Wave& Music System
Have a Bose wave Music Sys model AWRCC2 with stuck
Yes I think you can, get out your tools and take apart the unit, what do you have to loose you can always take it to a pro if you can't get it out. Be careful to unplug the unit. Don't force anything when you take it apart, be careful not to break any parts, put all pieces back together as you took them apart. Should be very straight forward if you are careful at what you do, get a bowl to put small parts in. Good Luck.....
Apr 07, 2010 | Bose Wave Radio
Recorded audio CD will not play
Most likely the recorded format is wrong and that is the cause.
May 05, 2017 | Bose Wave Radio
Bose Wave Music System - CD Says "Not Playable"
I turned mine upside down pressed play and it started working.
Turned it back over and it's working fine.
Dec 22, 2008 | Bose & Wave& Music System
May 06, 2008 | Bose Wave Radio
Bose Wave AWRCC2 error message
Which error, you did'nt put it in the post.
Mar 31, 2008 | Bose Wave Radio
Bose Wave Radio II Logo
1,843 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
