Question about Car Audio & Video
Manual for boss audio system BV996B - Car Audio & Video
How to reset screen
Not sure which model you have, but on most Boss models there is a little button on the front of the unit that you need to push with a pen. The button may say RES next to it. It also may be in the back of the unit.
Somewhere on the unit there is a button! Push it!
Find your manual using the link below if you can't find the button.
Boss Car Audio Manuals
May 10, 2015 | BOSS AUDIO SYSTEMS Car Audio & Video
Boss bv9976 wont play videos from USB?! Anyone know??
The Boss BV9976B supports playback of JPEG/MP4 and DIVX formats. Double-check to make sure your movies are in one of these formats. Then triple-check. Download a converter to convert your movies to the proper format.
Boss BV9976B manual
Dec 04, 2014 | BOSS AUDIO SYSTEMS BV9976 Car Video Player
Screen will not turn on it came on then it stop
Try resetting the system. Follow these instructions:
  • Push the RES or RESET button with a pen or similar object.
  • The button location depends on your Boss model.
  • Turn the power on.
Download the correct manual for your model in order to locate the RESET button:
Find your Boss manuals using the link above.
Sep 04, 2014 | BOSS AUDIO SYSTEMS Car Audio & Video
Why my bv9562b says gps not supported
In the Boss manual, that radio doesn't even mention gps. I suspect it doesn't come with the antenna, and other electronics necessary for gps functions.
http://www.bossaudio.com/manuals/
Manuals Boss Audio Systems
Apr 23, 2014 | GPS
I've purchused a 8gb sony sd memory card and when
It may not be formatted in a compatible format supported by your BOSS Audio system. Check the owner's manual of the unit,it should indicate which format it will support. Copy the data currently on the memory card back to a file on your PC/Laptop and reformat the card to match your BOSS unit. Have you tried other memory cards? It is also possible that the card has too large a capacity for the BOSS unit. T
Feb 13, 2012 | 2002 Nissan Altima
Where is the reset button on the boss audio system bv9560b
Click on the link below to view the BOSS audio BV9560b user manual, inside the manual it will show you where the reset button is located:
http://www.retrevo.com/support/Boss-Audio-BV9560B-Car-Videos-manual/id/23353ci554/t/2/
Feb 04, 2011 | BOSS AUDIO SYSTEMS BV9560B Car Video...
I dont know how to get my Boss Audio BV9455 to play from the USB slot how do i get it to work?
Refer to Manual Setting.... Go on Google.. then Exemple: ( download Boss audio BV9455 DVD player manual... then take the manual you need ..good luck
Sep 30, 2010 | Boss AUDIO SYSTEMS BV9455 Car DVD Player
What size blade fuse would I need for my D800.2 Boss amplifier? I took it to a shop to work on my music system ,and for some reason they threw away the fuse. I don't remember what size was in the single...
You need a 30 amp fuse according to Boss Audio's owners manual.
http://www.bossaudio.com/support/index.php?_m=downloads&_a=viewdownload&downloaditemid=564&nav=0,2
Aug 02, 2010 | Boss AUDIO SYSTEMS D8002 Car Audio...
Car Audio & Video Logo
127 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
