When i switch on than it goes off before blink three times
    President:
  • 2,291 Answers
Put out ur battery for some time and then try again, hit the keybboard when starting normaly not to hard,check if it works, check for ur battery, if it is fully charged
Posted on Aug 26, 2010
Why is it stuck in standby?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Aug 25, 2015 | Magnavox 32MD359B 32 in. TV
Eninge lite blinks fast and wont start
Pull any error codes.
The engine light lights up when you turn the ignition switch on, then goes off. After four seconds, if it comes on again and stays on, there is a present fault code. When it is an historical fault code, it comes on with ignition and goes off then comes on and goes off again. I believe in like 4 second intervals. A historical code will not be removed until a cycle of 50 ignition on/of intervals has passed. In other words, the engine light will continue to light two times when ignition switch is turned on, after 50 on/off cycles have passed the historical codes will no longer affect the engine light when starting.
If you will hold the odometer button on the side of the console down, and turn the ignition on and off, three times I think, waiting for the fuel pump to stop before turning the ignition switch to the off position, and one second until you turn it on again, the third time holding the odometer button down until the engine light begins to blink it will begin to blink in a fast sequence showing the fault codes will follow.
First indication of fault code display is rapidly blinking engine light. After that count the number of times the engine light lights up. There will be a brief pause between digits. If there are multiple codes stored, the rapid blinking will separate each. Once the fault codes begin to repeat, you have gone through all stored codes.
Tips: Have a pencil and paper ready.
Maybe ask a friend to help out. Sometimes a second pair of eyes can be good.
Go through a couple of cycles, so that you are sure you haven't missed any codes.
One example is if it blinks 3 times, pause, the blinks 2 times, that means 32.
Code 32: Rear Fuel Injector
Feb 16, 2014 | 2000 Harley Davidson FLHTCUI Electra Glide...
Lcd t v troubleshooting
Probable power supply failure.
Dec 31, 2013 | Computers & Internet
Nokia 3110c blinking three time and switch off
nokia 3110c blinking three time and switch off
Nov 19, 2010 | Nokia 3110 Cellular Phone
My Sony KDF-50WE655 does not turn on. Only the standby LED Flashes several times and then goes steady green, but the lamp light remains off.
Hello
You just count the number of blinks of the standby light before it goes out to green. In sony sets this blinking count ic critical for us to locate the faulty stage. You just count it after switch it Off by Power switch and Switch it On by the power switch at the front of the TV, for at least three or four times, and make sure abut the number of blinks, and report it to me. Ok
Nov 14, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Red blinking light three times pause then three
Make sure that lamp door is fixed securely and pressing lamp door switch as 3 times blinks shows lamp door switch is not On.
May 13, 2009 | Sony KDF-50E2000 50" HDTV
BRAVIA KDL-V32A12U PICTURE LOSS
THREE Blinks
B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FIVE Blinks
AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
Jun 19, 2017 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Kenmore elite dishwasher
I had the same problem when I bought it and it just happened again; the problem is solved by ressting the control panel: Hi Temp ---> Heated Dry two or three times. It kind of goes into a testing cycle and the clean blinking light goes off.
Dec 08, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
